Using FDS Flash storage for user settings as well as for DFU
I am building on a BLE DFU project which already has a NRF_FSTORAGE_DEF for allocation of non-volatile data used by DFU.
I want to add another instance of NRF_FSTORAGE_DEF for use with application setting data.
Can I define two different regions in Flash for this purpose, or do all uses of NRF_FSTORAGE_DEF need to be in a contiguous block of Flash memory?
One problem is that m_fs is used for both instance - which is easily fixed by renaming the DFU one to m_dfu_fs to avoid a name conflict.
The DFU section is set to between 0x7F000 - 0x80000.
Can I set my other section to 0x20000 - 0x22000?
I tried this and it compiles and runs OK, but when the pages_init() function is called on initialization of the FDS module, all three pages are marked as FDS_PAGE_UNDEFINED and are not erased, so all three are discounted and the function returns NO_PAGES.
I have the following settings in sdk_config.h:
#define FDS_VIRTUAL_PAGES 3
#define FDS_VIRTUAL_PAGE_SIZE 1024
#define FDS_VIRTUAL_PAGES_RESERVED 0
Are these settings correct for what I need?
If the Flash fs_data section needs to be contiguous, how should the region be defined? In the project settings or in code (as is done for the DFU region)?
Thanks...
Declan Traill
  • Hi Declan,
    I don't think it's an problem to have multiple fstorage instances and if they are occupying different places in the flash.
    However, why did you choose 0x20000 - 0x22000 ? Which SDK and softdevice you are using ?It's more likely inside the softdevice/application code space . I would suggest you to choose a place at the bottom of the flash, right before the bootloader.
    In addition, to avoid the flash area being used by the bootloader as the swap bank , you would need to configure how large your data is by using NRF_DFU_APP_DATA_AREA_SIZE (the area right under the bootloader). The layout is here.
  • The location of the FDS storage is set by the function in fds.c:
    static void flash_bounds_set(void)
        uint32_t flash_size  = (FDS_PHY_PAGES * FDS_PHY_PAGE_SIZE * sizeof(uint32_t));
        m_fs.end_addr   = flash_end_addr();
        m_fs.start_addr = m_fs.end_addr - flash_size;
    This works out to be 0x20000 to 0x22000
    I am using the latest SDK, think the softdevice is s132_nrf52_5.0.0_softdevice.hex
    I tried overriding that flash_bounds_set function and setting the FDS area to 0x1000 - 0x3000, but the code does exactly the same thing - all pages are FDS_PAGE_UNDEFINED and not erased, so the pages_init() function returns NO_PAGES
  • If I override the settings in the flash_bounds_set() function and set the FDS area to 0x7B000 to 0x7E000 then the pages are set correctly and the pages_init() function is successful. Now the code waits forever in wait_for_fds_ready(). It seems I am getting a NRF_ERROR_INTERNAL from the low level write function sd_flash_write() which is then reported back as a FDS_ERR_OPERATION_TIMEOUT error by init_execute().
  • The latest is that the sd_flash_write() function is returning NRF_ERROR_FORBIDDEN      Tried to write to an address outside the application flash area.
    This is probably due to the way the FDS area is being defined, and that I have to override the flash_bounds_set() where it is supposed to set the start/end addresses (but was setting it to a non-erased region - so the init function failed).
    I can't see what setting to change at the moment - have tried a couple of things, but same result.
    BTW I have NRF_DFU_APP_DATA_AREA_SIZE set to 0x3000  for the app storage area just below the bootloader.
    Any suggestions?
  • Hi Declan,
    S132 v5.0 is quite old softdevice, are you sure you use the latest ? Which exactly SDK version you are using ?
    If you have a look here  you can have a rough idea of the memory layout.
    I'm not sure why your FDS area is at 0x1000 - 0x3000 it should not be there, it's the area for MBR and softdevice.
    What was the result of flash_end_addr() in your case  ?
    Where is your bootloader and your application located ?
