How to bind the RTC in nrf9160 and extract the current time
Trying to use device_get_binding() function for the NRFX_RTC0 and using rtc_read() to extract the time.Not able to bind RTC device.
 * Copyright (c) 2019 Nordic Semiconductor ASA
 * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr.h>
#include <nrf_socket.h>
#include <net/socket.h>
#include <stdio.h>
#include <device.h>
#include <drivers/rtc.h>
#include <sys/printk.h>
#define AT_XSYSTEMMODE "AT\%XSYSTEMMODE=0,0,1,0"
#define AT_CFUN        "AT+CFUN=1"
#ifdef CONFIG_BOARD_NRF9160_PCA10090NS
#define AT_MAGPIO      "AT\%XMAGPIO=1,0,0,1,1,1574,1577"
static const char     update_indicator[] = {'\\', '|', '/', '-'};
static const char     at_commands[][31]  = {
				AT_XSYSTEMMODE,
				AT_MAGPIO,
				AT_CFUN
static int            fd;
static char           nmea_strings[10][NRF_GNSS_NMEA_MAX_LEN];
static u32_t          nmea_string_cnt;
static bool           got_first_fix;
static bool           update_terminal;
static u64_t          fix_timestamp;
nrf_gnss_data_frame_t last_fix;
#define ALARM (RTC_ALARM_SECOND)
void test_rtc_interrupt_fn(struct device *rtc_dev)
	u32_t now = rtc_read(rtc_dev);
	printk("Alarm\n");
	rtc_set_alarm(rtc_dev, now + ALARM);
void bsd_recoverable_error_handler(uint32_t error)
	printf("Err: %lu\n", (unsigned long)error);
void bsd_irrecoverable_error_handler(uint32_t error)
	printf("Irrecoverable: %lu\n", (unsigned long)error);
static int enable_gps(void)
	int  at_sock;
	int  bytes_sent;
	int  bytes_received;
	char buf[2];
	at_sock = socket(AF_LTE, 0, NPROTO_AT);
	if (at_sock < 0) {
		return -1;
	for (int i = 0; i < ARRAY_SIZE(at_commands); i++) {
		bytes_sent = send(at_sock, at_commands[i],
				  strlen(at_commands[i]), 0);
		if (bytes_sent < 0) {
			close(at_sock);
			return -1;
		do {
			bytes_received = recv(at_sock, buf, 2, 0);
		} while (bytes_received == 0);
		if (memcmp(buf, "OK", 2) != 0) {
			close(at_sock);
			return -1;
	close(at_sock);
	return 0;
static int init_app(void)
	u16_t fix_retry     = 0;
	u16_t fix_interval  = 1;
	u16_t nmea_mask     = NRF_CONFIG_NMEA_GSV_MASK |
			      NRF_CONFIG_NMEA_GSA_MASK |
			      NRF_CONFIG_NMEA_GLL_MASK |
			      NRF_CONFIG_NMEA_GGA_MASK |
			      NRF_CONFIG_NMEA_RMC_MASK;
	int   retval;
	if (enable_gps() != 0) {
		printk("Failed to enable GPS\n");
		return -1;
	fd = nrf_socket(NRF_AF_LOCAL, NRF_SOCK_DGRAM, NRF_PROTO_GNSS);
	if (fd >= 0) {
		printk("Socket created\n");
	} else {
		printk("Could not init socket (err: %d)\n", fd);
		return -1;
	retval = nrf_setsockopt(fd,
				NRF_SOL_GNSS,
				NRF_SO_GNSS_FIX_RETRY,
				&fix_retry,
				sizeof(uint16_t));
	if (retval != 0) {
		printk("Failed to set fix retry value\n");
		return -1;
				NRF_SOL_GNSS,
				NRF_SO_GNSS_FIX_INTERVAL,
				&fix_interval,
				sizeof(uint16_t));
	if (retval != 0) {
		printk("Failed to set fix interval value\n");
		return -1;
				NRF_SOL_GNSS,
				NRF_SO_GNSS_NMEA_MASK,
				&nmea_mask,
				sizeof(uint16_t));
	if (retval != 0) {
		printk("Failed to set nmea mask\n");
		return -1;
				NRF_SOL_GNSS,
				NRF_SO_GNSS_START,
				NULL,
				0);
	if (retval != 0) {
		printk("Failed to start GPS\n");
		return -1;
	return 0;
static void print_satellite_stats(nrf_gnss_data_frame_t *pvt_data)
	u8_t  tracked          = 0;
	u8_t  in_fix           = 0;
