Hi.
I just wonder how can I send string message through ble.
I will use raspberrypi as server. You can check whole code below.
It works well with computer bluetooth comunication based on windows.
but I don't know which example I should use when I use nrf52840.
Before, I used ble_app_blinky example. but It couldn't connect with raspberry pi.
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <errno.h>
#include <string.h>
#include <sys/socket.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/sdp.h>
#include <bluetooth/sdp_lib.h>
#include <bluetooth/rfcomm.h>
#include <sys/wait.h>
#include <pthread.h>
#include <signal.h>
void *ThreadMain(void *argument);
bdaddr_t bdaddr_any = {0, 0, 0, 0, 0, 0};
bdaddr_t bdaddr_local = {0, 0, 0, 0xff, 0xff, 0xff};
int _str2uuid( const char *uuid_str, uuid_t *uuid ) {
/* This is from the pybluez stack */
uint32_t uuid_int[4];
char *endptr;
if( strlen( uuid_str ) == 36 ) {
char buf[9] = { 0 };
if( uuid_str[8] != '-' && uuid_str[13] != '-' &&
uuid_str[18] != '-' && uuid_str[23] != '-' ) {
return 0;
// first 8-bytes
strncpy(buf, uuid_str, 8);
uuid_int[0] = htonl( strtoul( buf, &endptr, 16 ) );
if( endptr != buf + 8 ) return 0;
// second 8-bytes
strncpy(buf, uuid_str+9, 4);
strncpy(buf+4, uuid_str+14, 4);
uuid_int[1] = htonl( strtoul( buf, &endptr, 16 ) );
// third 8-bytes
strncpy(buf, uuid_str+19, 4);
strncpy(buf+4, uuid_str+24, 4);
uuid_int[2] = htonl( strtoul( buf, &endptr, 16 ) );
// fourth 8-bytes
strncpy(buf, uuid_str+28, 8);
uuid_int[3] = htonl( strtoul( buf, &endptr, 16 ) );
if( uuid != NULL ) sdp_uuid128_create( uuid, uuid_int );
} else if ( strlen( uuid_str ) == 8 ) {
// 32-bit reserved UUID
uint32_t i = strtoul( uuid_str, &endptr, 16 );
if( endptr != uuid_str + 8 ) return 0;
if( uuid != NULL ) sdp_uuid32_create( uuid, i );
} else if( strlen( uuid_str ) == 4 ) {
// 16-bit reserved UUID
int i = strtol( uuid_str, &endptr, 16 );
if( endptr != uuid_str + 4 ) return 0;
if( uuid != NULL ) sdp_uuid16_create( uuid, i );
} else {
return 0;
return 1;
sdp_session_t *register_service(uint8_t rfcomm_channel) {
/* A 128-bit number used to identify this service. The words are ordered from most to least
* significant, but within each word, the octets are ordered from least to most significant.
* For example, the UUID represneted by this array is 00001101-0000-1000-8000-00805F9B34FB. (The
* hyphenation is a convention specified by the Service Discovery Protocol of the Bluetooth Core
* Specification, but is not particularly important for this program.)
* This UUID is the Bluetooth Base UUID and is commonly used for simple Bluetooth applications.
* Regardless of the UUID used, it must match the one that the Armatus Android app is searching
* for.
