I want to interface a 16MB external flash (SPI) with nrf52832 on the development board.Suggest me how should I start with and if there is an example for external flash then let me know.
Hi
Did you really need a 100ms delay after chip select to make it work?
Did you try to measure how long the status is busy after issuing an erase command?
According to the specification this can take several seconds, depending on how much you are erasing.
I realized you're using a similar flash device to the one used on the nRF52840DK, which allows me to do some testing myself.
Are you able to send me both your source and header files so I can try to run your code?
The code you sent is referencing some includes and defines that I don't have.
Best regards
Torbjørn
Did you really need a 100ms delay after chip select to make it work? - No but to try to get the chip erase working I added that delay . But now when I removed it it is working. But I am not sure enough that whether it will work always or not.
I realized you're using a similar flash device to the one used on the nRF52840DK- Yes its a similar flash with difference in its storage capacity .(16 MB)
I have made removed that 100ms delay after CS and also removed the flash busy and wait status which I think is necessary but after doing that I am able to get the results sometimes. So I think it still needs some modifications for its proper functioning. I am attaching my source code for your reference.I am using SDK 15.3.0ble_app_uart_pdm_extflash.rar
Hi
Thanks for sharing your project. It mostly seems to work fine, except the external_flash.c/h files appear to be missing.
Most likely you put these in one of the SDK folders.
Are you able to share these files also?
Best regards
Torbjørn
Opps, Sorry for the inconvience. I am sharing these two files. One more thing I have doubt is that I am not able to write more than 16 bytes and also do not know the what the
// * @file ext_flash.c
// * This source file provides external flash memory related functionalities.
// * @author Glide Embedded Technology <www.glidemtech.com>
// * @date 7, August, 2019
///* Includes ------------------------------------------------------------------*/
#include <stdio.h>
#include <string.h>
#include <stdint.h>
#include "external_flash.h"
#include <hal/nrf_gpio.h>
#include <hal/nrf_spi.h>
#include "nrf_drv_spi.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
uint8_t print = 1;
#define SPI_INSTANCE 0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);
#define WAIT_FOR_PERIPH() do { \
while (!m_finished) {} \
m_finished = false; \
} while (0)
static volatile bool m_finished = false;
static uint8_t m_buffer_tx[256];
static uint8_t m_buffer_rx[256];
//static uint8_t m_data_send[256];
static uint8_t m_data_receive[256];
#define TEST_STRING "Z" //"Nordic"
static uint8_t m_tx_buf[] = TEST_STRING; /**< TX buffer. */
static uint8_t m_rx_buf[sizeof(TEST_STRING) + 1]; /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);
//int16_t pcm_data_buffer[MEM_SIZE_15KB] = {0};
static uint16_t pcm_data_buffer[MEM_SIZE_15KB];
static uint8_t m_data_send[225] = {[0 ... 224] = 0xcd};
uint8_t StatusReg;
uint8_t ConfigReg;
uint8_t SecurityReg;
* @brief SPI user event handler.
* @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
void * p_context)
m_finished = true;
uint16_t i ;
//printf("\n\rTransfer completed.");
if (m_buffer_rx[0] != 0)
// printf(" Received:");
for(i=0;i<8;i++)
// printf("m_buffer_rx[%d] = %x ",i,m_buffer_rx[i]);
NRF_LOG_HEXDUMP_INFO(m_buffer_rx, strlen((const char *)m_buffer_rx));
// nrf_gpio_pin_set(SPI_SS_PIN);
void cs_low(void)
nrf_gpio_pin_clear(SPI_SS_PIN);
void cs_high(void)
// nrf_gpio_pin_clear(SPI_SS_PIN);
* Reset setting Command
* Function: CMD_RSTEN
* Arguments: None.
* Description: Enable RST command
* Return Message: FlashOperationSuccess
ReturnMsg cmd_rsten( void )
// Chip select go low to start a flash command
cs_low();
// Write RSTEN command
uint8_t instruction = FLASH_CMD_RSTEN;
m_buffer_tx[0] = instruction;
nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,1,m_buffer_rx,1);
// Chip select go high to end a flash command
cs_high();
return FlashOperationSuccess;
* Function: CMD_RST
* Arguments: fsptr, pointer of flash status structure
* Description: The RST instruction is used as a system (software) reset that
* puts the device in normal operating Ready mode.
