Hello Nordic experts,
I am doing SDK 15.3.0 usbd_hid_composite example and this is where I am: https://devzone.nordicsemi.com/f/nordic-q-a/50447/nrf52840-usbd_hid_composite-how-does-windows-transmit-caps-lock-state-to-the-device-without-output-endpoint/201751. I want to modified the code so that I can control the output letter from "g" to any letter by changing the output report/control EP(EP 0). I have done the Nordic nRF52840 side code, but I do not know how to send the data from Ubuntu to the output report or control EP. So my question is how do I send data to the Control EP in Linux so that I can change the default output letter "g" to other letter?
Modified code:
* Copyright (c) 2017 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include "nrf.h"
#include "nrf_drv_usbd.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_drv_power.h"
#include "app_timer.h"
#include "app_usbd.h"
#include "app_usbd_core.h"
#include "app_usbd_hid_mouse.h"
#include "app_usbd_hid_kbd.h"
#include "app_usbd_dummy.h"
#include "app_error.h"
#include "bsp.h"
#include "bsp_cli.h"
#include "nrf_cli.h"
#include "nrf_cli_uart.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
* @brief CLI interface over UART
NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16);
NRF_CLI_DEF(m_cli_uart,
"uart_cli:~$ ",
&m_cli_uart_transport.transport,
'\r',
4);
* @brief Enable USB power detection
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
* @brief Enable HID mouse class
#define CONFIG_HAS_MOUSE 1
* @brief Enable HID keyboard class
#define CONFIG_HAS_KBD 1
* @brief Mouse button count
#define CONFIG_MOUSE_BUTTON_COUNT 1//2
* @brief Mouse speed (value sent via HID when board button is pressed).
#define CONFIG_MOUSE_MOVE_STEP (3)
* @brief Mouse move repeat time in milliseconds
#define CONFIG_MOUSE_MOVE_TIME_MS (5)
* @brief Letter to be sent on LETTER button
* @sa BTN_KBD_LETTER
uint8_t config_kbd_letter = APP_USBD_HID_KBD_G;
//#define CONFIG_KBD_LETTER APP_USBD_HID_KBD_G
* @brief Propagate SET_PROTOCOL command to other HID instance
#define PROPAGATE_PROTOCOL 0
#define LED_CAPSLOCK (BSP_BOARD_LED_0) /**< CAPSLOCK */
//#define LED_NUMLOCK (BSP_BOARD_LED_1) /**< NUMLOCK */
#define LED_HID_REP (BSP_BOARD_LED_1)//2) /**< Changes its state if any HID report was received or transmitted */
#define LED_USB_START (BSP_BOARD_LED_2)//3) /**< The USBD library has been started and the bus is not in SUSPEND state */
//#define BTN_MOUSE_X_POS 0
#define BTN_MOUSE_LEFT 0//1
//#define BTN_KBD_SHIFT 2
#define BTN_KBD_LETTER 1//3
* @brief Additional key release events
* This example needs to process release events of used buttons
enum {
BSP_USER_EVENT_RELEASE_0 = BSP_EVENT_KEY_LAST + 1, /**< Button 0 released */
BSP_USER_EVENT_RELEASE_1, /**< Button 1 released */
BSP_USER_EVENT_RELEASE_2, /**< Button 2 released */
BSP_USER_EVENT_RELEASE_3, /**< Button 3 released */
BSP_USER_EVENT_RELEASE_4, /**< Button 4 released */
BSP_USER_EVENT_RELEASE_5, /**< Button 5 released */
BSP_USER_EVENT_RELEASE_6, /**< Button 6 released */
BSP_USER_EVENT_RELEASE_7, /**< Button 7 released */