const char *service_name = "Armatus Bluetooth server";
const char *svc_dsc = "A HERMIT server that interfaces with the Armatus Android app";
const char *service_prov = "Armatus";
uuid_t root_uuid, l2cap_uuid, rfcomm_uuid, svc_uuid,
svc_class_uuid;
sdp_list_t *l2cap_list = 0,
*rfcomm_list = 0,
*root_list = 0,
*proto_list = 0,
*access_proto_list = 0,
*svc_class_list = 0,
*profile_list = 0;
sdp_data_t *channel = 0;
sdp_profile_desc_t profile;
sdp_record_t record = { 0 };
sdp_session_t *session = 0;
// set the general service ID
//sdp_uuid128_create(&svc_uuid, &svc_uuid_int);
_str2uuid("00001101-0000-1000-8000-00805F9B34FB",&svc_uuid);
sdp_set_service_id(&record, svc_uuid);
char str[256] = "";
sdp_uuid2strn(&svc_uuid, str, 256);
printf("Registering UUID %s\n", str);
// set the service class
sdp_uuid16_create(&svc_class_uuid, SERIAL_PORT_SVCLASS_ID);
svc_class_list = sdp_list_append(0, &svc_class_uuid);
sdp_set_service_classes(&record, svc_class_list);
// set the Bluetooth profile information
sdp_uuid16_create(&profile.uuid, SERIAL_PORT_PROFILE_ID);
profile.version = 0x0100;
profile_list = sdp_list_append(0, &profile);
sdp_set_profile_descs(&record, profile_list);
// make the service record publicly browsable
sdp_uuid16_create(&root_uuid, PUBLIC_BROWSE_GROUP);
root_list = sdp_list_append(0, &root_uuid);
sdp_set_browse_groups(&record, root_list);
// set l2cap information
sdp_uuid16_create(&l2cap_uuid, L2CAP_UUID);
l2cap_list = sdp_list_append(0, &l2cap_uuid);
proto_list = sdp_list_append(0, l2cap_list);
// register the RFCOMM channel for RFCOMM sockets
sdp_uuid16_create(&rfcomm_uuid, RFCOMM_UUID);
channel = sdp_data_alloc(SDP_UINT8, &rfcomm_channel);
rfcomm_list = sdp_list_append(0, &rfcomm_uuid);
sdp_list_append(rfcomm_list, channel);
sdp_list_append(proto_list, rfcomm_list);
access_proto_list = sdp_list_append(0, proto_list);
sdp_set_access_protos(&record, access_proto_list);
// set the name, provider, and description
sdp_set_info_attr(&record, service_name, service_prov, svc_dsc);
// connect to the local SDP server, register the service record,
// and disconnect
session = sdp_connect(&bdaddr_any, &bdaddr_local, SDP_RETRY_IF_BUSY);
sdp_record_register(session, &record, 0);
// cleanup
sdp_data_free(channel);
sdp_list_free(l2cap_list, 0);
sdp_list_free(rfcomm_list, 0);
sdp_list_free(root_list, 0);
sdp_list_free(access_proto_list, 0);
sdp_list_free(svc_class_list, 0);
sdp_list_free(profile_list, 0);
return session;
char input[1024] = { 0 };
char *read_server(int client) {
// read data from the client
int bytes_read;
bytes_read = read(client, input, sizeof(input));
if (bytes_read > 0) {
printf("received [%s]\n", input);
return input;
} else {
return NULL;
void write_server(int client, char *message) {
// send data to the client
char messageArr[1024] = { 0 };
int bytes_sent;
strcpy(messageArr, message);
bytes_sent = write(client, messageArr, strlen(messageArr));
if (bytes_sent > 0) {
printf("sent [%s] %d\n", messageArr, bytes_sent);
int main()
pthread_t thread_id;
signal( SIGPIPE, SIG_IGN );
int port = 3, result, sock, client, bytes_read, bytes_sent;
struct sockaddr_rc loc_addr = { 0 }, rem_addr = { 0 };
char buffer[1024] = { 0 };
socklen_t opt = sizeof(rem_addr);
// local bluetooth adapter
loc_addr.rc_family = AF_BLUETOOTH;
loc_addr.rc_bdaddr = bdaddr_any;
loc_addr.rc_channel = (uint8_t) port;
// register service
sdp_session_t *session = register_service(port);
// allocate socket
sock = socket(AF_BLUETOOTH, SOCK_STREAM, BTPROTO_RFCOMM);
printf("socket() returned %d\n", sock);
// bind socket to port 3 of the first available
result = bind(sock, (struct sockaddr *)&loc_addr, sizeof(loc_addr));
printf("bind() on channel %d returned %d\n", port, result);
// put socket into listening mode
result = listen(sock, 1);
printf("listen() returned %d\n", result);
//sdpRegisterL2cap(port);
while(1)
// accept one connection
printf("calling accept()\n");
client = accept(sock, (struct sockaddr *)&rem_addr, &opt);
printf("accept() returned %d\n", client);
ba2str(&rem_addr.rc_bdaddr, buffer);
fprintf(stderr, "accepted connection from %s\n", buffer);
memset(buffer, 0, sizeof(buffer));
pthread_create( &thread_id, NULL, ThreadMain, (void*)client);
char buf[1024];
pthread_detach(pthread_self());
int client = (int)argument;
while(1)
char *recv_message = read_server(client);
if ( recv_message == NULL ){
printf("client disconnected\n");
printf("%s\n", recv_message);
write_server(client, recv_message);
printf("disconnected\n" );
close(client);
return 0;
