Simple_On_Off_Model callbacks are called multiple times each message
so I witnessed this weird phenomenon:
When I use the simple On-Off-Model (as a base for a custom vendor model) in the switch application, the handle_set function in simple on_off_server. and therefore the callback function in main.c are called tree times.
As far as my guesses go, this is caused by the access layer calling the handle multiple times, but I'm really not sure.
Debugging didn't quite help yet, since the debugger exits the c-code after the callback function and does not return to the previous function that has called the handler in the first place.
This is not a crucial error, but still it would be quite interesting to know what is causing this behavior.
I'm currently still using the v3.1 of the mesh SDK.
Thank you,
Heiner
  • Hi.
    Can't see by first look what is causing this.
    I'll closer into it and discuss with our Mesh developers what might be causing this.
    Joakim
  • Hi.
    Talked to one of my colleagues about this.
    The reason that the command is sent three times is could be because you don't reply to the client. The client expects that the set command is ACKED, otherwise it will retry 3 times.
    You could try to use set_unack instead, that way the client won't retry three times when it doesn't receive an ACK.
    Cheers,
    Joakim
  • Hi Joakim,
    this is weird, because I actually used simple_on_off_client_set_unreliable for my messages.
    The differences I could find so far, where that simple_on_off_client_set_unreliable uses an argument called repeats.
    It would make sense if that is the cause, because repeats is set to 2. However if I set the repeat counter to 0 I cannot seem to transmit any message. (When I set repeats to 1 the handler is called two times instead of tree times.)
    From my point of view the function handle_set_unreliable_cb, unlike handle_set_cb, does not send a reply status to the access_model.
    Which makes sense, since it's set unacknowledged.
    But this leaves me with new questions, like:
    How can I set simple_on_off_client_set_unreliable to send the message only once?
    Or is there maybe something that needs to be acknowledged with handle_set_unreliable_cb (at least on a lower level)?
    It would be great if you could look into that again.
    Best,
    Heiner
  • Ok, then I don' think it's related to my previous answer.
    When you added the simple on-off model, did you follow our guide in the infocenter?
    (Creating new models)
    Could it be possible for you to upload your project so that I can look at your code?
    If you don't want to share your code in the public forum, we can turn the ticket private first.
    Joakim
  • Hi Joakim,
    I followed your guide and tried to stick as close as possible to it.
    There aren't too many changes, at least not yet. So I think it should be fine if we leave it in the public forum for now.
    As mentioned I used your simple_on_off model as a base for my code.
    model common.h
    /* Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
     * list of conditions and the following disclaimer.
    #ifndef SIMPLE_ON_OFF_COMMON_H__
    #define SIMPLE_ON_OFF_COMMON_H__
    #include <stdint.h>
    #include "access.h"
     * @defgroup SIMPLE_ON_OFF_MODEL Simple OnOff model
     * This model implements the message based interface required to
     * set the 1 bit value on the server.
     * This implementation of a simple OnOff model can be used to switch things
     * on or off by manipulating a single on/off state. The intention of this model
     * is to have a simple example model that can be used as a baseline for constructing
     * your own model.
     * Do not confuse the simple OnOff model with the Generic OnOff Model specified
     * in the Mesh Model Specification v1.0. The Generic OnOff Model provides additional
     * features such as control over when and for how long the transition between
     * the on/off state should be performed.
     * @note When the server has a publish address set (as in the light switch example),
     * the server will publish its state to its publish address every time its state changes.
     * For more information about creating models, see
     * @ref md_doc_getting_started_how_to_models.
     * Model Identification
     * @par
     * Company ID: @ref SIMPLE_ON_OFF_COMPANY_ID
     * @par
     * Simple OnOff Client Model ID: @ref SIMPLE_ON_OFF_CLIENT_MODEL_ID
     * @par
     * Simple OnOff Server Model ID: @ref SIMPLE_ON_OFF_SERVER_MODEL_ID
     * List of supported messages:
     * @par
     * @copydoc SIMPLE_ON_OFF_OPCODE_SET
     * @par
     * @copydoc SIMPLE_ON_OFF_OPCODE_GET
     * @par
     * @copydoc SIMPLE_ON_OFF_OPCODE_SET_UNRELIABLE
     * @par
     * @copydoc SIMPLE_ON_OFF_OPCODE_STATUS
     * @ingroup MESH_API_GROUP_VENDOR_MODELS
     * @defgroup SIMPLE_ON_OFF_COMMON Common Simple OnOff definitions
     * Types and definitions shared between the two Simple OnOff models.
