Add Timer Schedule in Mesh Main
Hi
I am doing a mesh application with :
      --SOC:52832;
      --with an AT Command Module connected  UART;
      --Mesh SDK :3.2;
      --SDK 15.3;
in order to manage call backs from AT Command Module, I add Schedule in mesh, to protect a timer watching  UART;
Simple codes here :
BEFORE MAIN:
     #define SCHED_MAX_EVENT_DATA_SIZE       APP_TIMER_SCHED_EVENT_DATA_SIZE    //define two parameters for schedule
    void one_net_timer_init(void);  //declare timer
static void scheduler_init(void)
APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
app_sched_execute();
IN MAIN:
one_net_timer_init();   //initiate the timer watching UART
scheduler_init();
for (;;)
   idle_state_handle();     //take care timer event;
  (void)sd_app_evt_wait();
 IN APPLICATION FILE:
APP_TIMER_DEF(one_net_timer);    //define timer
void one_net_timer_handler(void * p_context)     //timer handle
UNUSED_PARAMETER(p_context);
if(m_onenet_initiated){
at_uart_handle_URL(uart_rx_data);   //this is the function to checke UART call backs
void one_net_timer_init(void)       //Initiate timer
ret_code_t err_code;
err_code = app_timer_create(&one_net_timer,APP_TIMER_MODE_REPEATED, one_net_timer_handler);
err_code = app_timer_start(one_net_timer, APP_TIMER_TICKS(5000), NULL);
  PROBLEM:
  Operation went well, but after a while, when program is waiting call backs,  came out an error: Mesh Error 1, or Mesh Error 4, at 0x000000000;
 I am sure it is not with : at_uart_handle_URL(uart_rx_data);  in first two or three minutes, call backs handled properly. Error came in waiting period.
 Does mesh exist with Schedule in SDK 15.3 ?
Thanks
Brent