	u8_t  unhealthy        = 0;
	for (int i = 0; i < NRF_GNSS_MAX_SATELLITES; ++i) {
		if ((pvt_data->pvt.sv[i].sv > 0) &&
		    (pvt_data->pvt.sv[i].sv < 33)) {
			tracked++;
			if (pvt_data->pvt.sv[i].flags &
					NRF_GNSS_PVT_FLAG_FIX_VALID_BIT) {
				in_fix++;
					NRF_GNSS_SV_FLAG_UNHEALTHY) {
				unhealthy++;
	printk("Tracking: %d Using: %d Unhealthy: %d", tracked,
						       in_fix,
						       unhealthy);
	printk("\nSeconds since last fix %lld\n",
			(k_uptime_get() - fix_timestamp) / 1000);
static void print_pvt_data(nrf_gnss_data_frame_t *pvt_data)
	printf("Longitude:  %f\n", pvt_data->pvt.longitude);
	printf("Latitude:   %f\n", pvt_data->pvt.latitude);
	printf("Altitude:   %f\n", pvt_data->pvt.altitude);
	printf("Speed:      %f\n", pvt_data->pvt.speed);
	printf("Heading:    %f\n", pvt_data->pvt.heading);
	printk("Date:       %02u-%02u-%02u\n", pvt_data->pvt.datetime.day,
					       pvt_data->pvt.datetime.month,
					       pvt_data->pvt.datetime.year);
	printk("Time (UTC): %02u:%02u:%02u\n", pvt_data->pvt.datetime.hour,
					       pvt_data->pvt.datetime.minute,
					      pvt_data->pvt.datetime.seconds);
static void print_nmea_data(void)
	printk("NMEA strings:\n");
	for (int i = 0; i < nmea_string_cnt; ++i) {
		printk("%s\n", nmea_strings[i]);
int process_gps_data(nrf_gnss_data_frame_t *gps_data)
	int retval;
	retval = nrf_recv(fd, gps_data, sizeof(nrf_gnss_data_frame_t), NRF_MSG_DONTWAIT);
	if (retval > 0) {
		switch (gps_data->data_id) {
		case NRF_GNSS_PVT_DATA_ID:
			if ((gps_data->pvt.flags &
				== NRF_GNSS_PVT_FLAG_FIX_VALID_BIT) {
				if (!got_first_fix) {
					got_first_fix = true;
				fix_timestamp = k_uptime_get();
				memcpy(&last_fix, gps_data, sizeof(nrf_gnss_data_frame_t));
				nmea_string_cnt = 0;
				update_terminal = true;
		case NRF_GNSS_NMEA_DATA_ID:
			if (nmea_string_cnt < 10) {
				memcpy(nmea_strings[nmea_string_cnt++],
				       gps_data->nmea,
				       retval);
	return retval;
static inline void rtc_enable_gps(struct device *dev)
	counter_start(dev);
      struct rtc_config config;
	struct device *rtc_dev;
	printk("Test RTC driver\n");
	rtc_dev = device_get_binding("NRFX_RTC0");
        if (!rtc_dev) {
		printk("Cannot get RTC device\n");
        rtc_enable_gps(rtc_dev);
        printk("After enabling rtc\n");
        printk("After device binding\n");
	config.init_val = 0U;
	config.alarm_enable = 1U;
	config.alarm_val = ALARM;
         printk("After seting alarm value\n");
	//config.cb_fn = test_rtc_interrupt_fn;
	rtc_set_config(rtc_dev, &config);
	nrf_gnss_data_frame_t gps_data;
	u8_t		      cnt = 0;
	printk("Staring GPS application\n");
	if (init_app() != 0) {
		return -1;
	printk("Getting GPS data...\n");
	while (1) {
		do {
			/* Loop until we don't have more
			 * data to read
		} while (process_gps_data(&gps_data) > 0);
			cnt++;
			printk("\033[1;1H");
			printk("\033[2J");
			print_satellite_stats(&gps_data);
			printk("\nScanning [%c] ",
					update_indicator[cnt%4]);
		if (((k_uptime_get() - fix_timestamp) >= 1) &&
		     (got_first_fix)) {
			printk("\033[2J");
			printk("---------------------------------\n");
			print_pvt_data(&last_fix);
			printk("\n");
			print_nmea_data();
			printk("---------------------------------");
			update_terminal = false;
		k_sleep(K_MSEC(500));
	return 0;
