how to get data from pc by usb ep0
SDK ver:15.2.0
demo:usbd
i want to use the 52840 usb function ,the pc is the host ,the 52840 is device。
i cant use respond_setup_data to send data to pc。
but how to get data from pc?
source:
static void usbd_event_handler(nrf_drv_usbd_evt_t const * const p_event)
    switch (p_event->type)
    case NRF_DRV_USBD_EVT_SETUP:
        nrf_drv_usbd_setup_t setup;
        nrf_drv_usbd_setup_get(&setup);
        switch (setup.bmRequest)
        case 0xFE: // send data to pc
            send_data_to_pc(&setup);    // useful
        case 0xFF: // get data from pc
            get_data_from_pc(&setup);    //unusefu
            NRF_LOG_ERROR("Unknown request: 0x%2x", setup.bmRequest);
            nrf_drv_usbd_setup_stall();
            return;
static void  send_data_to_pc(nrf_drv_usbd_setup_t const * const p_setup)
    respond_setup_data(
        p_setup,
        get_descriptor_report_interface_0,
        p_setup->wLength);
static void  get_data_from_pc(nrf_drv_usbd_setup_t const * const p_setup)
      respond_get_data(
        p_setup,
        get_data,
        p_setup->wLength);
static void respond_setup_data(
    nrf_drv_usbd_setup_t const * const p_setup,
    void const * p_data, size_t size)
    /* Check the size against required response size */
    if (size > p_setup->wLength)
        size = p_setup->wLength;
    ret_code_t ret;
    nrf_drv_usbd_transfer_t transfer =
        .p_data = {.tx = p_data},
        .size = size
    ret = nrf_drv_usbd_ep_transfer(NRF_DRV_USBD_EPIN0, &transfer);
    if (ret != NRF_SUCCESS)
        NRF_LOG_ERROR("Transfer starting failed: %d", (uint32_t)ret);
    ASSERT(ret == NRF_SUCCESS);
    UNUSED_VARIABLE(ret);
static void respond_get_data(
    void  * data, size_t size)
    ret_code_t ret;
        .p_data = {.rx = data},
        .size = size,
    ret = nrf_drv_usbd_ep_transfer(NRF_DRV_USBD_EPOUT0, &transfer);
pc usb drive is good ,i can use it to communicate with other evaluation boards.
in 52840DK ,send data to pc is ok, failed to get data from pc .
how to get data from pc by usb ep0?
thanks.
