Hi Sir or Madam
nRF52832 support ANT+ function using 2.4G ISM frequency, but i am not sure the frequency list and channels number/ frequency bandwidth, is there any software can control the channel ?
Hi Sir or Madam
ANT+ profiles specify the channel number, and channel center frequency MHz = 2400+ channel number.
In other words: You can control the frequency, but only on channels that use a custom profile.
Hi, if we applicate FCC PART 15C certification, which section do you sugess to using? in addition , the occupide bandwidth is?
ANT+ is like BT has 79 channel? only one channel used when connect, if FHSS?
Hi Micheal,
ANT+ uses only one channel; 2457 MHz. The 6 dB bandwidth is less than 500 kHz so FCC 15.249 has to be used.
-Amanda H.
