We are planning to finalize NRF52840 part for IoT project and below are the features/criteria that we are looking, Kindly confirm whether below features will be supported by NRF52840 in the below Yes/No in the column.
Criteria | Level | Comments | Yes/No |
BT 5.0 | Must-have | ||
Support SIG Mesh | Must-have | Shouldnt be a custom mesh implementation | |
Support LE Coded Phy | Good to Have | Will help in getting long range | |
Long Range(Range in Meters) | Must-have | ||
Configurable Power (dB) | Must-have | ||
Support for Amazon Freertos | Good to Have | If does not support get support from Amazon | |
Low power | Must-have | ||
Usable ROM (128KB to 1MB) | Must-have | Should be able to handle Wifi stack | |
OTA Support(via other Interfaces)/Dual bank | Must-have | Shouls able to do DFU via UART/SPI/I2C | |
Certified Module (CE/FCC) | Must-have | ||
Support of other Protocols | Good to Have | Gives more flexibility to use as Zigbee,NFC etc | |
HCI Commands | Good to Have | When used as only radio | |
Internal RTC | Must-have | ||
Patch support | Good to Have | To get future BT spec features | |
Debugger Support | Must-have | ||
Voltage Level(1.8 to 3.3V) | Good to Have | ||
Diffferent Varients (Cortex M0/M4) | Good to Have | ||
Work as Just Radio | Good to Have |
Thanks & Regards,
Pavankumar K
Avnet India Pvt Ltd
