[nRF52840][usbd_hid_composite] How to send data to Control EP in Linux?
Hello Nordic experts,
I am doing SDK 15.3.0 usbd_hid_composite example and this is where I am: https://devzone.nordicsemi.com/f/nordic-q-a/50447/nrf52840-usbd_hid_composite-how-does-windows-transmit-caps-lock-state-to-the-device-without-output-endpoint/201751. I want to modified the code so that I can control the output letter from "g" to any letter by changing the output report/control EP(EP 0). I have done the Nordic nRF52840 side code, but I do not know how to send the data from Ubuntu to the output report or control EP. So my question is how do I send data to the Control EP in Linux so that I can change the default output letter "g" to other letter?
Modified code:
 * Copyright (c) 2017 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include "nrf.h"
#include "nrf_drv_usbd.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_drv_power.h"
#include "app_timer.h"
#include "app_usbd.h"
#include "app_usbd_core.h"
#include "app_usbd_hid_mouse.h"
#include "app_usbd_hid_kbd.h"
#include "app_usbd_dummy.h"
#include "app_error.h"
#include "bsp.h"
#include "bsp_cli.h"
#include "nrf_cli.h"
#include "nrf_cli_uart.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
 * @brief CLI interface over UART
NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16);
NRF_CLI_DEF(m_cli_uart,
            "uart_cli:~$ ",
            &m_cli_uart_transport.transport,
            '\r',
            4);
 * @brief Enable USB power detection
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
 * @brief Enable HID mouse class
#define CONFIG_HAS_MOUSE    1
 * @brief Enable HID keyboard class
#define CONFIG_HAS_KBD      1
 * @brief Mouse button count
#define CONFIG_MOUSE_BUTTON_COUNT 1//2
 * @brief Mouse speed (value sent via HID when board button is pressed).
#define CONFIG_MOUSE_MOVE_STEP (3)
 * @brief Mouse move repeat time in milliseconds
#define CONFIG_MOUSE_MOVE_TIME_MS (5)
 * @brief Letter to be sent on LETTER button
 * @sa BTN_KBD_LETTER
uint8_t config_kbd_letter = APP_USBD_HID_KBD_G;
//#define CONFIG_KBD_LETTER APP_USBD_HID_KBD_G
 * @brief Propagate SET_PROTOCOL command to other HID instance
#define PROPAGATE_PROTOCOL  0
#define LED_CAPSLOCK       (BSP_BOARD_LED_0) /**< CAPSLOCK */
//#define LED_NUMLOCK        (BSP_BOARD_LED_1) /**< NUMLOCK */
#define LED_HID_REP        (BSP_BOARD_LED_1)//2) /**< Changes its state if any HID report was received or transmitted */
#define LED_USB_START      (BSP_BOARD_LED_2)//3) /**< The USBD library has been started and the bus is not in SUSPEND state */
//#define BTN_MOUSE_X_POS   0
#define BTN_MOUSE_LEFT     0//1
//#define BTN_KBD_SHIFT      2
#define BTN_KBD_LETTER     1//3
 * @brief Additional key release events
 * This example needs to process release events of used buttons
enum {
    BSP_USER_EVENT_RELEASE_0 = BSP_EVENT_KEY_LAST + 1, /**< Button 0 released */
    BSP_USER_EVENT_RELEASE_1,                          /**< Button 1 released */
    BSP_USER_EVENT_RELEASE_2,                          /**< Button 2 released */
    BSP_USER_EVENT_RELEASE_3,                          /**< Button 3 released */
    BSP_USER_EVENT_RELEASE_4,                          /**< Button 4 released */
    BSP_USER_EVENT_RELEASE_5,                          /**< Button 5 released */
    BSP_USER_EVENT_RELEASE_6,                          /**< Button 6 released */
    BSP_USER_EVENT_RELEASE_7,                          /**< Button 7 released */
 * @brief USB composite interfaces
#define APP_USBD_INTERFACE_MOUSE 0
#define APP_USBD_INTERFACE_KBD   1
