i am trying to interface ultrasonic sensor with nrf9160, but i dont get any examples regarding ultrasonic. so i tried the interrupt method to measure the time of gpio high state, i used
k_cycle_get_32(); function to get starting timing and also i used the same function while the high is getting low. then i send the count to SYS_CLOCK_HW_CYCLES_TO_NS() function, but it doesnt give the exact value. kindly help me to sort this out. here i attached the interrupt callback function.
static void UltraSonicData(struct device *port, struct gpio_callback *cb, u32_t pins)
static uint8_t DataFlag;
float Distance;
if(DataFlag == 0)
Time = k_cycle_get_32();
printk("UltraSonic high Started\n starting time: %d \n ",Time);
int err;
gpio_pin_configure(gpio_dev, dpin1,
(GPIO_DIR_IN | GPIO_INT | GPIO_INT_EDGE |
GPIO_INT_ACTIVE_LOW));
gpio_init_callback(&ultrasonic_cb, UltraSonicData, BIT(dpin1));
err = gpio_add_callback(gpio_dev, &ultrasonic_cb);
if (err)
printk("UltraSonicConfig Cannot add callbacks");
err = gpio_pin_enable_callback(gpio_dev, dpin1);
if (err)
printk("UltraSonicConfig Cannot enable callbacks");
DataFlag = 1;
Time = k_cycle_get_32() - Time;
printf("Time:%d\n ",Time);
Distance = (((SYS_CLOCK_HW_CYCLES_TO_NS(Time)/10.0)/5882.0));//*0.0343)/2.0);
printf("Distance:%f\n ",Distance);
int err;
(GPIO_DIR_IN | GPIO_INT | GPIO_INT_EDGE | GPIO_PUD_PULL_DOWN |
GPIO_INT_ACTIVE_HIGH));
if (err)
DataFlag = 0;
thanks in advance
hmdra
