DWM1001-DEV board using SAADC
this is my first post on DevZone:-)
I'm working with DWM1001-DEV board. I know that this board contains an nRF52832.
I'm configuring the SAADC to measure the battery level. The board has available two pins for them, the P0.31 and P0.30.
I compile the SAADC example project from the Nordic Web page on board and this work.
Now I want to compile the code with the user thread available for developers but the
saadc_callback never is called. I'm using timer 2.
When I configure them to NRF_TIMER_EVENT_COMPARE0 event this works because the timer2_event_handler is always called.
I'm debugging both projects and comparing and all functions, return NRF_SUCCESS.
#include "dwm.h"
#include <stdio.h>
#include "nrf.h"
#include "nrf_drv_timer.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "app_error.h"
#include "nrf_delay.h"
/* Thread priority */
#ifndef THREAD_APP_PRIO
#define THREAD_APP_PRIO 20
#endif /* THREAD_APP_PRIO */
/* Thread stack size */
#ifndef THREAD_APP_STACK_SIZE
#define THREAD_APP_STACK_SIZE (3 * 1024)
#endif /* THREAD_APP_STACK_SIZE */
#define SAMPLES_IN_BUFFER 5
#define APP_ERR_CHECK(err_code) \
do { \
if ((err_code) != DWM_OK) \
printf("err: line(%u) code(%u)", __LINE__, (err_code));\
} while (0)
volatile uint8_t state = 1;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(2);
static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t m_ppi_channel;
static uint32_t m_adc_evt_counter;
const nrf_drv_timer_t timer2 = NRF_DRV_TIMER_INSTANCE(2);
void timer2_event_handler(nrf_timer_event_t event_type, void * p_context)
ret_code_t ret_value;
nrf_saadc_value_t adc_value;
static int cnt = 0;
switch (event_type) {
case NRF_TIMER_EVENT_COMPARE0:
/*Do nothing.*/
/* interrupt handled from nordic driver, see nrf_drv_timer.c */
extern void TIMER2_IRQHandler(void);
void dwm_irq_hndlr(void *p_context)
TIMER2_IRQHandler();
int vec[5];
ret_code_t err_code;
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
APP_ERR_CHECK(err_code);
int i;
for (i = 0; i < SAMPLES_IN_BUFFER; i++)
vec[i]=p_event->data.done.p_buffer[i];
m_adc_evt_counter++;
void app_thread_entry(uint32_t data)
int count=0;
dwm_irq_t irq;
int rv;
uint32_t err_code = NRF_SUCCESS;
uint32_t time_ticks;
saadc_init();
saadc_sampling_event_init();
while (1)
count++;
if(count==30000)
count=0;
void saadc_sampling_event_init()
err_code = nrf_drv_timer_init(&timer2, &timer_cfg, timer2_event_handler);
/* setup m_timer for compare event every 400ms */
uint32_t ticks = nrf_drv_timer_ms_to_ticks(&timer2, 4000);
nrf_drv_timer_extended_compare(&timer2, NRF_TIMER_CC_CHANNEL0,ticks,NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,false);
nrf_drv_timer_enable(&timer2);
uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&timer2,NRF_TIMER_CC_CHANNEL0);
uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
err_code = nrf_drv_ppi_channel_assign(m_ppi_channel,timer_compare_event_addr,saadc_sample_task_addr);
void saadc_init(void)
nrf_saadc_channel_config_t channel_config =NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(nrf_drv_saadc_gpio_to_ain(31));
err_code = nrf_drv_saadc_init(NULL, saadc_callback);
err_code = nrf_drv_saadc_channel_init(0, &channel_config);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
void dwm_user_start(void)
uint8_t hndl;
int rv;
//dwm_shell_compile();
//Disabling ble by default as softdevice prevents debugging with breakpoints (due to priority)
//dwm_ble_compile();
//dwm_le_compile();
rv = dwm_thread_create(THREAD_APP_PRIO, app_thread_entry, (void*)NULL,"app", THREAD_APP_STACK_SIZE, &hndl);
APP_ERR_CHECK(rv);
dwm_thread_resume(hndl);
Will there be any incompatibility with the use of SAADC?
Best Regards
CostaT
  • Is very strange, I call the  nrf_drv_saadc_sample() function after all the configuration, and the  saadc_callback never is called.
    Best Regards
  • Unfortunately, we don't have any experience with the OS in question, for instance we do not understand or know the timing, so we cannot comment on how the callbacks are called. Please direct your to appropriate forums by those that have created the OS.
    Kenneth