    /** Vendor specific company ID for Simple OnOff model */
    #define SIMPLE_ON_OFF_COMPANY_ID    (ACCESS_COMPANY_ID_NORDIC)
    /** Simple OnOff opcodes. */
    typedef enum
        SIMPLE_ON_OFF_OPCODE_SET = 0xC1,            /**< Simple OnOff Acknowledged Set. */
        SIMPLE_ON_OFF_OPCODE_GET = 0xC2,            /**< Simple OnOff Get. */
        SIMPLE_ON_OFF_OPCODE_SET_UNRELIABLE = 0xC3, /**< Simple OnOff Set Unreliable. */
        SIMPLE_ON_OFF_OPCODE_STATUS = 0xC4,         /**< Simple OnOff Status. */
    	SIMPLE_ON_OFF_OPCODE_SET_FRIEND = 0xC5,		/** Heiner Set Adress of Friend Node */
    } simple_on_off_opcode_t;
    /** Message format for the Simple OnOff Set message. */
    typedef struct __attribute((packed))
        uint8_t state; /** Heiner: State 1 */
    		/** Heiner: State 2 hier hinzufügen*/
        uint8_t tid;    /**< Transaction number. */
    } simple_on_off_msg_set_t;
    /** Message format for th Simple OnOff Set Unreliable message. */
    } simple_on_off_msg_set_unreliable_t;
    /** Message format for the Simple OnOff Status message. */
        uint8_t present_state; /**< Current state. */ // Heiner
    } simple_on_off_msg_status_t;
    //** Heiner: format for Simple OnOff Friend message */
        uint16_t address; /** Heiner: Adresse des FRND Knoten */
    } simple_on_off_msg_set_friend_t;
    /** @} end of SIMPLE_ON_OFF_COMMON */
    /** @} end of SIMPLE_ON_OFF_MODEL */
    #endif /* SIMPLE_ON_OFF_COMMON_H__ */
    model server.c
    #include "simple_on_off_server.h"
    #include "simple_on_off_common.h"
    #include <stdint.h>
    #include <stddef.h>
    #include "access.h"
    #include "nrf_mesh_assert.h"
    #include "log.h"
     * Static functions
    static void reply_status(const simple_on_off_server_t * p_server,
                             const access_message_rx_t * p_message,
    //                         bool present_on_off)
                             uint8_t present_state)
        simple_on_off_msg_status_t status;
    //    status.present_on_off = present_on_off ? 1 : 0;
        status.present_state; // Heiner
        access_message_tx_t reply;
        reply.opcode.opcode = SIMPLE_ON_OFF_OPCODE_STATUS;
        reply.opcode.company_id = SIMPLE_ON_OFF_COMPANY_ID;
        reply.p_buffer = (const uint8_t *) &status;
        reply.length = sizeof(status);
        reply.force_segmented = false;
        reply.transmic_size = NRF_MESH_TRANSMIC_SIZE_DEFAULT;
        reply.access_token = nrf_mesh_unique_token_get();
        (void) access_model_reply(p_server->model_handle, p_message, &reply);
     * Opcode handler callbacks
    static void handle_set_cb(access_model_handle_t handle, const access_message_rx_t * p_message, void * p_args)
        simple_on_off_server_t * p_server = p_args;
        NRF_MESH_ASSERT(p_server->set_cb != NULL);
        // bool value = (((simple_on_off_msg_set_t*) p_message->p_data)->on_off) > 0;
        uint8_t value = (((simple_on_off_msg_set_t*) p_message->p_data)->state);//Heiner value -> uint8
        value = p_server->set_cb(p_server, value);
        reply_status(p_server, p_message, value);
        (void) simple_on_off_server_status_publish(p_server, value); /* We don't care about status */
    static void handle_get_cb(access_model_handle_t handle, const access_message_rx_t * p_message, void * p_args)
        NRF_MESH_ASSERT(p_server->get_cb != NULL);
        reply_status(p_server, p_message, p_server->get_cb(p_server));
    static void handle_set_unreliable_cb(access_model_handle_t handle, const access_message_rx_t * p_message, void * p_args)
    //    bool value = (((simple_on_off_msg_set_unreliable_t*) p_message->p_data)->on_off) > 0;
    	uint8_t value = (((simple_on_off_msg_set_unreliable_t*) p_message->p_data)->state);//Heiner value -> uint8
