nrf52840 spi
hi,
i tring to initialize spi. i am facing an error.please find the attached file.
jagadeesh
 * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include <stdbool.h>
#include <stddef.h>
#include <ctype.h>
#include <math.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_clock.h"
#include "nrf_drv_power.h"
#include "app_error.h"
#include "app_util.h"
#include "boards.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "nrf_drv_timer.h"
#include "bsp.h"
#include "nrf_wdt.h"
#include "sdk_common.h"
#include "nrf_drv_spi.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                32                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define BLE_UART_LIMIT 			240 	// size of UART sub packet
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define TX_POWER_LEVEL  8
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
uint8_t DATA_PACKECT[82];
uint8_t data_array[512];
uint16_t uartIndex = 0;
uint16_t uartSubIdx;
uint8_t SLAVE_ID[9] ="SLAVE_ID:";
uint8_t NAME1[12] ="FUEL_HEIGHT:";
uint8_t NAME2[16] ="BATTERY_VOLTAGE:";
uint8_t NAME3[12] ="TEMPERATURE:";
uint8_t SPACE[2] = "  ";
uint8_t NEW_LINE[2] = "\r\n";
uint8_t UID[4];
uint8_t buffer[8];
uint8_t buffer1[7];
uint8_t buffer2[5];
uint8_t buffer3[5];
uint8_t FUEL_HEIGHT[4];
uint8_t BAT_VOLTAGE[4];
uint8_t TEMPERATURE[4];
float F_HEIGHT;
float B_VOLTAGE;
float TEMP;
    uint32_t num;
    uint32_t num1;
    uint32_t num2;
    union ui32_to_ui8 {
    uint32_t ui32;
    uint8_t ui8[4];
}u;
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        uint32_t i;
        uint32_t DATA_LENGTH;
        NRF_UART_TASK_STARTTX;
        nrf_gpio_pin_set(TX_D);
    //     nrf_gpio_cfg_output(TX_D);
  /* if(p_evt->params.rx_data.p_data[0]=='0' || p_evt->params.rx_data.p_data[0]=='1' || p_evt->params.rx_data.p_data[0]=='4'
         || p_evt->params.rx_data.p_data[0]=='5' || p_evt->params.rx_data.p_data[0]=='B' ||p_evt->params.rx_data.p_data[0]=='7'
         || p_evt->params.rx_data.p_data[0]=='F'|| p_evt->params.rx_data.p_data[0]=='6'|| p_evt->params.rx_data.p_data[0]==' ')
        for ( i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
     //   inc++;
    else {
    printf("\r\nCOMMAND DATA MISMATCHED \r\n");
    inc = 0;
      if(inc ==14)
     printf("\r\nCOMMAND RECIEVED\r\n");
     ble_nus_data_send(&m_nus, &txdata[ii], &len, m_conn_handle);
     inc=0;
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            nrf_gpio_pin_set(PAIR_LED);
            NRF_LOG_INFO("Disconnected");
            nrf_gpio_pin_clear(PAIR_LED);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
           /* err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            APP_ERROR_CHECK(err_code);*/
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
#if 0
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
         //  if(rs485_communication2 == 0)
            nrf_gpio_pin_clear(TX_D);
            index++;
            //rs485_communication2 = 1;
          /*  if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
        //  if(rs485_communication2 == 1)
             //   if (index > 0)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                 index = 0;
        //   rs485_communication2 = 0;
           //  nrf_gpio_pin_clear(TX_D);
        case APP_UART_FIFO_ERROR:
        case APP_UART_TX_EMPTY:
        NRF_UART_TASK_STOPTX;
            UNUSED_VARIABLE(app_uart_get(&data_array[uartIndex]));
            uartIndex++;
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UARTE_BAUDRATE_9600
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
static void tx_power_set(void)
    ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
void Delay(uint16_t count)
	uint16_t ii,jj;
	for(ii=0;ii<count;ii++)
		for(jj=0;jj<10000;jj++);
void reverse(char *str, int len)
    int i=0, j=len-1, temp;
    while (i<j)
        temp = str[i];
        str[i] = str[j];
        str[j] = temp;
        i++; j--;
int intToStr(int x, char str[], int d)
    int i = 0;
    while (x)
        str[i++] = (x%10) + '0';
        x = x/10;
    // If number of digits required is more, then
    // add 0s at the beginning
    while (i < d)
        str[i++] = '0';
    reverse(str, i);
    str[i] = '\0';
    return i;
void ftoa(float n, char *res, int afterpoint)
    // Extract integer part
    int ipart = (int)n;
    // Extract floating part
    float fpart = n - (float)ipart;
    // convert integer part to string
    int i = intToStr(ipart, res, 0);
    // check for display option after point
    if (afterpoint != 0)
        res[i] = '.';  // add dot
        // Get the value of fraction part upto given no.