 * @brief User event handler, HID mouse
static void hid_mouse_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                      app_usbd_hid_user_event_t event);
 * @brief User event handler, HID keyboard
static void hid_kbd_user_ev_handler(app_usbd_class_inst_t const * p_inst,
/*lint -save -e26 -e64 -e123 -e505 -e651*/
 * @brief Global HID mouse instance
APP_USBD_HID_MOUSE_GLOBAL_DEF(m_app_hid_mouse,
                              APP_USBD_INTERFACE_MOUSE,
                              NRF_DRV_USBD_EPIN1,
                              CONFIG_MOUSE_BUTTON_COUNT,
                              hid_mouse_user_ev_handler,
                              APP_USBD_HID_SUBCLASS_BOOT
APP_USBD_DUMMY_GLOBAL_DEF(m_app_mouse_dummy, APP_USBD_INTERFACE_MOUSE);
 * @brief Global HID keyboard instance
APP_USBD_HID_KBD_GLOBAL_DEF(m_app_hid_kbd,
                            APP_USBD_INTERFACE_KBD,
                            NRF_DRV_USBD_EPIN2,
                            hid_kbd_user_ev_handler,
APP_USBD_DUMMY_GLOBAL_DEF(m_app_kbd_dummy, APP_USBD_INTERFACE_KBD);
/*lint -restore*/
 * @brief Timer to repeat mouse move
APP_TIMER_DEF(m_mouse_move_timer);
static void kbd_status(void)
//    if(app_usbd_hid_kbd_led_state_get(&m_app_hid_kbd, APP_USBD_HID_KBD_LED_NUM_LOCK))
//        bsp_board_led_on(LED_NUMLOCK);
//    else
//        bsp_board_led_off(LED_NUMLOCK);
    if(app_usbd_hid_kbd_led_state_get(&m_app_hid_kbd, APP_USBD_HID_KBD_LED_CAPS_LOCK))
        bsp_board_led_on(LED_CAPSLOCK);
        bsp_board_led_off(LED_CAPSLOCK);
 * @brief Class specific event handler.
 * @param p_inst    Class instance.
 * @param event     Class specific event.
    UNUSED_PARAMETER(p_inst);
    switch (event) {
        case APP_USBD_HID_USER_EVT_OUT_REPORT_READY:
            /* No output report defined for HID mouse.*/
            ASSERT(0);
        case APP_USBD_HID_USER_EVT_IN_REPORT_DONE:
            bsp_board_led_invert(LED_HID_REP);
        case APP_USBD_HID_USER_EVT_SET_BOOT_PROTO:
            UNUSED_RETURN_VALUE(hid_mouse_clear_buffer(p_inst));
#if PROPAGATE_PROTOCOL
            hid_kbd_on_set_protocol(&m_app_hid_kbd, APP_USBD_HID_USER_EVT_SET_BOOT_PROTO);
        case APP_USBD_HID_USER_EVT_SET_REPORT_PROTO:
            hid_kbd_on_set_protocol(&m_app_hid_kbd, APP_USBD_HID_USER_EVT_SET_REPORT_PROTO);
//const void * app_usbd_hid_kbd_out_report_get(app_usbd_hid_kbd_t const * p_kbd,
//                                             size_t * p_size);
size_t size;
uint8_t *report;
uint8_t LED;
    switch (event) {
            /* Only one output report IS defined for HID keyboard class. Update LEDs state. */
						//self-added
						report = (uint8_t *) app_usbd_hid_kbd_out_report_get(&m_app_hid_kbd, &size);
						LED = report[1];
						if (LED == 0) config_kbd_letter = APP_USBD_HID_KBD_A;
						else if (LED == 1) config_kbd_letter = APP_USBD_HID_KBD_B;
						else if (LED == 2) config_kbd_letter = APP_USBD_HID_KBD_C;
						else if (LED == 3) config_kbd_letter = APP_USBD_HID_KBD_D;
						else if (LED == 4) config_kbd_letter = APP_USBD_HID_KBD_E;
						else if (LED == 5) config_kbd_letter = APP_USBD_HID_KBD_F;
						else if (LED == 6) config_kbd_letter = APP_USBD_HID_KBD_G;
						else if (LED == 7) config_kbd_letter = APP_USBD_HID_KBD_H;
						else if (LED == 8) config_kbd_letter = APP_USBD_HID_KBD_I;
						else if (LED == 9) config_kbd_letter = APP_USBD_HID_KBD_J;
						else if (LED == 10) config_kbd_letter = APP_USBD_HID_KBD_K;
						else if (LED == 11) config_kbd_letter = APP_USBD_HID_KBD_L;
						else if (LED == 12) config_kbd_letter = APP_USBD_HID_KBD_M;
