How to backport a example from sdk 14.3 to sdk 12.3
Hello All,
I am working on the N51822 custom board.
Using segger IDE, SDK 12.3
Previously i have worked on the sdk 14.3 on the n52810 board. It is working properly on that.
But now i have replicated same on the n51822 module with SES IDE (segger) using sdk 12.3.
But in sdk 12.3 SES files are not available.
I wanted to know the procedure from backport my previous file (sdk 14.3 ,pca10040e , s112) to sdk 12.3 ( pca10028 (s130) board files) .
I am getting lots of errors if i change definitions , include file, configuration file as per the board n51822.
Which file i have change/modified/import in the 12.3 sdk so it will work properly as same as 14.3 sdk.
Please help me if anyone know the procedure.
Waiting for your valuable response.
Regards
Rohit
  • Hi Jimmy,
    Thanks for your response.
    I will check with it and let you after some time.
    Thanks
    Rohit
    Please check my code it is from sdk 14.3
    i have import to sdk 12.3 (pca10028) how can i do it..?
     * Copyright (c) 2015 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief Blinky Sample Application main file.
     * This file contains the source code for a sample server application using the LED Button service.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "boards.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_lbs.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "bsp.h"
    #define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2    /**< Reply when unsupported features are requested. */
    #define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
    #define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
    #define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
    #define DEVICE_NAME                     "FIND_53"   /**< Name of device. Will be included in the advertising data. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                80      //500                               /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
    #define APP_ADV_TIMEOUT_IN_SECONDS      BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
     //static uint32_t cnt = 0;
    /**@brief Function for assert macro callback.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
        bsp_board_leds_init();
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
        ret_code_t              err_code;
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        ble_advdata_t advdata;
        ble_advdata_t srdata;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&srdata, 0, sizeof(srdata));
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_set(&advdata, &srdata);
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
    static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
        if (led_state)
            bsp_board_led_on(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED ON!");
            bsp_board_led_off(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED OFF!");
        ble_lbs_init_t init;
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
    ///**@brief Function for handling advertising events.
    // * @details This function will be called for advertising events which are passed to the application.
    // * @param[in] ble_adv_evt  Advertising event.
    //static void on_adv_evt(ble_adv_evt_t ble_adv_evt)
    //    uint32_t err_code;
    //    switch (ble_adv_evt)
    //        case BLE_ADV_EVT_FAST:
    //            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
    //            APP_ERROR_CHECK(err_code);
    //            break;
    //        case BLE_ADV_EVT_IDLE:
    //            sleep_mode_enter();
    //            break;
    //        default:
    //            break;
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module that
     *          are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply
     *       setting the disconnect_on_fail config parameter, but instead we use the event
     *       handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
        APP_ERROR_HANDLER(nrf_error);
        ble_gap_adv_params_t adv_params;
        // Start advertising
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.type        = BLE_GAP_ADV_TYPE_ADV_IND;
        adv_params.p_peer_addr = NULL;
        adv_params.fp          = BLE_GAP_ADV_FP_ANY;
        adv_params.interval    = APP_ADV_INTERVAL;
        adv_params.timeout     = APP_ADV_TIMEOUT_IN_SECONDS;
        err_code = sd_ble_gap_adv_start(&adv_params, APP_BLE_CONN_CFG_TAG);
        bsp_board_led_on(ADVERTISING_LED);
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                bsp_board_led_on(CONNECTED_LED);
                bsp_board_led_off(ADVERTISING_LED);
                err_code = app_button_enable();
                NRF_LOG_INFO("Disconnected");
                bsp_board_led_off(CONNECTED_LED);
    //            err_code = app_button_disable();
                advertising_start();
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                       BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                       NULL,
                                                       NULL);
    #ifndef S140
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
            case BLE_EVT_USER_MEM_REQUEST:
                err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                ble_gatts_evt_rw_authorize_request_t  req;
                ble_gatts_rw_authorize_reply_params_t auth_reply;
                req = p_ble_evt->evt.gatts_evt.params.authorize_request;
                if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                        if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                        auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
            } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    #define BT0_SHORT_PUSH BSP_EVENT_KEY_0
    #define BT0_LONG_PUSH  BSP_EVENT_KEY_1
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BT0_SHORT_PUSH:
                NRF_LOG_INFO("Short button press");
            case BT0_LONG_PUSH:
                NRF_LOG_INFO("Long button press");
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_BUTTONS, bsp_event_handler);
        err_code = bsp_event_to_button_action_assign(BSP_BOARD_BUTTON_0, BSP_BUTTON_ACTION_PUSH, BT0_SHORT_PUSH);
        err_code = bsp_event_to_button_action_assign(BSP_BOARD_BUTTON_0, BSP_BUTTON_ACTION_LONG_PUSH, BT0_LONG_PUSH);
        /*err_code = bsp_btn_ble_init(NULL, &startup_event);
        *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);*/
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON:
                NRF_LOG_INFO("Send button state change.");
                err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE &&
                    err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for the Power Manager.
