In my bootloader I'm using sd_flash_page_erase() directly without pstorage.
The flash erase performance is exceedingly slow. It is taking 13.187 seconds to erase 132 pages or 99.9ms/page (does that have any significance). I'm using sd7.1.0 on a week old 51822QFAC. The datasheet claims 22.3ms worst case, is there really that much overhead in erasing with the softdevice?
While erasing the system should be fairly idle, except for the 7.5-30ms connection interval (not sure what ble_dfu.py is setting it to). The next erase is triggered directly from the system event and I have tried with both the scheduler enabled and disabled.
The data receive and flash write performance isn't horrible. Using ble_dfu.py with RCPT_NOTIF not enabled, I'm receiving 132K in 31.2s (34718bps) with never more then 100 bytes of flash writes pending. As a result, the erase time represents a significant portion of the upgrade time. The best part is this is on a board without an antenna, just a trace and a non-populated ceramic antenna (part hadn't arrived when the board was assembled). For my application, DFU performance is critical because I'm also using it to upgrade an external 2MB SPI flash, so hopefully there is more room to increase the BLE performance.
Any ideas where to look for the source of the slow erase?
EDIT: Additional info. The problem is caused by the connection interval, the performance I was seeing above was at 20ms, I can't imagine how bad it is at 7.5ms. At 90ms the erase took 3.94s, which is much more reasonable, but this is with android, it seems the python dfu/MasterEmulator ignores the connection parameter requests, I never get the response event.
The erase may be faster on android (lollipop), but the download is painful, with a 18.75ms interval and 20pkts/notif I'm only getting 7789bps, with a somewhat modifed python script at 20ms I get 46856bps.
If I ever have to upgrade my full 2MB external flash (ouch) it would take 6min with the python script, but 36min with the current performance I'm seeing with android. Ouch!
