Hi all,
I have a question.
When I try send message coap, it can send as mesh network.
But when I send search gateway msg, connect msg from publish (subscribe) Node to NCP. Seem it can't send as mesh network. I have to put Node in the coverage area of NCP then it can discovery and connect to Gateway. If I put NCP --> Node 1 --> Node 2 in a straight line. Node 1 can connect to mqtt gateway, but node 2 can't . But I can ping from Node 2 to Node 1 and NCP.
If I connect Node1 and Node 2 to MQTT gateway and put NCP --> Node 1 --> Node 2 in a straight line. I can send data from Node 1 and Node 2 to NCP as mesh network.
I check message type of discovery and connect message. I saw it same with coap message. They are all used otUdpSend.
So Why is there such a difference?