    static void power_manage(void)
        ret_code_t err_code = sd_app_evt_wait();
    #if USE_BSP == 0
    #define PIN_0 0
    APP_TIMER_DEF(m_button_action);
    #define BUTTON_STATE_POLL_INTERVAL_MS  10UL
    #define LONG_PRESS(MS)    (uint32_t)(MS)/BUTTON_STATE_POLL_INTERVAL_MS
    static uint32_t flag = 0, temp = 0;
    void button_timeout_handler(void * p_context)
         uint32_t err_code;
         static uint32_t cnt = 0, flag = 0,temp=0;
         if ((app_button_is_pushed(0)))
             cnt++;
             if ( (cnt >= LONG_PRESS(2000)) && (flag == 1 ))
                 cnt = 0;
                 flag = 2;
                 NRF_LOG_INFO("Long Button press");
                 NRF_LOG_INFO("stop advertising...");
                 err_code = sd_ble_gap_adv_stop();     //stop advertising
                 return;
                  err_code = app_timer_start(m_button_action,
                                             APP_TIMER_TICKS(BUTTON_STATE_POLL_INTERVAL_MS),
                                             NULL);
         else if((flag == 2 && temp == 1) ||  temp == 0 )
              cnt = 0;                         // reset counter variable
              flag = 1;
              temp = 1;
              NRF_LOG_INFO("advertising.......");
              gap_params_init();
              advertising_init();
              advertising_start();            //start advertising
              return;
    void button_callback(uint8_t pin_no, uint8_t button_action)
          uint32_t err_code;
          if ((pin_no == BUTTON_1) && (button_action == APP_BUTTON_PUSH))
                                         NULL);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
    //    ret_code_t err_code;
    //    //The array must be static because a pointer to it will be saved in the button handler module.
    //    static app_button_cfg_t buttons[] =
    //        {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
    //    err_code = app_button_init(buttons, sizeof(buttons) / sizeof(buttons[0]),
    //                               BUTTON_DETECTION_DELAY);
     uint32_t err_code;
          static app_button_cfg_t  button_cfg;
          button_cfg.pin_no         = BUTTON_1;
          button_cfg.button_handler = button_callback;
          button_cfg.pull_cfg       = NRF_GPIO_PIN_PULLUP;
          button_cfg.active_state   = APP_BUTTON_ACTIVE_LOW;
          err_code = app_button_init(&button_cfg, 1, 100);
          /*Enable an app timer instance to detect long button press*/
          err_code = app_timer_create(&m_button_action, APP_TIMER_MODE_SINGLE_SHOT, button_timeout_handler);
    #endif //USE_BSP
    static void log_init(void)
    /**@brief Function for application main entry.
        // Initialize.
        leds_init();
        timers_init();
        log_init();
    #if USE_BSP == 0
        buttons_init();
    #else
        //buttons_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        NRF_LOG_INFO("FIND test example started.");
        //advertising_start();
        // Enter main loop.
        for (;;)
                //buttons_init();
                power_manage();
    this code is working for the nrf52810 i sdk 14.3.
    Now i have to replicate on the nrf51822...
    Please provide your input..
    Waiting for the response...
    Rohit
