Is there a way to create a command that gets throughput information from a device in the ble_app_interactive example? I want to get the throughput of a peripheral device once it is connected.
Do you want to measure throughput for transmit or receive? You may create a new repeated timer instance with the app timer library included in the example and count the number of received/transmitted bytes per time unit. It might be easier than trying to port code from the throughput example.
Vidar,
Thank you for your reply! I am now printing the rssi value of peripheral devices in the device display command in the command-line interface. I would like to print the throughput value next to the rssi value to receive.
I understand that the devices will probably need to be connected in order to read the throughput, so should I move the rssi print to another spot with the throughput? Can I incorporate the app timer library in with the cli example?
You need to be connected to measure throughput, as you said. You also have to explicitly enable RSSI sampling to get RSSI samples while connected, unlike scan mode (RSSI get sample / RSSI for connections with event filter).
The app timer is already included in the project so that you can easily create a new timer instance. I used the same approach to measure throughput with the ble_app_uart example for another case. Including the code here in case it helps.
* Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "Nord_UART" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(15, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 10 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(6000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
APP_TIMER_DEF(m_throughput_timer_id);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
static int m_tot_num_bytes;
void throughput_timeout_handler (void * p_context)
static int last_recv_byte_cnt;
NRF_LOG_INFO("%d kbps", (m_tot_num_bytes-last_recv_byte_cnt) >> 7);
last_recv_byte_cnt = m_tot_num_bytes;
static void application_timer_start()
uint32_t err_code;
err_code = app_timer_start(m_throughput_timer_id, APP_TIMER_TICKS(1000), NULL);
/**@brief Function for initializing the timer module.
static void timers_init(void)
err_code = app_timer_create(&m_throughput_timer_id,
APP_TIMER_MODE_REPEATED,
throughput_timeout_handler);
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
uint32_t err_code;
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
do
err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
} while (err_code == NRF_ERROR_BUSY);
if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
uint32_t err_code;
ble_nus_init_t nus_init;
// Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
NRF_LOG_INFO("Disconnected");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// Pairing not supported
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
ret_code_t err_code;
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
do
if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
(err_code != NRF_ERROR_NOT_FOUND) )
index = 0;
case APP_UART_FIFO_ERROR:
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
/*init.srdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.srdata.uuids_complete.p_uuids = m_adv_uuids;*/
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
nrf_pwr_mgmt_run();
static void send_data()
uint32_t err_code;
uint16_t length = m_ble_nus_max_data_len;
if (err_code == NRF_SUCCESS)
m_tot_num_bytes += length;
/**@brief Application main function.
bool erase_bonds;
// Initialize.
uart_init();
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
application_timer_start();
// Start execution.
advertising_start();
// Enter main loop.
for (;;)
send_data();
idle_state_handle();
Thanks so much, Vidar! This helps Where should I go to enable RSSI sampling while connected using the throughput example? I want the RSSI, from one semiconductor to the other, to print out underneath the final throughput value.
Glad you found it helpful:) You can call sd_ble_gap_rssi_start() when the connection has been established to enable RSSI sampling, but keep in mind that the RSSI can vary a lot between packets so I think it would make sense to print out an average RSSI value underneath the final throughput number.