* @brief USB composite interfaces
#define APP_USBD_INTERFACE_MOUSE 0
#define APP_USBD_INTERFACE_KBD 1
* @brief User event handler, HID mouse
static void hid_mouse_user_ev_handler(app_usbd_class_inst_t const * p_inst,
app_usbd_hid_user_event_t event);
* @brief User event handler, HID keyboard
static void hid_kbd_user_ev_handler(app_usbd_class_inst_t const * p_inst,
/*lint -save -e26 -e64 -e123 -e505 -e651*/
* @brief Global HID mouse instance
APP_USBD_HID_MOUSE_GLOBAL_DEF(m_app_hid_mouse,
APP_USBD_INTERFACE_MOUSE,
NRF_DRV_USBD_EPIN1,
CONFIG_MOUSE_BUTTON_COUNT,
hid_mouse_user_ev_handler,
APP_USBD_HID_SUBCLASS_BOOT
APP_USBD_DUMMY_GLOBAL_DEF(m_app_mouse_dummy, APP_USBD_INTERFACE_MOUSE);
* @brief Global HID keyboard instance
APP_USBD_HID_KBD_GLOBAL_DEF(m_app_hid_kbd,
APP_USBD_INTERFACE_KBD,
NRF_DRV_USBD_EPIN2,
hid_kbd_user_ev_handler,
APP_USBD_DUMMY_GLOBAL_DEF(m_app_kbd_dummy, APP_USBD_INTERFACE_KBD);
/*lint -restore*/
* @brief Timer to repeat mouse move
APP_TIMER_DEF(m_mouse_move_timer);
static void kbd_status(void)
// if(app_usbd_hid_kbd_led_state_get(&m_app_hid_kbd, APP_USBD_HID_KBD_LED_NUM_LOCK))
// bsp_board_led_on(LED_NUMLOCK);
// else
// bsp_board_led_off(LED_NUMLOCK);
if(app_usbd_hid_kbd_led_state_get(&m_app_hid_kbd, APP_USBD_HID_KBD_LED_CAPS_LOCK))
bsp_board_led_on(LED_CAPSLOCK);
bsp_board_led_off(LED_CAPSLOCK);
* @brief Class specific event handler.
* @param p_inst Class instance.
* @param event Class specific event.
UNUSED_PARAMETER(p_inst);
switch (event) {
case APP_USBD_HID_USER_EVT_OUT_REPORT_READY:
/* No output report defined for HID mouse.*/
ASSERT(0);
case APP_USBD_HID_USER_EVT_IN_REPORT_DONE:
bsp_board_led_invert(LED_HID_REP);
case APP_USBD_HID_USER_EVT_SET_BOOT_PROTO:
UNUSED_RETURN_VALUE(hid_mouse_clear_buffer(p_inst));
#if PROPAGATE_PROTOCOL
hid_kbd_on_set_protocol(&m_app_hid_kbd, APP_USBD_HID_USER_EVT_SET_BOOT_PROTO);
case APP_USBD_HID_USER_EVT_SET_REPORT_PROTO:
hid_kbd_on_set_protocol(&m_app_hid_kbd, APP_USBD_HID_USER_EVT_SET_REPORT_PROTO);
//const void * app_usbd_hid_kbd_out_report_get(app_usbd_hid_kbd_t const * p_kbd,
// size_t * p_size);
size_t size;
uint8_t *report;
uint8_t LED;
switch (event) {
/* Only one output report IS defined for HID keyboard class. Update LEDs state. */
//self-added
report = (uint8_t *) app_usbd_hid_kbd_out_report_get(&m_app_hid_kbd, &size);
LED = report[1];
if (LED == 0) config_kbd_letter = APP_USBD_HID_KBD_A;
else if (LED == 1) config_kbd_letter = APP_USBD_HID_KBD_B;
else if (LED == 2) config_kbd_letter = APP_USBD_HID_KBD_C;
else if (LED == 3) config_kbd_letter = APP_USBD_HID_KBD_D;
else if (LED == 4) config_kbd_letter = APP_USBD_HID_KBD_E;
else if (LED == 5) config_kbd_letter = APP_USBD_HID_KBD_F;
else if (LED == 6) config_kbd_letter = APP_USBD_HID_KBD_G;
else if (LED == 7) config_kbd_letter = APP_USBD_HID_KBD_H;
else if (LED == 8) config_kbd_letter = APP_USBD_HID_KBD_I;
else if (LED == 9) config_kbd_letter = APP_USBD_HID_KBD_J;
else if (LED == 10) config_kbd_letter = APP_USBD_HID_KBD_K;
else if (LED == 11) config_kbd_letter = APP_USBD_HID_KBD_L;
