Using Softdevice s140 v6.1.0
nRF5 SDK v15.2.0
I am trying to write to the flash, here are my read and write functions:
//writes to the flash
uint32_t flash_write(uint32_t m_addr, uint32_t m_data)
ret_code_t err_code;
NRF_LOG_INFO("Writing \"%x\" to flash address \"%x\".", m_data, m_addr);
err_code = nrf_fstorage_write(&fstorage, (FLASH_START_ADDR + (4*m_addr)), &m_data, sizeof(m_data), NULL);
// wait_for_flash_ready(&fstorage);
return err_code;
//reads from the flash
uint32_t flash_read(uint32_t m_addr)
uint32_t m_data;
err_code = nrf_fstorage_read(&fstorage, (FLASH_START_ADDR + (4*m_addr)), &m_data, 4);
NRF_LOG_INFO("Read \"%x\" from flash address \"%x\".", m_data, m_addr);
return m_data;
Two problems:
- The write function does not work unless i comment out the //wait_for_flash_ready(&fstorage);
- When writing 0x00000000 to an address, and then reading the same address back, I get a strange value: 0x2003FE50
Yes, I am aware that you have to erase the page before writing, but I have checked that the data at that address was already 0xFFFFFFFF
Here's the rest of my flash related code:
#define FLASH_START_ADDR 0x70000
#define FLASH_LENGTH 0x10000
#define FLASH_LENGTH_32BIT (FLASH_LENGTH/4)
static void fstorage_evt_handler(nrf_fstorage_evt_t * p_evt);
bool flashBusy = false;
NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
/* Set a handler for fstorage events. */
.evt_handler = fstorage_evt_handler,
//start and end addresses
.start_addr = FLASH_START_ADDR,
.end_addr = (FLASH_START_ADDR + FLASH_LENGTH - 1),
//Error Handler for fstorage events
if (p_evt->result != NRF_SUCCESS)
NRF_LOG_INFO("--> Event received: ERROR while executing an fstorage operation.");
return;
switch (p_evt->id)
case NRF_FSTORAGE_EVT_WRITE_RESULT:
NRF_LOG_INFO("--> Event received: wrote %d bytes at address 0x%x.",
p_evt->len, p_evt->addr);
} break;
case NRF_FSTORAGE_EVT_ERASE_RESULT:
NRF_LOG_INFO("--> Event received: erased %d page from address 0x%x.",
} break;
//blocking function to wait for flash to be ready
void wait_for_flash_ready(nrf_fstorage_t const * p_fstorage)
/* While fstorage is busy, sleep and wait for an event. */
while (nrf_fstorage_is_busy(p_fstorage))
(void)sd_app_evt_wait();
//function to set up the flash memory
void flash_init()
nrf_fstorage_api_t * p_fs_api;
p_fs_api = &nrf_fstorage_sd;
err_code = nrf_fstorage_init(&fstorage, p_fs_api, NULL);