ReturnMsg cmd_rst( void )
cs_low();
// Write RST command = 0x99
uint8_t instruction = FLASH_CMD_RST;
cs_high();
* Function: CMD_WRSR
* Arguments: UpdateValue, 8/16 bit status register value to updata
* Description: The WRSR instruction is for changing the values of
* Status Register Bits (and configuration register)
* Return Message: FlashIsBusy, FlashTimeOut, FlashOperationSuccess
ReturnMsg cmd_wrsr( uint8_t UpdateValue )
// Check flash is busy or not
if( IsFlashBusy() ) return FlashIsBusy;
// Setting Write Enable Latch bit
uint8_t err_code;
err_code = cmd_wren();
// cs_low();
// Send command and update value
uint8_t instruction[9] = {0};
instruction[0] = FLASH_CMD_WRSR;
nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction,1,m_buffer_rx,3);
nrf_delay_ms(2);
printf("UPDATE VALUE = %d",UpdateValue);
instruction[1]=UpdateValue;
// memcpy(instruction[1],UpdateValue,8);
nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction[1],2,m_buffer_rx,4);
//#ifdef SUPPORT_WRSR_CR
// SendByte( UpdateValue >> 8, SIO ); // write configuration register
//#endif
cs_high();
if( WaitFlashReady( WriteStatusRegCycleTime ) )
return FlashTimeOut;
//ReturnMsg cmd_wrsr( uint8_t UpdateValue )
// // Check flash is busy or not
// if( IsFlashBusy() ) return FlashIsBusy;
// // Setting Write Enable Latch bit
// uint8_t err_code;
// uint8_t read_value;
// nrf_gpio_pin_clear(SPI_WP_PIN);
// err_code = cmd_wren();
// // Chip select go low to start a flash command
//// cs_low();
// // Send command and update value
// err_code = cmd_rdsr(read_value);
// printf("rdsr valu = %d \n",read_value);
// if((read_value & 2)== 1)
// uint8_t instruction[9] = {0};
// instruction[0] = FLASH_CMD_WRSR;
// nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction,1,m_buffer_rx,3);
// nrf_delay_ms(2);
// printf("UPDATE VALUE = %d",UpdateValue);
// instruction[1]=UpdateValue;
//// memcpy(instruction[1],UpdateValue,8);
// nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction[1],2,m_buffer_rx,4);
// if((read_value ^ 1)==1)
// printf("wep is zero \n");
//// uint8_t instruction[9] = {0};
//// instruction[0] = FLASH_CMD_WRSR;
//// nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction,1,m_buffer_rx,3);
//// nrf_delay_ms(2);
//// printf("UPDATE VALUE = %d",UpdateValue);
//// instruction[1]=UpdateValue;
////// memcpy(instruction[1],UpdateValue,8);
//// nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction[1],2,m_buffer_rx,4);
////#ifdef SUPPORT_WRSR_CR
//// SendByte( UpdateValue >> 8, SIO ); // write configuration register
////#endif
// // Chip select go high to end a flash command
// cs_high();
// if( WaitFlashReady( WriteStatusRegCycleTime ) )
// return FlashOperationSuccess;
// else
// return FlashTimeOut;
* Function: CMD_RDSCUR
* Arguments: SecurityReg, 8 bit buffer to store security register value
* Description: The RDSCUR instruction is for reading the value of
* Security Register bits.
ReturnMsg cmd_rdscur( uint8_t *SecurityReg )
uint8_t gDataBuffer;
cs_low();
//Send command
uint8_t instruction = FLASH_CMD_RDSCUR;
nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction,1,gDataBuffer,3);
cs_high();
*SecurityReg = gDataBuffer;
* Function: CMD_WRSCUR
* Arguments: None.
* Description: The WRSCUR instruction is for changing the values of
* Security Register Bits.
