How to connect my nRF52840 DONGLE to a BLE sensor using "sd_ble_gap_connect" function
I'm currently using the nRF52840 Dongle  and i need some help.
On the other hand, i have BLE ela identifiers/sensors : elainnovation.com/bluetooth-low-energy.html
The fact is that i've already developed the code that handles the advertising mode. Now i try to implement the connected mode between nRF52840 Dongle  and BLE ela sensors
In BLE ela datasheets, it is said that when you connect to one of there Bluetooth Low Energy (BLE) Identifiers and Sensors, you can receive all data stored in it's stack just by sending an L to the sensor.
I've tried that with nfR connect APP it works, here is the result :
Now I want to do the same thing with my nrf C project based on NRF52840-Beacon_Scanner example . To my mind i need to do these steps
1/ connect with the device by using the "sd_ble_gap_connect" function
Here is the code :
and the parameters
--> m_peer_addr
--> m_scan_param_connected
--> m_connection_param
I'm blocked in this step 1, the function return error code 7 (wrong params). What is wrong in my code ?
--> It's not about whitelist because i'm not using it.
--> Maybe it's about invalid parameter(s) in p_scan_params or p_conn_params.
--> But I think that peer address is not present in the device identity list so
Q1 : How can i add a peer address in the device identity list ?
2/ sending the L to the sensor
Q2 : How can i send an L to the BLE ela sensor after connection establishment ? By using the Nordic UART Service Client ?
3/ store all data sent by BLE ela Sensor
I'll check that later after understanding both previous parts.
Thank you
AJT