else if (LED == 12) config_kbd_letter = APP_USBD_HID_KBD_M;
else if (LED == 13) config_kbd_letter = APP_USBD_HID_KBD_N;
else if (LED == 14) config_kbd_letter = APP_USBD_HID_KBD_O;
else if (LED == 15) config_kbd_letter = APP_USBD_HID_KBD_P;
else if (LED == 16) config_kbd_letter = APP_USBD_HID_KBD_Q;
else if (LED == 17) config_kbd_letter = APP_USBD_HID_KBD_R;
else if (LED == 18) config_kbd_letter = APP_USBD_HID_KBD_S;
else if (LED == 19) config_kbd_letter = APP_USBD_HID_KBD_T;
else if (LED == 20) config_kbd_letter = APP_USBD_HID_KBD_U;
else if (LED == 21) config_kbd_letter = APP_USBD_HID_KBD_V;
else if (LED == 22) config_kbd_letter = APP_USBD_HID_KBD_W;
else if (LED == 23) config_kbd_letter = APP_USBD_HID_KBD_X;
else if (LED == 24) config_kbd_letter = APP_USBD_HID_KBD_Y;
else if (LED == 25) config_kbd_letter = APP_USBD_HID_KBD_Z;
else config_kbd_letter = APP_USBD_HID_KBD_G;
kbd_status();
UNUSED_RETURN_VALUE(hid_kbd_clear_buffer(p_inst));
hid_mouse_on_set_protocol(&m_app_hid_mouse, APP_USBD_HID_USER_EVT_SET_BOOT_PROTO);
hid_mouse_on_set_protocol(&m_app_hid_mouse, APP_USBD_HID_USER_EVT_SET_REPORT_PROTO);
* @brief USBD library specific event handler.
* @param event USBD library event.
static void usbd_user_ev_handler(app_usbd_event_type_t event)
switch (event)
case APP_USBD_EVT_DRV_SOF:
case APP_USBD_EVT_DRV_SUSPEND:
app_usbd_suspend_req(); // Allow the library to put the peripheral into sleep mode
bsp_board_leds_off();
case APP_USBD_EVT_DRV_RESUME:
bsp_board_led_on(LED_USB_START);
kbd_status(); /* Restore LED state - during SUSPEND all LEDS are turned off */
case APP_USBD_EVT_STARTED:
case APP_USBD_EVT_STOPPED:
app_usbd_disable();
case APP_USBD_EVT_POWER_DETECTED:
NRF_LOG_INFO("USB power detected");
if (!nrf_drv_usbd_is_enabled())
app_usbd_enable();
case APP_USBD_EVT_POWER_REMOVED:
NRF_LOG_INFO("USB power removed");
app_usbd_stop();
case APP_USBD_EVT_POWER_READY:
NRF_LOG_INFO("USB ready");
app_usbd_start();
static void mouse_move_timer_handler(void * p_context)
UNUSED_PARAMETER(p_context);
UNUSED_RETURN_VALUE(app_usbd_hid_mouse_x_move(&m_app_hid_mouse, CONFIG_MOUSE_MOVE_STEP));
static void bsp_event_callback(bsp_event_t ev)
switch ((unsigned int)ev)
// case CONCAT_2(BSP_EVENT_KEY_, BTN_MOUSE_X_POS):
// UNUSED_RETURN_VALUE(app_usbd_hid_mouse_x_move(&m_app_hid_mouse, CONFIG_MOUSE_MOVE_STEP));
// UNUSED_RETURN_VALUE(app_timer_start(m_mouse_move_timer, APP_TIMER_TICKS(CONFIG_MOUSE_MOVE_TIME_MS), NULL));
// break;
// case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_MOUSE_X_POS):
// UNUSED_RETURN_VALUE(app_timer_stop(m_mouse_move_timer));
// break;
case CONCAT_2(BSP_EVENT_KEY_, BTN_MOUSE_LEFT):
UNUSED_RETURN_VALUE(app_usbd_hid_mouse_button_state(&m_app_hid_mouse, 0, true));
case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_MOUSE_LEFT):
UNUSED_RETURN_VALUE(app_usbd_hid_mouse_button_state(&m_app_hid_mouse, 0, false));
// case CONCAT_2(BSP_EVENT_KEY_, BTN_KBD_SHIFT):
// UNUSED_RETURN_VALUE(app_usbd_hid_kbd_modifier_state_set(&m_app_hid_kbd, APP_USBD_HID_KBD_MODIFIER_LEFT_SHIFT, true));
// break;