* Return Message: FlashIsBusy, FlashOperationSuccess, FlashWriteRegFailed,
* FlashTimeOut
ReturnMsg cmd_wrscur( void )
cmd_wren();
cs_low();
// Write WRSCUR command
uint8_t instruction = FLASH_CMD_WRSCUR;
cs_high();
if( WaitFlashReady( WriteSecuRegCycleTime ) ){
cmd_rdscur( &gDataBuffer );
// Check security register LDSO bit
if( (gDataBuffer & FLASH_LDSO_MASK) == FLASH_LDSO_MASK )
return FlashWriteRegFailed;
* Function: CMD_RDID
* Arguments: Identification, 32 bit buffer to store id
* Description: The RDID instruction is to read the manufacturer ID
* of 1-byte and followed by Device ID of 2-byte.
ReturnMsg cmd_rdid( uint32_t *Identification )
uint32_t temp;
uint8_t gDataBuffer[3];
cs_low();
// Send command
// SendByte( FLASH_CMD_RDID, SIO );
uint8_t instruction = FLASH_CMD_RDID;
// Chip select go high to end a command
cs_high();
// Store identification
temp = gDataBuffer[0];
temp = (temp << 8) | gDataBuffer[1];
*Identification = (temp << 8) | gDataBuffer[2];
printf("rdid = %x %x",gDataBuffer [0],gDataBuffer [1]);
* Function: CMD_RES
* Arguments: ElectricIdentification, 8 bit buffer to store electric id
* Description: The RES instruction is to read the Device
* electric identification of 1-byte.
ReturnMsg cmd_res( uint8_t *ElectricIdentification )
printf("cmd_res \n");
cs_low();
// Send flash command and insert dummy cycle
uint8_t instruction[4];
instruction[0]= FLASH_CMD_RES;
instruction[1]= 0;
instruction[2]=0;
instruction[3]=0;
nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction,4,m_buffer_rx,5);
// Get electric identification
*ElectricIdentification = m_buffer_rx[4];
printf(" eid = %x\n",m_buffer_rx[4]);
cs_high();
* Function: CMD_REMS
* Arguments: REMS_Identification, 16 bit buffer to store id
* fsptr, pointer of flash status structure
* Description: The REMS instruction is to read the Device
* manufacturer ID and electric ID of 1-byte.
ReturnMsg cmd_rems( uint16_t *REMS_Identification, FlashStatus *fsptr )
uint8_t gDataBuffer[2];
cs_low();
// Send flash command and insert dummy cycle ( if need )
// ArrangeOpt = 0x00 will output the manufacturer's ID first
// = 0x01 will output electric ID first
// SendByte( FLASH_CMD_REMS, SIO );
// InsertDummyCycle( 16 );
// SendByte( fsptr->ArrangeOpt, SIO );
instruction[0]= FLASH_CMD_REMS;
instruction[1]= 0;
instruction[2]=0;
instruction[3]=0x00;
nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction,4,m_buffer_rx,6);
// Get ID
gDataBuffer[0] = m_buffer_rx[2];//GetByte( SIO );
gDataBuffer[1] = m_buffer_rx[3];//GetByte( SIO );
// Store identification informaion
*REMS_Identification = (gDataBuffer[0] << 8) | gDataBuffer[1];
cs_high();
void cmd_read( uint32_t flash_address, uint16_t *target_address, uint32_t byte_length )
uint32_t index;
// Check flash address
if( flash_address > FlashSize )
return FlashAddressInvalid;
// cmd_wrdis();
// nrf_delay_ms(100);
cs_low();
// nrf_delay_ms(50);
// Write READ command and address
memset(m_buffer_tx,0x00,sizeof(m_buffer_tx));
uint8_t instruction;
instruction = FLASH_CMD_READ;
