Target : NRF52832, SD S132 6.1.1. program on Eclipse.
Intro :
I migrated to SDK 15.3 for my application and it works.
Then I migrated DFU to SDK15.3 too but does not work fine.
We would like to be able to do updates of app via BLE. We are used to do it with SDK 13.0, so flash first time bootloader and softdevice (and application) with programmer on Eclipse, and then update the application OTA DFU via BLE.
My linker script of DFU is set as below (coming from dfu example secure bootloader):
MEMORY
FLASH (rx) : ORIGIN = 0x78000, LENGTH = 0x6000
RAM (rwx) : ORIGIN = 0x200057b8, LENGTH = 0xa848
uicr_bootloader_start_address (r) : ORIGIN = 0x00000FF8, LENGTH = 0x4
uicr_mbr_params_page (r) : ORIGIN = 0x00000FFC, LENGTH = 0x4
mbr_params_page (r) : ORIGIN = 0x0007E000, LENGTH = 0x1000
bootloader_settings_page (r) : ORIGIN = 0x0007F000, LENGTH = 0x1000
First when I flashed Bootloader and softdevice, I coud not see DfuTarg (on NRFConnect mobile). I saw differents topics as this topic here, then by starting to flash softdevice and then flash bootloader with deleting --sectorerase for flash bootloader, I can get DfuTarg at last.
It's indicated that " However, the MBR v2.4.x is backward compatible with earlier version, meaning if it couldn't find the bootloader address in flash, it will check the bootloader address in UICR. "
AIM issue:
After that, I flash the app and it does not run and I still see DfuTarg. I tried to delete --sectorerase from makefile for flash application but still the same.
So I guess that --sectorerase should only erase the pages of application i.e from 0x00026000 to 0x00049000 (in my case).
It stays stuck in Dfu mode.
Questions :
#1 : Are there any parameter missing to start app? Can the bootloader not be able to find the start address of the app ? What could it be else ?
#2 : MBR being backward compatible, if we erase the MBR it should be able to find the address of Bootloader start in &(NRF_UICR->NRFFW[0]) and it should be able to run DfuTarg ?
Thank you in advance for your help and suggestions.
