SD 6.0.0 to SD 6.1.1 migration problem
Hello all,
I recently migrated from SDK 15.0.0 to SDK 15.3.0 and as a result tried to migrate from SD 6.0.0 to 6.1.1.
My application goes to sleep after a while and when it wakes up it should auto connect to to its host again.
The problem here is that using SD v-6.1.1 after 7 or 8 disconnect and connects the soft device asserts without any additional log info about the reason. the PC is at 0x00014AA6 when SD asserts which is in soft device.
The application works fine using SD v-6.0.0
I saw this and I wonder if I have the same problem?
Either way is there any way to resolve this issue or I have to use the soft device v 6.0.0???
thanks,
Hossein