m_buffer_tx[0]= instruction;
m_buffer_tx[1] = flash_address >> 16;
m_buffer_tx[2] = flash_address >> 8;
m_buffer_tx[3] = flash_address;
// nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,FLASH_CMD_READ_LENGHT,m_data_receive,FLASH_CMD_READ_LENGHT+16);
nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,FLASH_CMD_READ_LENGHT,m_data_receive,FLASH_CMD_READ_LENGHT+byte_length);
// for( index=0; index < 4; index++ )
// printf("m_buffer_tx[%d] = %.02x \n",index,m_buffer_tx[index]);
// nrf_delay_ms(10);
// for( index=0; index < 20; index++ )
// printf("m_data_receive[%d] = %.02x \n",index,m_data_receive[index]);
nrf_delay_ms(50);
cs_high();
return true;
void read_data_ext_flash(void)
uint8_t i;
static uint32_t flash_address = FLASH_TARGET_ADDR;
static counter=0;
for(i=0;i<16;i++)
// for(i=0;i<2;i++)
// for(j=0;j<256;j=j+2)
cmd_read(flash_address,pcm_data_buffer,225);
uint16_t index;
nrf_delay_ms(5);
// for( index=0; index < 102400; index++ )
for( index=0; index < 225; index++ )
// Read data one byte at a time
printf("\r\n%2.2X%2.2X",pcm_data_buffer[index],pcm_data_buffer[index+1]);
index = index+1;
flash_address = flash_address + 0x000100;
// counter ++;
// uint32_t flash_address = FLASH_TARGET_ADDR;
//// cmd_read(flash_address,pcm_data_buffer,102400);
// cmd_read(flash_address,pcm_data_buffer,3584); //256*16 3584 bytes
// for( index=0; index < MEM_SIZE_15KB; index++ )
// // Read data one byte at a time
// printf("\r\n%2.2X%2.2X",pcm_data_buffer[index],pcm_data_buffer[index+1]);
// index = index+1;
//// // Read data one byte at a time
// printf("\r\n%2.2X%",pcm_data_buffer[index]);
// index = index+1;
* Function: Wait_Flash_WarmUp
* Arguments: None.
* Description: Wait some time until flash read / write enable.
* Return Message: None.
void wait_flash_warm_up()
uint32_t time_cnt = FlashFullAccessTime;
while( time_cnt > 0 )
time_cnt--;
uint8_t flash_ID_test( uint8_t id )
uint8_t instruction[8] = {0};
uint8_t id_read = id;
switch (id_read)
case 1:
instruction[0] = FLASH_CMD_RES ;
instruction[1]= 0x00;
instruction[2] = 0x00;
instruction[3]= 0x00;
cs_low();
nrf_delay_ms(1);
printf("\rValue is 1:");
printf("%02x \n",m_buffer_rx[4]);
cs_high();
case 2:
instruction[0] = FLASH_CMD_REMS ;
instruction[1]= 0x01;
instruction[2] = 0x02;
printf("\rValue is 2:");
memset(m_buffer_rx,0x00,sizeof(m_buffer_rx));
nrf_delay_ms(2);
printf("%02x,%02x,%02x,%02x,%02x,%02x\n",m_buffer_rx[0],m_buffer_rx[1],m_buffer_rx[2],m_buffer_rx[3],m_buffer_rx[4],m_buffer_rx[5]);
// printf("%d,%d,%d,%d,%d,%d\n",m_buffer_rx[0],m_buffer_rx[1],m_buffer_rx[2],m_buffer_rx[3],m_buffer_rx[4],m_buffer_rx[5]);
case 3:
m_buffer_tx[0] = FLASH_CMD_RDID;
cs_low();
nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,1,m_buffer_rx,4);
nrf_delay_ms(2);
printf("\rValue is 3:");
printf("%02x,%02x,%02x\n",m_buffer_rx[1],m_buffer_rx[2],m_buffer_rx[3]);
// printf("%d,%d,%d \n",m_buffer_rx[1],m_buffer_rx[2],m_buffer_rx[3]);
cs_high();
printf("Out of range");
return true;
ReturnMsg cmd_rdsr( uint8_t *StatusReg )
