Behavior of 2 concurrent peripheral links
I would like to clear some of my confusion on multi peripheral links behavior.
My context: SDK 15.2/SD610 on 3 52840 nodes.
I am using multiple peripheral links feature of SDK, 1x52840 as peripheral and 2x52840 as centrals. Each Central connects to the single peripheral directly.
On both central nodes I set connection interval to 15ms, and gap event length to 6units(7.5ms). The same setting also applies to the peripheral node. It is expected that in one connection interval that 2 packets can be sent per link.
The question is, can this peripheral node send 1 packet to each of the connected central node within one connection interval(15ms)?
I kinda of think this is not possible as according to what connection interval is defined, each central node has its own timing and anchor point when connection event is open, this may results in conflicts in peripheral node. So the peripheral can only send 1 packet in one interval and wait till this event is closed it can then starts sending next packet to another node. In other word, the expected throughput of this peripheral node can not be achieved by using the settings above.
Not sure if I understand this correctly. Can you help to clarify the exact behavior of soft device in this case?
Thank you.
  • I tried to find some in blue spec, and in v4.2 it does mentioned:
    Slaves are permitted to have physical links to more than one master at a time.
    However, I can not find more details about the exact timing on slave node and the indication of performance. But the following statement in spec is interesting and may suggest something:
    Slave initiated anchor point move
    the Link Layer of the slave requesting a change in the anchor points of the LE connection
    It looks that on slave node it does have a chance to synchronize all perisperhal links connection event by initiate a anchor point move request. So in the end it becomes a scheduling problem on peripheral node, that wether a peripheral node can send 1 packet to each of central nodes in one connection interval.
    However I did not find much related to this topic on S140 SDS scheduling chapter. So still wondering if this is possible in 840 soft device.
    any suggestions about this question?
    thanks a lot.
  • I think it should be possible to send a packet to each central within 15ms. The connection interval is the interval between the start of each connection event. If you have one packet to send, then at the start of the connection event the packet will be sent, and if there is nothing else to be sent, the connection event is closed(in total is should only take a few ms). The next upcoming event is then the start of the connection event for your link number 2. The maximum time spent in the connection event is the gap event length that you set.
  • Thank you  for the hint. I think i basically got the idea.
    2 more related issues would like to confirm:
    1) in SDS scheduling chapter it is recommended that the connection interval should be set to:
    • ∑tevent-Cx + (tScanReserved + ScanWindow) + tSlaveEventNominal + tAdvEventMax
    In my case the scanning and advertising are all stopped after connection established. Will it be OK if i skip the scaning and adv parts in above formula in this case?
    2) During test i found the scanner failed to discover advertising peripheral node quite often, and sometimes failed to connect due to peer disconnected. The scanning window is set to 80 units and interval is 160 units. Is there any way to improve it?
  • 1)
     Yes. Also see this post
    2) How many devices were you already connected to in this scenario? 15 ms connection interval? What was the advertising interval for the advertising device ?
