I can't get USBD messages with a SoftDevice 140 on my nRF52840 Dongle
I have the ble_peripheral blinky example running, and I have a separate project with the USBD working fine (based on the usbd_cdc_acm example), but when I try to merge the two together, the app_usbd_init causes a crash.  Is it not possible?  What am I doing wrong?
Thanks in advance.  I've attached my usbd_out source file.
--jeff
#include "app_usbd.h"
#include "app_usbd_cdc_acm.h"
#include "app_usbd_serial_num.h"
//#include "app_usbd_string_desc.h"
#include "boards.h"
#include "nrf_drv_clock.h"
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
#define CDC_ACM_COMM_INTERFACE  0
#define CDC_ACM_COMM_EPIN       NRF_DRV_USBD_EPIN2
#define CDC_ACM_DATA_INTERFACE  1
#define CDC_ACM_DATA_EPIN       NRF_DRV_USBD_EPIN1
#define CDC_ACM_DATA_EPOUT      NRF_DRV_USBD_EPOUT1
#define READ_SIZE 1
static char m_rx_buffer[READ_SIZE];
static char m_tx_buffer[NRF_DRV_USBD_EPSIZE];
static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst, app_usbd_cdc_acm_user_event_t event);
static void usbd_user_ev_handler(app_usbd_event_type_t event);
 * @brief CDC_ACM class instance
APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
                            cdc_acm_user_ev_handler,
                            CDC_ACM_COMM_INTERFACE,
                            CDC_ACM_DATA_INTERFACE,
                            CDC_ACM_COMM_EPIN,
                            CDC_ACM_DATA_EPIN,
                            CDC_ACM_DATA_EPOUT,
                            //APP_USBD_CDC_COMM_PROTOCOL_AT_V250
                            APP_USBD_CDC_COMM_PROTOCOL_NONE
typedef struct serial_command_hdr
    zb_uint16_t size;
    zb_uint8_t command; // serial_command_t
} serial_command_hdr_t;
static void serial_reset()
    serial_command_hdr_t rts;
    rts.size    = 0xC0C0;
    rts.command = SERIAL_CMD_INVALID;
    app_usbd_cdc_acm_write(&serial_uart, &rts, sizeof(rts) );
    app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
    switch (event)
        case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
 //           bsp_board_led_on(LED_CDC_ACM_OPEN);
            /*Setup first transfer*/
            ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
                                                   m_rx_buffer,
                                                   READ_SIZE);
            UNUSED_VARIABLE(ret);
        case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
 //           bsp_board_led_off(LED_CDC_ACM_OPEN);
        case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
 //           bsp_board_led_invert(LED_CDC_ACM_TX);
        case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
            ret_code_t ret;
 //           NRF_LOG_INFO("Bytes waiting: %d", app_usbd_cdc_acm_bytes_stored(p_cdc_acm));
            do
                /*Get amount of data transfered*/
                size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
 //               NRF_LOG_INFO("RX: size: %lu char: %c", size, m_rx_buffer[0]);
                /* Fetch data until internal buffer is empty */
                                            m_rx_buffer,
                                            READ_SIZE);
            } while (ret == NRF_SUCCESS);
 //           bsp_board_led_invert(LED_CDC_ACM_RX);
    switch (event)
        case APP_USBD_EVT_DRV_SUSPEND:
 //           PRINT("USB_RESUME\n",NULL);
        case APP_USBD_EVT_DRV_RESUME:
        case APP_USBD_EVT_STARTED:
        case APP_USBD_EVT_STOPPED:
            app_usbd_disable();
 //           bsp_board_leds_off();
        case APP_USBD_EVT_POWER_DETECTED:
 //           PRINT("USB power detected\n",NULL);
            if (!nrf_drv_usbd_is_enabled())
                app_usbd_enable();
        case APP_USBD_EVT_POWER_REMOVED:
 //           PRINT("USB power removed\n",NULL);
            app_usbd_stop();
        case APP_USBD_EVT_POWER_READY:
//            PRINT("USB ready\n",NULL);
            app_usbd_start();
//            PRINT("USB unhandled event:%x\n", event);
void usbd_message(char *msg)
#ifdef NotNow
    size_t size = sprintf(m_tx_buffer, msg);
    app_usbd_cdc_acm_write(&m_app_cdc_acm, m_tx_buffer, size);
void serial_init()
    ret_code_t ret;
    bsp_board_led_on(BSP_BOARD_LED_3);
    static const app_usbd_config_t usbd_config = {
        .ev_state_proc = usbd_user_ev_handler
    ret = nrf_drv_clock_init();
 //   APP_ERROR_CHECK(ret);
    bsp_board_led_on(BSP_BOARD_LED_2);
    while(!nrf_drv_clock_lfclk_is_running())
        /* Just waiting */
    bsp_board_led_on(BSP_BOARD_LED_1);
    app_usbd_serial_num_generate();
    ret = app_usbd_init(&usbd_config);
    bsp_board_led_on(BSP_BOARD_LED_0);
 return;
    app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
    ret = app_usbd_class_append(class_cdc_acm);
//    EVT_LOG("USBD CDC ACM example started.\n", NULL);
    if (USBD_POWER_DETECTION)
        ret = app_usbd_power_events_enable();
 //       EVT_LOG("No USB power detection enabled\nStarting USB now\n", NULL);
        app_usbd_enable();
        app_usbd_start();
