Would you please tell me how can I dump a memory and save into a file in keil uVersion 5.24?
For example: I want to read the flash memory 0x00000000 to 0x00010000 of flash memory in RF52832' and save into file.
Thank you,
Chianglin
Thank you,
Chianglin
I am not sure how to do this with Keil, but you can use the command line tool nrfjrprog for this.
> nrfjprog --memrd 0x0 --n 0x10000 > dump.txt
Where can I found "nrfjrprog"? Would you please tell me it's full path?
Thank you,
Chianglin
you can download and install them from command-line-tools-nordic
thank you, Susheel.
Is there a similar way to dump to a binary file?
probably you can use "nrfjprog --readcode hexfile.hex" and then do a hex2bin conversion on the output file.
