Measuring 32 kHz Crystal Accuracy - Test Software does only use RC Oscillator not XTAL
I want to measure the 32 kHz XTAL frequency by toggling a GPIO and measuring the frequency by a frequency counter. The nRF52 has got an external crystal connected. But if I measure the frequency, I get around 34 kHz and I noticed that this frequency is there, although I remove the 32 kHz crystal. So the frequency must be created by the internal RC or derived from the 32 MHz crystal. I checked the SDK config but it is correct:
// <e> NRFX_CLOCK_ENABLED - nrfx_clock - CLOCK peripheral driver
#ifndef NRFX_CLOCK_ENABLED
#define NRFX_CLOCK_ENABLED 1
// <o> NRFX_CLOCK_CONFIG_LF_SRC  - LF Clock Source
// <0=> RC
// <1=> XTAL
// <2=> Synth
// <131073=> External Low Swing
// <196609=> External Full Swing
#ifndef NRFX_CLOCK_CONFIG_LF_SRC
#define NRFX_CLOCK_CONFIG_LF_SRC 1
And here is my code to toggle the pin:
static void rtc_evt_handler(nrfx_rtc_int_type_t event)
  if(event == NRFX_RTC_INT_TICK)
    /* Set GPIO high */
    GPIO_pin_set(TX_TEST, GPIO_state_high);
    /* Wait some time */
    nrf_delay_us(10);
    /* Set GPIO low */
    GPIO_pin_set(TX_TEST, GPIO_state_low);
/* Public functions ----------------------------------------------------------*/
void Test_crystal_32khz_start(void)
  nrfx_rtc_config_t       rtc_config  = NRFX_RTC_DEFAULT_CONFIG;
  /* Set RTC prescaler */
  rtc_config.prescaler                = 0;
  /* Start internal LFCLK XTAL oscillator */
  nrfx_clock_init(clock_evt_handler);
  nrfx_clock_lfclk_start();
  /* Initialize RTC instance */
  nrfx_rtc_init(&rtc_instance, &rtc_config, rtc_evt_handler);
  /* Power on RTC */
  nrfx_rtc_enable(&rtc_instance);
  /* Enable tick event interrupt */
  nrfx_rtc_tick_enable(&rtc_instance, true);
  Log_print("[OK] %s: Init successful", __FILE__);
  while(1)
    Log_process_single();
I use the same SDK config for our ongoing project and there I can measure a sine wave on the 32 kHz crystal. But there is a Softdevice running, maybe it is controling the LFCLK sources?
What should I configurate, to force the chip to use the 32 kHz crystal?
Thank you!
Regards.
