Hardfault Error
I'm using SDK 7.1, PCA10028 eval board, SD310 2.0.1, MCP 3.6.0.8331
When the line wrtHandle = hdr->Handle; executes I get an Hardfault Error. Why?
case BLE_GATTS_EVT_WRITE:
							if (p_ble_evt->evt.gatts_evt.params.write.handle == 0 && p_ble_evt->evt.gatts_evt.params.write.op== BLE_GATTS_OP_EXEC_WRITE_REQ_NOW)
									hdr 				=		(GatMem_t *)LongWriteBuff;
									while (hdr->Handle == p_blinds->blinds_name_handles.value_handle)
												memcpy(buff + hdr->Offset, hdr->Data, hdr->Len);
												len += hdr->Len;
												p += hdr->Len + 6;
												hdr = (GatMem_t *)p;
									 if(wrtHandle == p_blinds->blinds_name_handles.value_handle)
																		p_blinds->blinds_name_handler(p_blinds, (uint8_t *)buff);
									 if(wrtHandle == p_blinds->sched_data_handles.value_handle)
																		p_blinds->sched_data_handler(p_blinds, (uint8_t *)buff);
									 if(wrtHandle == p_blinds->room_name_handles.value_handle)
																		p_blinds->room_name_handler(p_blinds, (uint8_t *)buff);
									 if(wrtHandle == p_blinds->room_info_handles.value_handle)
																		p_blinds->room_info_handler(p_blinds, (uint8_t *)buff);
									return;
							else on_write(p_blinds, p_ble_evt);
hdr points address 0x2000275B hdr.handle = 0x000B LongWriteBuff is at address 0x2000275B LongWriteBuff[0] = 0x000B
after execution of wrtHandle = hdr->Handle; My application locks up at:
0x0001D110 E7FE      B        HardFault_Handler (0x0001D110)
   165:                 B       .
   166:                 ENDP
   167: PendSV_Handler  PROC
   168:                 EXPORT  PendSV_Handler            [WEAK]
  • Hi Ccook,
    It's hard to tell by just looking at the code snipet. Could you attach the full code or a simple example code that can demonstrate the issue so that we can test here ? If you want the code to be kept in confidence, I suggest you to post the case on MyPage support portal.
  • I never did figure out why I was getting the Hard Fault. I removed the structure hdr, and pulled the header data directly from LongWriteBuf and it's working fine now.