						else if (LED == 13) config_kbd_letter = APP_USBD_HID_KBD_N;
						else if (LED == 14) config_kbd_letter = APP_USBD_HID_KBD_O;
						else if (LED == 15) config_kbd_letter = APP_USBD_HID_KBD_P;
						else if (LED == 16) config_kbd_letter = APP_USBD_HID_KBD_Q;
						else if (LED == 17) config_kbd_letter = APP_USBD_HID_KBD_R;
						else if (LED == 18) config_kbd_letter = APP_USBD_HID_KBD_S;
						else if (LED == 19) config_kbd_letter = APP_USBD_HID_KBD_T;
						else if (LED == 20) config_kbd_letter = APP_USBD_HID_KBD_U;
						else if (LED == 21) config_kbd_letter = APP_USBD_HID_KBD_V;
						else if (LED == 22) config_kbd_letter = APP_USBD_HID_KBD_W;
						else if (LED == 23) config_kbd_letter = APP_USBD_HID_KBD_X;
						else if (LED == 24) config_kbd_letter = APP_USBD_HID_KBD_Y;
						else if (LED == 25) config_kbd_letter = APP_USBD_HID_KBD_Z;
						else config_kbd_letter = APP_USBD_HID_KBD_G;
            kbd_status();
            UNUSED_RETURN_VALUE(hid_kbd_clear_buffer(p_inst));
            hid_mouse_on_set_protocol(&m_app_hid_mouse, APP_USBD_HID_USER_EVT_SET_BOOT_PROTO);
            hid_mouse_on_set_protocol(&m_app_hid_mouse, APP_USBD_HID_USER_EVT_SET_REPORT_PROTO);
 * @brief USBD library specific event handler.
 * @param event     USBD library event.
static void usbd_user_ev_handler(app_usbd_event_type_t event)
    switch (event)
        case APP_USBD_EVT_DRV_SOF:
        case APP_USBD_EVT_DRV_SUSPEND:
            app_usbd_suspend_req(); // Allow the library to put the peripheral into sleep mode
            bsp_board_leds_off();
        case APP_USBD_EVT_DRV_RESUME:
            bsp_board_led_on(LED_USB_START);
            kbd_status(); /* Restore LED state - during SUSPEND all LEDS are turned off */
        case APP_USBD_EVT_STARTED:
        case APP_USBD_EVT_STOPPED:
            app_usbd_disable();
        case APP_USBD_EVT_POWER_DETECTED:
            NRF_LOG_INFO("USB power detected");
            if (!nrf_drv_usbd_is_enabled())
                app_usbd_enable();
        case APP_USBD_EVT_POWER_REMOVED:
            NRF_LOG_INFO("USB power removed");
            app_usbd_stop();
        case APP_USBD_EVT_POWER_READY:
            NRF_LOG_INFO("USB ready");
            app_usbd_start();
static void mouse_move_timer_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    UNUSED_RETURN_VALUE(app_usbd_hid_mouse_x_move(&m_app_hid_mouse, CONFIG_MOUSE_MOVE_STEP));
static void bsp_event_callback(bsp_event_t ev)
    switch ((unsigned int)ev)
//        case CONCAT_2(BSP_EVENT_KEY_, BTN_MOUSE_X_POS):
//            UNUSED_RETURN_VALUE(app_usbd_hid_mouse_x_move(&m_app_hid_mouse, CONFIG_MOUSE_MOVE_STEP));
//            UNUSED_RETURN_VALUE(app_timer_start(m_mouse_move_timer, APP_TIMER_TICKS(CONFIG_MOUSE_MOVE_TIME_MS), NULL));
//            break;
//        case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_MOUSE_X_POS):
//            UNUSED_RETURN_VALUE(app_timer_stop(m_mouse_move_timer));
//            break;
        case CONCAT_2(BSP_EVENT_KEY_, BTN_MOUSE_LEFT):
            UNUSED_RETURN_VALUE(app_usbd_hid_mouse_button_state(&m_app_hid_mouse, 0, true));
        case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_MOUSE_LEFT):
            UNUSED_RETURN_VALUE(app_usbd_hid_mouse_button_state(&m_app_hid_mouse, 0, false));
//        case CONCAT_2(BSP_EVENT_KEY_, BTN_KBD_SHIFT):
//            UNUSED_RETURN_VALUE(app_usbd_hid_kbd_modifier_state_set(&m_app_hid_kbd, APP_USBD_HID_KBD_MODIFIER_LEFT_SHIFT, true));
//            break;
//        case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_KBD_SHIFT):