cs_low();
// Send command
nrf_drv_spi_transfer(&spi,FLASH_CMD_RDSR,1,gDataBuffer,1);
cs_high();
*StatusReg = gDataBuffer;
// printf("cmd_rdsr = %d \n",gDataBuffer);
ReturnMsg cmd_rdcr( uint8_t *StatusReg )
cs_low();
// Send command
// SendByte( FLASH_CMD_RDSR, SIO );
// gDataBuffer = GetByte( SIO );
nrf_drv_spi_transfer(&spi,FLASH_CMD_RDCR,1,gDataBuffer,1);
cs_high();
// printf("status register = %x \n",StatusReg);
bool IsFlashBusy( void )
cmd_rdsr( &gDataBuffer );
if( (gDataBuffer & FLASH_WIP_MASK) == FLASH_WIP_MASK )
return true;
return false;
bool WaitFlashReady( uint32_t ExpectTime )
uint32_t temp = 0;
while( IsFlashBusy() )
if( temp > ExpectTime )
return false;
temp = temp + 1;
return true;
ReturnMsg cmd_wren( void )
// cs_low();
// Write Enable command = 0x06, Setting Write Enable Latch Bit
uint8_t instruction = FLASH_CMD_WREN;
nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,1,m_buffer_rx,0);
// cs_high();
ReturnMsg cmd_wrdis( void )
cs_low();
uint8_t instruction = FLASH_CMD_WRDI;
cs_high();
ReturnMsg cmd_pp( uint32_t flash_address, uint16_t *source_address, uint32_t byte_length )
// printf("cmd_pp \n");
uint32_t index;
if( flash_address > FLASH_SIZE ) return FlashAddressInvalid;
nrf_delay_ms(10);
cs_low();
cmd_wren();
nrf_delay_ms(3);
// Write Page Program command
uint8_t len = 4;
m_buffer_tx[0]=FLASH_CMD_PP;
// memcpy(m_buffer_tx,instruction,4);
// nrf_drv_spi_transfer(&spi,instruction,len,m_buffer_rx,len+1);
memcpy(m_buffer_tx[4],flash_address >> 16,1);
for( index=4; index < byte_length; index++ )
m_buffer_tx[index] = (uint8_t) source_address[index];//0xaa;
printf("\r data transmitted: ");
for( index=0; index < 30; index++ )
printf(" %.02x ",m_buffer_tx[index]);
nrf_delay_ms(10);
printf("\n");
// nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,20,m_data_receive,0);
nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,251,m_data_receive,0);
nrf_delay_ms(50);
cs_high();
nrf_delay_ms(20);
if( WaitFlashReady( PageProgramCycleTime ) )
uint8_t cmd_se( uint32_t flash_address )
cs_low();
cmd_wren();
nrf_delay_ms(3);
//Write Sector Erase command = 0x20;
m_buffer_tx[0] = FLASH_CMD_SE;
// printf(" \r sectore esrase command : %0.2x,%0.2x,%0.2x,%0.2x\n ",m_buffer_tx[0],m_buffer_tx[1],m_buffer_tx[2],m_buffer_tx[3]);
nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,4,m_buffer_rx,0);
nrf_delay_ms(50);
cs_high();
nrf_delay_ms(240);
printf("sector esrsed \n");
// if( WaitFlashReady( SectorEraseCycleTime ) )
// if( WaitFlashReady( 240000000 ))
// cmd_rdsr(StatusReg);
// else
uint8_t cmd_block_erase( uint32_t flash_address )
cs_low();
cmd_wren();
nrf_delay_ms(3);
instruction= FLASH_CMD_BE;
// instruction[1]= 0;
// instruction[2] =0;
// instruction[3]=0;
// SendByte( FLASH_CMD_SE, SIO );
// SendFlashAddr( flash_address, SIO, addr_4byte_mode );
nrf_delay_ms(100);
cs_high();
nrf_delay_ms(4000);
printf("block earsed \n");
// else
* Function: CMD_CE
* Arguments: None.
* Description: The CE instruction is for erasing the data
* of the whole chip to be "1".
