I test ancs when connect second iphone Will appear p_file_name: 0x20001c08 "src \ gap_core.c" ,This is what causes?
Hi all,
I use nRF51822, nrf51_sdk_v5_2_0_39364 and s110_nrf51822_6.0.0.Test ANCS, first with the iPhone connection is no problem. When I disconnect, connect a second iphone, will appear this error error_code: 0xDEADBEEF, line_num:0x000005c1,p_file_name: 0x20001c08 "src \ gap_core.c" I do not know why.? I use ble_bondmngr_cfg.h code:
  /**@brief Number of CCCDs used in the Apple Notification Center Client application. */
  #define BLE_BONDMNGR_CCCD_COUNT           5
 /**@brief Maximum number of bonded masters. */
 #define BLE_BONDMNGR_MAX_BONDED_CENTRALS  2
main.c  code:
1470 line       switch (p_ble_evt->header.evt_id)
1471 line        {
1472 line               case BLE_GAP_EVT_CONNECTED:
1473 line
1474 line              //              err_code = app_button_enable();
1475 line            // 		APP_ERROR_CHECK(err_code);
1476	line
1477 line              m_advertising_mode = BLE_NO_ADVERTISING;
1478  line              m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
1479	line
1480	line	           display_wcfalg=1;
1481	line	          err_code = app_timer_start(m_firstcon_timer_id, FIRSTCON_INTERVAL, NULL);
1482	line
1483  line              APP_ERROR_CHECK(err_code);
1484  line             break;
1485  line    case BLE_GAP_EVT_CONN_PARAM_UPDATE:
1486  line   case BLE_GAP_EVT_AUTH_STATUS:
1487  line        apple_notification_setup();
1488  line        break;
Hope to get your help!
Edit: FORMAT