    // Heiner
    static void handle_set_friend_cb(access_model_handle_t handle, const access_message_rx_t * p_message, void * p_args)
        NRF_MESH_ASSERT(p_server->friend_cb != NULL);
    	uint16_t value = (((simple_on_off_msg_set_friend_t*) p_message->p_data)->address);
        value = p_server->friend_cb(p_server, value);
        //(void) simple_on_off_server_status_publish(p_server, value); // Heiner publish Friend Adress if necessary
    static const access_opcode_handler_t m_opcode_handlers[] =
        {ACCESS_OPCODE_VENDOR(SIMPLE_ON_OFF_OPCODE_SET,            SIMPLE_ON_OFF_COMPANY_ID), handle_set_cb},
        {ACCESS_OPCODE_VENDOR(SIMPLE_ON_OFF_OPCODE_GET,            SIMPLE_ON_OFF_COMPANY_ID), handle_get_cb},
        {ACCESS_OPCODE_VENDOR(SIMPLE_ON_OFF_OPCODE_SET_UNRELIABLE, SIMPLE_ON_OFF_COMPANY_ID), handle_set_unreliable_cb},
        {ACCESS_OPCODE_VENDOR(SIMPLE_ON_OFF_OPCODE_SET_FRIEND,     SIMPLE_ON_OFF_COMPANY_ID), handle_set_friend_cb}
     * Public API
    uint32_t simple_on_off_server_init(simple_on_off_server_t * p_server, uint16_t element_index)
        if (p_server == NULL ||
            p_server->get_cb == NULL ||
            p_server->set_cb == NULL)
            return NRF_ERROR_NULL;
        access_model_add_params_t init_params;
        init_params.element_index =  element_index;
        init_params.model_id.model_id = SIMPLE_ON_OFF_SERVER_MODEL_ID;
        init_params.model_id.company_id = SIMPLE_ON_OFF_COMPANY_ID;
        init_params.p_opcode_handlers = &m_opcode_handlers[0];
        init_params.opcode_count = sizeof(m_opcode_handlers) / sizeof(m_opcode_handlers[0]);
        init_params.p_args = p_server;
        init_params.publish_timeout_cb = NULL;
        return access_model_add(&init_params, &p_server->model_handle);
    uint32_t simple_on_off_server_status_publish(simple_on_off_server_t * p_server, uint8_t value)
    //    status.present_on_off = value ? 1 : 0;
        status.present_state = value; // Heiner
        access_message_tx_t msg;
        msg.opcode.opcode = SIMPLE_ON_OFF_OPCODE_STATUS;
        msg.opcode.company_id = SIMPLE_ON_OFF_COMPANY_ID;
        msg.p_buffer = (const uint8_t *) &status;
        msg.length = sizeof(status);
        msg.force_segmented = false;
        msg.transmic_size = NRF_MESH_TRANSMIC_SIZE_DEFAULT;
        msg.access_token = nrf_mesh_unique_token_get();
        return access_model_publish(p_server->model_handle, &msg);
    While uploading the code I took a closer look at the set_unreliable function from server.c
    uint32_t simple_on_off_client_set_unreliable(simple_on_off_client_t * p_client, uint8_t state, uint8_t repeats) // Heiner
        simple_on_off_msg_set_unreliable_t set_unreliable;
    //    set_unreliable.on_off = on_off ? 1 : 0;
        set_unreliable.state = state; // Heiner
        set_unreliable.tid = m_tid++;
        access_message_tx_t message;
        message.opcode.opcode = SIMPLE_ON_OFF_OPCODE_SET_UNRELIABLE;
        message.opcode.company_id = SIMPLE_ON_OFF_COMPANY_ID;
        message.p_buffer = (const uint8_t*) &set_unreliable;
        message.length = sizeof(set_unreliable);
        message.force_segmented = false;
        message.transmic_size = NRF_MESH_TRANSMIC_SIZE_DEFAULT;
        uint32_t status = NRF_SUCCESS;
        for (uint8_t i = 0; i < repeats; ++i)
            message.access_token = nrf_mesh_unique_token_get();
            status = access_model_publish(p_client->model_handle, &message);
            if (status != NRF_SUCCESS)
        return status;
    This explains why I couldn't get any message through before.
    However if set the repeat counter to 1 the message should be transmitted just once, but the callback is still being called twice. So the root of the problem must be somewhere else.
    Best,
    Heiner