* Return Message: FlashIsBusy, FlashOperationSuccess, FlashTimeOut
ReturnMsg cmd_ce( void )
cs_low();
cmd_wren();
nrf_delay_ms(3);
//Write Chip Erase command = 0x60;
m_buffer_tx[0] = 0xC7;//FLASH_CMD_CE;
nrf_delay_ms(100);
cs_high();
// printf("StatusReg= %d \n",StatusReg);
//if( WaitFlashReady( 60000 ) )
nrf_delay_ms(60000);
printf("chip esrsed \n");
// else
//return FlashOperationSuccess;
ReturnMsg full_sector_erase(void)
uint8_t i=0;
for(i=0;i<5;i++)
cmd_se(flash_address);
nrf_delay_ms(240);
flash_address = flash_address + FLASH_SECTORSIZE;
* Simple flash read/write test
uint8_t flash_read_write_test( void )
uint8_t message= 0;
FlashStatus flash_state = {0};
uint32_t flash_addr;
uint32_t trans_len = 0;
uint16_t i=0, error_cnt = 0;
uint16_t seed = 0;
uint8_t st_reg = 0;
/* Assign initial condition */
flash_addr = FLASH_TARGET_ADDR;
trans_len = TRANS_LENGTH;
seed = RANDOM_SEED;
/* Erase 4K sector of flash memory
Note: It needs to erase dirty sector before program */
uint8_t err_code;
// err_code = cmd_se( flash_addr ); //cmd_ce();//cmd_block_erase(flash_addr);//cmd_se( flash_addr );
// printf("error code = %d \n",err_code);
// nrf_delay_ms(300);
// cmd_read( flash_addr, m_data_receive, TRANS_LENGTH );
// printf("\r data after chip erase: ");
// for( i=4; i < 20; i++ )
// printf(" %.02x ",m_data_receive[i]);
// printf("\n");
/* Program data to flash memory */
// cmd_pp( flash_addr, m_data_send,256 ); //TRANS_LENGTH
// nrf_delay_ms(500);
/* Read flash memory data to memory buffer */
// cmd_read( flash_addr, m_data_receive, 256 ); //TRANS_LENGTH
/* Compare original data and flash data */
// for( i=4; i < (trans_len); i=i+1 )
// if( m_data_send[i] != m_data_receive[i] )
// printf("wrong data \n");
// Error_inc( error_cnt );
// else
printf("\r data received: ");
for( i=4; i < 256; i++ )
nrf_delay_ms(10);
printf("\n");
/* Erase 4K sector of flash memory */
// cmd_se( flash_addr ); //cmd_ce();//cmd_block_erase(flash_addr); //
// nrf_delay_ms(240); //240 60000
if( error_cnt != 0 )
return false;
return true;
uint8_t ext_flash_init(void)
uint8_t retval = false;
/* Configure SPI pins */
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = SPI_SS_PIN;
spi_config.miso_pin = SPI_MISO_PIN;
spi_config.mosi_pin = SPI_MOSI_PIN;
spi_config.sck_pin = SPI_SCK_PIN;
spi_config.mode = NRF_DRV_SPI_MODE_0;
spi_config.frequency= NRF_DRV_SPI_FREQ_125K;
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
nrf_gpio_pin_set(SPI_WP_PIN);
uint8_t err_code;
cmd_rsten();
cmd_rst();
err_code = cmd_wrdis();
/* Set CS pin to High*/
// cs_high();
wait_flash_warm_up();
nrf_delay_ms(100);
flash_ID_test(3);
/* read and verify manufacturer and device id from external flash to ensure external flash is working */
if(flash_ID_test(3) == true)
// flash_read_write_test();
// return true;
// cmd_wren();
// cmd_wrsr(2);
// cmd_rdcr(ConfigReg);
//nrf_delay_ms(500);
////cmd_ce();
//// cmd_se(0x000000);
//// nrf_delay_ms(500);
//printf("finish \n");
// cmd_read( 0x000000, m_data_receive, TRANS_LENGTH );
// uint8_t i;
// printf("\r data after chip erase at 0x000000: ");
// printf("\n");
// cmd_se(0x008000);
// cmd_read( 0x008000, m_data_receive, TRANS_LENGTH );
// printf("\r data after chip erase at 0x008000: ");
// printf("\n");
return retval;
Hi
Thanks. Adding those files I realize that ext_flash.h is also missing ;)
Either way, I will start doing some testing on my own in the mean time, and set up a quick test based on the ble_app_uart example.
Getting 3-4 of the core functions running should not be very time consuming.
Best regards
Torbjørn
