what happens if LFCLKSRC that is selected isn't available (for ex:- goes missing)
On nRF52832,
A1> Out of the Softdevice scope: if we are using RTC and have LFCLKSRC configured to XTAL source and if XTAL source gets turned off for some reason what happens. Does the system automatically switch to LFRC source? any NMI or event generated for software to know/handle?
Also when using s132 Softdevice,
B1> what happens if the softdevice is started with LFCLKSRC missing (Configure LFCLKSRC to XTAL and XTAL is not available)?
B2.> what happens if the XTAL goes missing during run time? is there any interrupt generated?
Is there any documentation available that shows the nRF52832 behavior for above scenarios?
Best Regards
Santosh Athuru
    No.
    No.
    It will indefinitely wait for the LFCLK XTAL to start. You will be stuck in sd_softdevice_enable().
    The code will likely assert and reset.
    Not specifically. If you are worried for the scenario you describe, you could implemented a LFCLK XTAL test function, that you run before you enable the SD. The function could check that you are able to start the LFCLK with XTAL within some time limit. If the test passes, use XTAL, if not use RC.
  • Does the system automatically switch to LFRC source?
    No.
    In the above use case , Softdevice is not enabled yet, so what is CPU doing, I mean which clock source is the CPU running off at this time. If the LFCLKSRC that is chosen is not available, RTC will not run, correct? but will the CPU be running?
    In the above use case, softdevice is being enabled. Can you clarify 'stuck in sd_softdevice_enable()' ? CPU is running, but the SW is waiting for some event...forever? Again which clock source is CPU running off?
    I don't see a reset happening here, it looks like Nordic pauses and resumes back when the XTAL is available. I need some way to correctly confirm this behavior while using soft device. Please advise.
    One of the problems, I'm looking at is,if Radio is transmitting while the clock goes missing and if the Nordic is stuck in that state then it keeps drawing extra current?
    Best Regards
    Santosh Athuru
  • Softdevice is not enabled yet, so what is CPU doing, I mean which clock source is the CPU running off at this time.
    The CPU is not using the LFCLK, the CPU uses the HFCLK, see the figure at this page.
    The RTC itself will still work, it can run from internal RC oscillator. But if LFCLK XTAL is chosen, but not available, you will be stuck in sd_softdevice_enable().
    The CPU will enter WFE(Wait For Event) sleep, while waiting for the LFCLKSTARTED event.
    HFCLK(If HFXO is not explicitly started, it will run from 64 MHz internal oscillator(HFINT)).
    I have not tested it, but I find the behavior you describe feasible. How did you test this ?
  • I've a reboot counter that is incremented every time code is run after reboot. So I can tell reboot isn't happening, also there are some IO, I monitor on scope.
    If we start our application with LFCLKSRC = 1, XTAL is missing, so RTC assumes LFRC as source and runs. We don't wait for any Clock started event in our code and start softdevice. Now, softdevice is trying to use XTAL as LFCLKSRC and is stuck doing something. Here we observe about 2mA of current draw, till XTAL is available.
    But, if we start our application with LFCLKSRC = 0, XTAL is missing, RTC uses LFRC as source. We configure softdevice to use XTAL as LFCLKSRC, soft device is stuck waiting for XTAL. Here we don't see the 2mA current draw we saw in above case.
    So we are wondering what inside softdevice is causing this extra 2mA current draw in first case above.
    Best Regards
    Santosh Athuru
  • If the LFCLK is already started or in the process of starting with the correct clock source(XTAL), the SD will just wait for the LFCLKSTAT SRC to change from RC to XTAL. It's the CPU current you are seeing here.