        // of points after dot. The third parameter is needed
        // to handle cases like 233.007
        fpart = fpart * pow(10, afterpoint);
        intToStr((int)fpart, res + i + 1, afterpoint);
/**@brief Application main function.
void wdt_init(void)
NRF_WDT->CONFIG = (WDT_CONFIG_HALT_Pause << WDT_CONFIG_HALT_Pos) | ( WDT_CONFIG_SLEEP_Run << WDT_CONFIG_SLEEP_Pos);
NRF_WDT->CRV = 9*32768;
NRF_WDT->RREN |= WDT_RREN_RR0_Msk;
NRF_WDT-> RR [0] = 0x6E524635UL;
NRF_WDT->TASKS_START = 1;
void spi_init(void)
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin   = SPI_SS_PIN;
    spi_config.miso_pin = SPI_MISO_PIN;
    spi_config.sck_pin  = SPI_SCK_PIN;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config,NULL, NULL));
/*void temp_spi(void)
float adcv_volt_f;
long temp = 0;
uint8_t ti;
	switch(adc_sts_flag)
		case 1:
			cs_low;
			adc_sts_flag = 2;
		case 2:
			if(MISO_high)
				adc_sts_flag = 3;
		case 3:
			if(MISO_low)
				adc.byte_cnt[3] = 0;
				adc.byte_cnt[2] = SPI_Tran_sieve(0);
				adc.byte_cnt[1] = SPI_Tran_sieve(0);
				adc.byte_cnt[0] = SPI_Tran_sieve(0);
				adc_sts_flag = 4;
				cs_high;
		case 4:
			ti = (mav_sample_indx-1)&(MAV_SAMPLE_WINDOW_MASK);
			temp = mav_samples[ti]-adc.full_cnt;
			mav_samples[mav_sample_indx] = adc.full_cnt;
			if(mav_sample_indx>=MAV_SAMPLE_WINDOW_MASK)mav_sample_ready = true;
			mav_sample_indx = (mav_sample_indx+1)&(MAV_SAMPLE_WINDOW_MASK);
			if(mav_sample_ready==false)break;
//avg samples
			temp = 0;
			for(uint8_t i=0;i<MAV_SAMPLE_WINDOW_SIZE;i++)
			temp = (unsigned long)(temp + mav_samples[i]);
			temp/= MAV_SAMPLE_WINDOW_SIZE;
			adcv_volt_f = ((6800*(float)temp/(2097152-temp))-100)/0.385;//calculate
			//unit conversion
			eMBRegHoldingCB(&temp_buf[0], UNIT_ADD, 1, MB_REG_READ);
			switch(temp_buf[1])
					case 'F':
						adcv_volt_f = (adcv_volt_f * 1.8) + 32;
					case 'K':
						adcv_volt_f = adcv_volt_f + 273;
					case 'C':
			//avg
			mav_temperature[mav_temperature_indx] = adcv_volt_f * read_float(CALIB_VALUE_ADD);//calibrate
			if(mav_temperature_indx>=MAV_TEMPER_WINDOW_MASK)mav_temperature_ready = true;
			mav_temperature_indx = (mav_temperature_indx+1)&(MAV_TEMPER_WINDOW_MASK);
			if(mav_temperature_ready==false)break;
//avg temperature
			adcv_volt_f = 0;
			for(uint8_t i=0;i<MAV_TEMPER_WINDOW_SIZE;i++)
				adcv_volt_f += mav_temperature[i];
			adcv_volt_f = adcv_volt_f/MAV_TEMPER_WINDOW_SIZE;
			process_resolution(adcv_volt_f);
			adc_sts_flag = 0xFF;
			adc_read_tim_out_cnt = 0;
			adc_sts_flag = 1;
u.ui32 = NRF_FICR->DEVICEID[0];
itoa(u.ui32,buffer,16);
