Using FDS Flash storage for user settings as well as for DFU
I am building on a BLE DFU project which already has a NRF_FSTORAGE_DEF for allocation of non-volatile data used by DFU.
I want to add another instance of NRF_FSTORAGE_DEF for use with application setting data.
Can I define two different regions in Flash for this purpose, or do all uses of NRF_FSTORAGE_DEF need to be in a contiguous block of Flash memory?
One problem is that m_fs is used for both instance - which is easily fixed by renaming the DFU one to m_dfu_fs to avoid a name conflict.
The DFU section is set to between 0x7F000 - 0x80000.
Can I set my other section to 0x20000 - 0x22000?
I tried this and it compiles and runs OK, but when the pages_init() function is called on initialization of the FDS module, all three pages are marked as FDS_PAGE_UNDEFINED and are not erased, so all three are discounted and the function returns NO_PAGES.
I have the following settings in sdk_config.h:
#define FDS_VIRTUAL_PAGES 3
#define FDS_VIRTUAL_PAGE_SIZE 1024
#define FDS_VIRTUAL_PAGES_RESERVED 0
Are these settings correct for what I need?
If the Flash fs_data section needs to be contiguous, how should the region be defined? In the project settings or in code (as is done for the DFU region)?
Thanks...
Declan Traill
  • Hi
    What compiler suite was used in this experiment? Am asking because the linker symbol reference seems to be somewhat specific to the KEIL compiler toolsuite?
    RMV
  • It should work with gcc and SES as well. We have covered those compile in the code:
    #elif defined ( __CC_ARM )
    extern char Load$$LR$$LR_IROM1$$Base;
    extern char Load$$LR$$LR_IROM1$$Length;
    extern char Load$$LR$$LR_IROM1$$Limit;
    #define CODE_START ((uint32_t)&Load$$LR$$LR_IROM1$$Base)
    #define CODE_END   ((uint32_t)&Load$$LR$$LR_IROM1$$Limit)
    #define CODE_SIZE  ((uint32_t)&Load$$LR$$LR_IROM1$$Length)
    #elif defined ( __ICCARM__ )
    extern void * __vector_table;
    extern char RO_END$$Base;
    #define CODE_START ((uint32_t)&__vector_table)
    #define CODE_END   ((uint32_t)&RO_END$$Base)
    #define CODE_SIZE  (CODE_END - CODE_START)
    #elif defined(__SES_ARM)
    extern uint32_t * _vectors;
    extern uint32_t __FLASH_segment_used_end__;
    #define CODE_START ((uint32_t)&_vectors)
    #define CODE_END   ((uint32_t)&__FLASH_segment_used_end__)
    #elif defined ( __GNUC__ )
    extern uint32_t __isr_vector;
    extern uint32_t __etext;
    #define CODE_START ((uint32_t)&__isr_vector)
    #define CODE_END   ((uint32_t)&__etext)
