Setting up the nrfSniffer
I am following the nRF_Sniffer_UG_v2.2.pdf to setup the nrfSniffer. Wireshark does not show me my board among the interfaces. I had a look at the troubleshooting part. In part 6.1 the given tests are;
1. Run nrf_sniffer.bat --extcap-interfaces to list the interface.
2. If this exits with a python error, verify that python.exe can be run from the command line c:>python.exe --version, where the Python version is the same as Section 1.2 “Required software” on page 2.
My setup passes the second test. I see the version as 2.7.16. However it fails the first test; the outcome is nrf_sniffer.bat is not recognized as an internal or external command . I think the step I am missing is (correct me if I am wrong);
"For Windows - Verify that the path used for python in the nrf_sniffer.bat file correctly points to the required version as stated in “Required software“ on page 2."
Can someone please explain what this means?
Also is requirements.txt in pyserial-master supposed to be empty?
Thanks.
  • Hi.
     It means that you have to verify that it is Python 2.7.xx that is running the nrf_sniffer.bat file:
    @echo off
    python "%~dp0nrf_sniffer.py"  %*
    (The content of the file above).
    Have you checked this?
     Looks empty on GitHub, you can install it with pip to be sure;
    python -m pip install pyserial
    Andreas
  • Hi Andreas,
    Thanks for your assistance.
    I can confirm the the content of the nrf_sniffer.bat file's content is as you showed.
    Yes, I have checked the stuff under 6.1
    I am not sure if pyserial has been installed correctly. How can I make sure of that. I am not experienced in using the cmd terminal. So I will be happy if you can please direct me as required. I have tried to installed pyserial as you said and the output is;
    C:\Users\Denin\Desktop\pyserial-master>python -m pip install pyserial
    Collecting pyserial
      Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000000004DDDC18>: Failed to establish a new connection: [Errno 11002] getaddrinfo failed',)': /simple/pyserial/
      Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000000004DDDD68>: Failed to establish a new connection: [Errno 11002] getaddrinfo failed',)': /simple/pyserial/
      Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000000004DDDF28>: Failed to establish a new connection: [Errno 11002] getaddrinfo failed',)': /simple/pyserial/
      Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000000004E53128>: Failed to establish a new connection: [Errno 11002] getaddrinfo failed',)': /simple/pyserial/
      Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000000004E532E8>: Failed to establish a new connection: [Errno 11002] getaddrinfo failed',)': /simple/pyserial/
      Could not find a version that satisfies the requirement pyserial (from versions: )
    No matching distribution found for pyserial
    Denin
  • Hi Denin.
    Looks like you have some issues with installing pyserial.
    Could you take a look at this page and see if this could help you?
    From the error messages it seems like you're blacklisted from python.org.
    Andreas
  • Hi Andreas,
    Ok the above problem was because I was not connected to the internet. I did not know that I had to, since the pyserial files were downloaded beforehand. This is solved.
    I am now having another problem. Wireshark does not work consistently. Every time I close it (or it crashes) I have to power down the nrf board, wait and power it up again. Only then can Wireshark shows the board when I open it. Otherwise it does not.
    When it shows the board and I double click on it, Wireshark says it has started capturing packets however, usually it does not show any. In the mean time the led on the board blinks like crazy, which means it is receiving many packets. Wireshark happened to show some packets couple of times and for a limited amount of time, like a few seconds and then stopped.
    I have been going through the "6.3 nRF Sniffer occasionally works and appears unstable" part of the user guide;
    1)Typed sethwf force to the jlink.exe.
    2)Made sure both host firmware and emulator have the same date. The product is version shown on the guide (V2) is different to what I have (V3), but I have installed whatever version comes in the nrfsniffer folder. Please have a look at the screen shot.
    3)When I run jlink.exe no popups are coming up that says "A new firmware version is available.....Do you want to upgrade...?" So I assume it is up do date?
    What else could you suggest me? I have to be able to use sniffer tool properly and effectively to debug my application because I am stuck there.
    Denin
  • And I forgot to say..
    In addition to my previous message, when I click "Restart current capture", Wireshark gives me a warning that says "Unable to send control message:Invalid argument"