uint8_t PIN_SENSE1[1],PIN_SENSE2[1];
uint16_t value1,value2,value3,value4,value5,value6,value7,value8,value9,value10,value11,value12;
uint16_t dlen,dlen1,dlen2,dlen3,dlen4,dlen5,dlen6,dlen7,dlen8,dlen9;
uint8_t CMD0;
uint8_t CMD1[8];
uint8_t CMD2[8];
uint8_t CMD3[8];
    uint16_t len=1;
    uint16_t lenn=9;
    uint16_t leng=12;
    uint16_t lengg=16;
    uint16_t lengt=5;
    uint16_t le=2;
unsigned char DUMMY_BYTE[5] = "0x00";
CMD0 = strtol(DUMMY_BYTE, NULL, 16);
unsigned char FUEL0[5] = "0x28";
unsigned char FUEL1[5] = "0x03";
unsigned char FUEL2[5] = "0x07";
unsigned char FUEL3[5] = "0xD3";
unsigned char FUEL4[5] = "0x00";
unsigned char FUEL5[5] = "0x02";
unsigned char FUEL6[5] = "0x33";
unsigned char FUEL7[5] = "0x7F";
unsigned char BAT0[5] = "0x28";
unsigned char BAT1[5] = "0x03";
unsigned char BAT2[5] = "0x07";
unsigned char BAT3[5] = "0xD7";
unsigned char BAT4[5] = "0x00";
unsigned char BAT5[5] = "0x02";
unsigned char BAT6[5] = "0x72";
unsigned char BAT7[5] = "0xBE";
unsigned char TEMP0[5] = "0x0F";
unsigned char TEMP1[5] = "0x03";
unsigned char TEMP2[5] = "0x08";
unsigned char TEMP3[5] = "0x03";
unsigned char TEMP4[5] = "0x00";
unsigned char TEMP5[5] = "0x02";
unsigned char TEMP6[5] = "0x37";
unsigned char TEMP7[5] = "0x45";
CMD1[0] = strtol(FUEL0, NULL, 16);
CMD1[1] = strtol(FUEL1, NULL, 16);
CMD1[2] = strtol(FUEL2, NULL, 16);
CMD1[3] = strtol(FUEL3, NULL, 16);
CMD1[4] = strtol(FUEL4, NULL, 16);
CMD1[5] = strtol(FUEL5, NULL, 16);
CMD1[6] = strtol(FUEL6, NULL, 16);
CMD1[7] = strtol(FUEL7, NULL, 16);
CMD2[0] = strtol(BAT0, NULL, 16);
CMD2[1] = strtol(BAT1, NULL, 16);
CMD2[2] = strtol(BAT2, NULL, 16);
CMD2[3] = strtol(BAT3, NULL, 16);
CMD2[4] = strtol(BAT4, NULL, 16);
CMD2[5] = strtol(BAT5, NULL, 16);
CMD2[6] = strtol(BAT6, NULL, 16);
CMD2[7] = strtol(BAT7, NULL, 16);
CMD3[0] = strtol(TEMP0, NULL, 16);
CMD3[1] = strtol(TEMP1, NULL, 16);
CMD3[2] = strtol(TEMP2, NULL, 16);
CMD3[3] = strtol(TEMP3, NULL, 16);
CMD3[4] = strtol(TEMP4, NULL, 16);
CMD3[5] = strtol(TEMP5, NULL, 16);
CMD3[6] = strtol(TEMP6, NULL, 16);
CMD3[7] = strtol(TEMP7, NULL, 16);
  nrf_gpio_cfg_output(PAIR_LED);
  nrf_gpio_cfg_output(GPIO_1);
  nrf_gpio_pin_clear(GPIO_1);
  nrf_gpio_cfg_output(GPIO_2);
  nrf_gpio_pin_clear(GPIO_2);
  nrf_gpio_cfg_sense_input(IN1,NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_HIGH);
  nrf_gpio_cfg_sense_input(IN2,NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_HIGH);
    bool erase_bonds;
    uint16_t length;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    wdt_init();
    // Start execution.