// case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_KBD_SHIFT):
// UNUSED_RETURN_VALUE(app_usbd_hid_kbd_modifier_state_set(&m_app_hid_kbd, APP_USBD_HID_KBD_MODIFIER_LEFT_SHIFT, false));
// break;
case CONCAT_2(BSP_EVENT_KEY_, BTN_KBD_LETTER):
UNUSED_RETURN_VALUE(app_usbd_hid_kbd_key_control(&m_app_hid_kbd, config_kbd_letter, true));//CONFIG_KBD_LETTER, true));
case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_KBD_LETTER):
UNUSED_RETURN_VALUE(app_usbd_hid_kbd_key_control(&m_app_hid_kbd, config_kbd_letter, false));//CONFIG_KBD_LETTER, false));
return; // no implementation needed
* @brief Auxiliary internal macro
* Macro used only in @ref init_bsp to simplify the configuration
#define INIT_BSP_ASSIGN_RELEASE_ACTION(btn) \
APP_ERROR_CHECK( \
bsp_event_to_button_action_assign( \
btn, \
BSP_BUTTON_ACTION_RELEASE, \
(bsp_event_t)CONCAT_2(BSP_USER_EVENT_RELEASE_, btn)) \
static void init_bsp(void)
ret_code_t ret;
ret = bsp_init(BSP_INIT_BUTTONS, bsp_event_callback);
APP_ERROR_CHECK(ret);
// INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_MOUSE_X_POS);
INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_MOUSE_LEFT );
// INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_KBD_SHIFT );
INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_KBD_LETTER );
/* Configure LEDs */
static void init_cli(void)
ret_code_t ret;
ret = bsp_cli_init(bsp_event_callback);
nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
uart_config.pseltxd = TX_PIN_NUMBER;
uart_config.pselrxd = RX_PIN_NUMBER;
uart_config.hwfc = NRF_UART_HWFC_DISABLED;
ret = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
ret = nrf_cli_start(&m_cli_uart);
ret_code_t ret;
static const app_usbd_config_t usbd_config = {
.ev_state_proc = usbd_user_ev_handler,
ret = NRF_LOG_INIT(NULL);
ret = nrf_drv_clock_init();
while(!nrf_drv_clock_lfclk_is_running())
/* Just waiting */
ret = app_timer_init();
ret = app_timer_create(&m_mouse_move_timer, APP_TIMER_MODE_REPEATED, mouse_move_timer_handler);
init_bsp();
init_cli();
ret = app_usbd_init(&usbd_config);
app_usbd_class_inst_t const * class_inst_mouse;
#if CONFIG_HAS_MOUSE
class_inst_mouse = app_usbd_hid_mouse_class_inst_get(&m_app_hid_mouse);
#else
class_inst_mouse = app_usbd_dummy_class_inst_get(&m_app_mouse_dummy);
ret = app_usbd_class_append(class_inst_mouse);
app_usbd_class_inst_t const * class_inst_kbd;
#if CONFIG_HAS_KBD
class_inst_kbd = app_usbd_hid_kbd_class_inst_get(&m_app_hid_kbd);
#else
class_inst_kbd = app_usbd_dummy_class_inst_get(&m_app_kbd_dummy);
ret = app_usbd_class_append(class_inst_kbd);
NRF_LOG_INFO("USBD HID composite example started.");
if (USBD_POWER_DETECTION)
ret = app_usbd_power_events_enable();
NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
app_usbd_enable();
app_usbd_start();
while (true)
while (app_usbd_event_queue_process())
/* Nothing to do */
nrf_cli_process(&m_cli_uart);
UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
/* Sleep CPU only if there was no interrupt since last loop processing */
__WFE();
Thank you for your support in advance and I look forward to hearing from you.
Louis
