Is there implementation of these functions available for Freertos version of app_timer?
app_timer_cnt_get()
app_timer_cnt_diff_compute()
they are required for LESC operations.
Thanks!
app_timer_cnt_get()
Thanks!
Hi.
There is actually no need for those functions in FreeRTOS.
Instead, you can use
xTaskGetTickCount - which returns the count of ticks since vTaskStartScheduler was called.
(Ref: https://www.freertos.org/a00021.html#xTaskGetTickCount)
When using an RTOS, it is best to use RTOS features as much as possible.
Joakim
Hi Joakim,
Thanks for the reply. Actually I agree that its best to use RTOS features, however currently when I include auth_tracker.c into the project its asking me for the following function:
so shall we add them to app_timer_freertos.c implementation?
Sergey
You are right Sergy,
Exclude the direct dependency of your app with RTC by including app_timer_freertos.c and let FreeRTOS take control on the tick. Your app actually can purely use freertos timers if you wish, but if you do not want to change the app_timer code, then it is understandable and just replace app_timer.c with app_timer_freertos.c in your project
Susheel, thats exactly what I did indeed, just its missing the above named functions. May be its a good idea to add them for compatibility :)
Hi Susheel Nuguru,
I am getting the same error with app_timer_cnt_diff_compute and app_timer_cnt_get (referred from auth_status_tracker.o). I have already included app_timer_freertos.c and app_timer.c isn't present in my project.
Do I need to edit app_timer_freertos.c with something like this?
uint32_t app_timer_cnt_get(void) { return xTaskGetTickCount(); }