  //  printf("\r\nUART started.\r\n");
    advertising_start();
    tx_power_set();
    for (;;) {
             idle_state_handle();
NRF_WDT->RR[0] = WDT_RR_RR_Reload;
for(int jj=0;jj<6;jj++)
for(int ii=0;ii<8;ii++)
{app_uart_put(CMD0);}
nrf_delay_ms(1000);
{app_uart_put(CMD1[ii]);}
nrf_delay_ms(2000);
{app_uart_put(CMD2[ii]);}
nrf_delay_ms(2000);
{app_uart_put(CMD3[ii]);}
nrf_delay_ms(2000);
FUEL_HEIGHT[0] = data_array[4];
FUEL_HEIGHT[1] = data_array[3];
FUEL_HEIGHT[2] = data_array[6];
FUEL_HEIGHT[3] = data_array[5];
BAT_VOLTAGE[0]  = data_array[13];
BAT_VOLTAGE[1]  = data_array[12];
BAT_VOLTAGE[2]  = data_array[15];
BAT_VOLTAGE[3]  = data_array[14];
TEMPERATURE[0]  = data_array[22];
TEMPERATURE[1]  = data_array[21];
TEMPERATURE[2]  = data_array[24];
TEMPERATURE[3]  = data_array[23];
num = ((FUEL_HEIGHT[0] << 24)|(FUEL_HEIGHT[1] << 16)|(FUEL_HEIGHT[2] << 8)|(FUEL_HEIGHT[3]));
F_HEIGHT = *((float*)&num);
num1 = ((BAT_VOLTAGE[0] << 24)|(BAT_VOLTAGE[1] << 16)|(BAT_VOLTAGE[2] << 8)|(BAT_VOLTAGE[3]));
B_VOLTAGE = *((float*)&num1);
num2 = ((TEMPERATURE[0] << 24)|(TEMPERATURE[1] << 16)|(TEMPERATURE[2] << 8)|(TEMPERATURE[3]));
TEMP = *((float*)&num2);
ftoa(F_HEIGHT, buffer1, 6);
ftoa(B_VOLTAGE, buffer2, 2);
ftoa(TEMP, buffer3, 3);
/*ble_nus_data_send(&m_nus, &SLAVE_ID[0], &lenn, m_conn_handle);
ble_nus_data_send(&m_nus, &buffer[0], &len, m_conn_handle);
ble_nus_data_send(&m_nus, &SPACE[0], &le, m_conn_handle);
ble_nus_data_send(&m_nus, &NAME1[0], &leng, m_conn_handle);
ble_nus_data_send(&m_nus, &buffer1[0], &lengt, m_conn_handle);
ble_nus_data_send(&m_nus, &NAME2[0], &lengg, m_conn_handle);
ble_nus_data_send(&m_nus, &buffer2[0], &lengt, m_conn_handle);
ble_nus_data_send(&m_nus, &NAME3[0], &leng, m_conn_handle);
ble_nus_data_send(&m_nus, &buffer3[0], &lengt, m_conn_handle);
ble_nus_data_send(&m_nus, &NEW_LINE[0], &le, m_conn_handle);*/
value1 = sizeof(SLAVE_ID);
value2 = sizeof(buffer);
value3 = sizeof(SPACE);
value4 = sizeof(NAME1);
value5 = sizeof(buffer1);
value6 = sizeof(SPACE);
value7 = sizeof(NAME2);
value8 = sizeof(buffer2);
value9 = sizeof(SPACE);
value10 = sizeof(NAME3);
value11 = sizeof(buffer3);
value12 = sizeof(NEW_LINE);
dlen = value1+value2;
dlen1 = dlen+value3;
dlen2 = dlen1+value4;
dlen3 = dlen2+value5;
dlen4 = dlen3+value6;
dlen5 = dlen4+value7;
dlen6 = dlen5+value8;
dlen7 = dlen6+value9;
dlen8 = dlen7+value10;
dlen9 = dlen8+value11;
