NRF9160 infinite nrf_connect blocking behavior post LTE PSM wakeup
I've noticed several times now when the NRF9160 comes out of a PSM sleep cycle that when a call to an underlying socket connect(), or nrf_getaddrinfo() call (whether it be from a socket connect at the app level, or the connect() within sntp_init) that the underlying nrf_connect/nrf_getaddrinfo blocks forever.
So my first question is
- Why would the nrf_connect/nrf_getaddrinfo block indefinitely, even if there is a strange state issue with DNS or other with the provider iBasis or otherwise, a failure timeout should occur.
- Can either of those functions within nrf91_sockets be non-blocking enabled with O_NONBLOCKING? This is assuming there isn't an internal K_FOREVER lock state within the modem firmware which would lock it all up regardless.
I'm using the latest modem firmware and V1.0.0 tag
Thanks!
    You can set the timeout, or use fcntl() to enable flag O_NONBLOCK on a socket.
    Does it block, or does the program hang? Do you ever get out of this state, or do you need to reset in order to recover?
    Do you have a log output showing a failure, or a debug trace?
    Håkon
  • Hi Håkon!
    I suspect that if nrf_getaddrinfo also occasionally blocks then the O_NONBLOCK approach might not work, but I'll give it a try.
    The program hasn't fully hung as a worker that blinks LEDs continues running.
    In terms of log output I've added additional printk's within the BSD sockets code, right before nrf_getaddrinfo/connect which display fine over RTT, so everything stops within nrf_xyz.
    Thanks!
    I tried the O_NONBLOCK approach:
    fcntl (sockno, F_SETFL, opt | O_NONBLOCK)
    if ((res = connect (sockno, addr, addrlen)) < 0)
    if (errno == EINPROGRESS)
    fd_set wait_set;
    // make file descriptor set with socket
    FD_ZERO (&wait_set);
    FD_SET (sockno, &wait_set);
    // wait for socket to be writable; return after given timeout
    res = select (sockno + 1, NULL, &wait_set, NULL, timeout);
    when the select is called the Kernel faults with a panic
    ASSERTION FAIL [num_events > 0] @ C:/Nordic/NRF9160-100/ncs/zephyr/kernel/poll.c:195
    zero events
    ***** Kernel Panic! *****
    Current thread ID = 0x20025c90
    Faulting instruction address = 0x5e0bc
    I may just watchdog the whole application for a clean reboot which will probably be better, as I'd end up restarting LTE anyways.
    Thx
    This will not resolve to nrf_select, as this isn't offloaded through the socket offloading API:
    https://github.com/NordicPlayground/fw-nrfconnect-zephyr/blob/master/include/net/socket_offload_ops.h#L36
    You can use nrf_select directly if you include nrf_socket.h in your source file, but you could use poll() (which is offloaded and will translate to nrf_poll) in this situation and see if that works better?
    Håkon
  • Thanks! I'll give that a try.
    Somewhat related is there away to determine when the system/modem has re-established a connection to the network/provider when it comes out of sleep, or a reasonable number of seconds period after waking, or is it assumed the connection is always valid (DNS, etc) once the initial registration after bootup to the network provider has occurred?