//            UNUSED_RETURN_VALUE(app_usbd_hid_kbd_modifier_state_set(&m_app_hid_kbd, APP_USBD_HID_KBD_MODIFIER_LEFT_SHIFT, false));
//            break;
        case CONCAT_2(BSP_EVENT_KEY_, BTN_KBD_LETTER):
            UNUSED_RETURN_VALUE(app_usbd_hid_kbd_key_control(&m_app_hid_kbd, config_kbd_letter, true));//CONFIG_KBD_LETTER, true));
        case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_KBD_LETTER):
            UNUSED_RETURN_VALUE(app_usbd_hid_kbd_key_control(&m_app_hid_kbd, config_kbd_letter, false));//CONFIG_KBD_LETTER, false));
            return; // no implementation needed
 * @brief Auxiliary internal macro
 * Macro used only in @ref init_bsp to simplify the configuration
#define INIT_BSP_ASSIGN_RELEASE_ACTION(btn)                      \
    APP_ERROR_CHECK(                                             \
        bsp_event_to_button_action_assign(                       \
            btn,                                                 \
            BSP_BUTTON_ACTION_RELEASE,                           \
            (bsp_event_t)CONCAT_2(BSP_USER_EVENT_RELEASE_, btn)) \
static void init_bsp(void)
    ret_code_t ret;
    ret = bsp_init(BSP_INIT_BUTTONS, bsp_event_callback);
    APP_ERROR_CHECK(ret);
//    INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_MOUSE_X_POS);
    INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_MOUSE_LEFT );
//    INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_KBD_SHIFT  );
    INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_KBD_LETTER );
    /* Configure LEDs */
static void init_cli(void)
    ret_code_t ret;
    ret = bsp_cli_init(bsp_event_callback);
    nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
    uart_config.pseltxd = TX_PIN_NUMBER;
    uart_config.pselrxd = RX_PIN_NUMBER;
    uart_config.hwfc    = NRF_UART_HWFC_DISABLED;
    ret = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
    ret = nrf_cli_start(&m_cli_uart);
    ret_code_t ret;
    static const app_usbd_config_t usbd_config = {
        .ev_state_proc = usbd_user_ev_handler,
    ret = NRF_LOG_INIT(NULL);
    ret = nrf_drv_clock_init();
    while(!nrf_drv_clock_lfclk_is_running())
        /* Just waiting */
    ret = app_timer_init();
    ret = app_timer_create(&m_mouse_move_timer, APP_TIMER_MODE_REPEATED, mouse_move_timer_handler);
    init_bsp();
    init_cli();
    ret = app_usbd_init(&usbd_config);
    app_usbd_class_inst_t const * class_inst_mouse;
#if CONFIG_HAS_MOUSE
    class_inst_mouse = app_usbd_hid_mouse_class_inst_get(&m_app_hid_mouse);
#else
    class_inst_mouse = app_usbd_dummy_class_inst_get(&m_app_mouse_dummy);
    ret = app_usbd_class_append(class_inst_mouse);
    app_usbd_class_inst_t const * class_inst_kbd;
#if CONFIG_HAS_KBD
    class_inst_kbd = app_usbd_hid_kbd_class_inst_get(&m_app_hid_kbd);
#else
    class_inst_kbd = app_usbd_dummy_class_inst_get(&m_app_kbd_dummy);
    ret = app_usbd_class_append(class_inst_kbd);
    NRF_LOG_INFO("USBD HID composite example started.");
    if (USBD_POWER_DETECTION)
        ret = app_usbd_power_events_enable();
        NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
        app_usbd_enable();
        app_usbd_start();
    while (true)
        while (app_usbd_event_queue_process())
            /* Nothing to do */
        nrf_cli_process(&m_cli_uart);
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        /* Sleep CPU only if there was no interrupt since last loop processing */
        __WFE();
Thank you for your support in advance and I look forward to hearing from you.
Louis