//dlen10 = dlen9+value12;
for(int ii=0;ii < value1; ii++)
{DATA_PACKECT[ii] = SLAVE_ID[ii];}
for(int ii=0;ii < value2; ii++)
{DATA_PACKECT[(value1 + ii)] = buffer[ii];}
for(int ii=0;ii < value3; ii++)
{DATA_PACKECT[(dlen + ii)] = SPACE[ii];}
for(int ii=0;ii < value4; ii++)
{DATA_PACKECT[(dlen1 + ii)] = NAME1[ii];}
for(int ii=0;ii < value5; ii++)
{DATA_PACKECT[(dlen2 + ii)] = buffer1[ii];}
for(int ii=0;ii < value6; ii++)
{DATA_PACKECT[(dlen3 + ii)] = SPACE[ii];}
for(int ii=0;ii < value7; ii++)
{DATA_PACKECT[(dlen4 + ii)] = NAME2[ii];}
for(int ii=0;ii < value8; ii++)
{DATA_PACKECT[(dlen5 + ii)] = buffer2[ii];}
for(int ii=0;ii < value9; ii++)
{DATA_PACKECT[(dlen6 + ii)] = SPACE[ii];}
for(int ii=0;ii < value10; ii++)
{DATA_PACKECT[(dlen7 + ii)] = NAME3[ii];}
for(int ii=0;ii < value11; ii++)
{DATA_PACKECT[(dlen8 + ii)] = buffer3[ii];}
for(int ii=0;ii < value12; ii++)
{DATA_PACKECT[(dlen9 + ii)] = NEW_LINE[ii];}
length = sizeof(DATA_PACKECT);
ble_nus_data_send(&m_nus, &DATA_PACKECT[0], &length, m_conn_handle);
    if(nrf_gpio_pin_read(IN1) == 1)
     {PIN_SENSE1[0]='1';}
     {PIN_SENSE1[0]='0';}
ble_nus_data_send(&m_nus, &PIN_SENSE1[0],&len, m_conn_handle);
     if(nrf_gpio_pin_read(IN2) == 1)
     {PIN_SENSE2[0]='1';}
     {PIN_SENSE2[0]='0';}
ble_nus_data_send(&m_nus, &PIN_SENSE2[0], &len, m_conn_handle);
        /*     if(uartIndex != 0) {
                   // Delay(130); // delay to capture all byte about 1K
                    Delay(100);
 //                   NRF_LOG_DEBUG("Ready to send data over BLE NUS");
 //                   NRF_LOG_HEXDUMP_DEBUG(data_array, uartIndex);
                    uartSubIdx =0;
                    do {
                          do	{
                                if(uartIndex < BLE_UART_LIMIT) length = (uint16_t)uartIndex;
                                else length = BLE_UART_LIMIT;
                                err_code = ble_nus_data_send(&m_nus, &data_array[uartSubIdx], &length, m_conn_handle);
                                        (err_code != NRF_ERROR_NOT_FOUND))	{
                            if(uartIndex < BLE_UART_LIMIT) uartIndex = 0;
                            else {
                                  uartIndex = uartIndex - BLE_UART_LIMIT;
                                  uartSubIdx = uartSubIdx + BLE_UART_LIMIT;
                        } while (uartIndex > 0);
                uartIndex = 0;*/
SDK.txt
