I'm trying to utilise UART1 and freertos queues, with dynamic b;e&threads.
I'm trying to use the serial api for the UART.
I've tested the code below with the freertos_coap_server example, and it works fine.
The freertos queues pass data from the uart handler to the uart thread.
However when I use same code in the ble_thread_dyn_hrs_coap_srv_freertos example
the uart thread never recieves the queue elements from the ISR.
Can you advise?
The code for serial is shown below:
QueueHandle_t cmdMsgQueue;
int32_t init_msg_queue(void) {
cmdMsgQueue = xQueueCreate( UARTCMD_QUEUELENGTH, sizeof(cmdMsg_t) );
if( cmdMsgQueue == NULL ) {
NRF_LOG_ERROR("Creation of cmdQueue failed");
return ERROR;
NRF_LOG_INFO("Creation of cmdQueue Succeeded");
return SUCCESS;
int32_t cmdmsg_queue_recv(QueueHandle_t *msgQueue, cmdMsg_t *cmdMsg) {
BaseType_t status = xQueueReceive( *msgQueue, ( void * ) cmdMsg, ( TickType_t ) portMAX_DELAY );
if( status != pdTRUE ) {
NRF_LOG_WARNING("cmdmsg_queue_recv: Message recieve failed");
return status;
return status;
char dataBuf[400];
int dataBufCounter = 0;
static void serial_rx_cb(struct nrf_serial_s const *p_serial, nrf_serial_event_t event) {
static BaseType_t xHigherPriorityTaskWoken;
if (event == NRF_SERIAL_EVENT_RX_DATA) {
char c;
ret_code_t ret = nrf_serial_read(&serial1_uarte, &c, sizeof(c), NULL, 0);
if (ret == NRF_SUCCESS) {
if ((c == '\n') || (c == '\r')) {
cmdMsg_t cmdMsg;
memset(cmdMsg.msg,'\0', dataBufCounter+2);
memcpy(cmdMsg.msg, dataBuf, dataBufCounter+1);
cmdMsg.len = dataBufCounter+1;
otCliOutputFormat("%d\r\n", dataBufCounter+1);
if (cmdMsg.len > UARTCMD_MSGMAXLEN) {
NRF_LOG_WARNING("cmdProcUartISR: Message too long");
return;
} else {
if( xQueueSendFromISR( cmdMsgQueue, (void*)&cmdMsg, &xHigherPriorityTaskWoken ) != pdTRUE )
NRF_LOG_WARNING("cmdProcUartISR: Message send failed");
} else {
otCliOutputFormat("sent:%d\r\n", dataBufCounter+1);
dataBufCounter = 0;
memset(dataBuf,'\0', 400);
} else {
otCliOutputFormat("%d:%c\r\n", dataBufCounter, c);
dataBuf[dataBufCounter] = c;
dataBufCounter++;
} else {
otCliOutputFormat("Serial Error\r\n");
NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_DMA,
&serial1_queues, &serial1_buffs, serial_rx_cb, sleep_handler);
void uart_task(void * arg) {
ret_code_t ret;
otCliOutputFormat("in uart_task\r\n");
int qeueInitRes = init_msg_queue();
char jsonMsg[100];
otCliOutputFormat("\r\nqueue enabled: %d\r\n", qeueInitRes);
//ret = nrf_drv_power_init(NULL);
otCliOutputFormat("in uart_task: power\r\n");
APP_ERROR_CHECK(ret);
ret = nrf_serial_init(&serial1_uarte, &m_uarte1_drv_config, &serial1_config);
otCliOutputFormat("in uart_task: serial\r\n");
cmdMsg_t cmdMsg;
static char newline[] = "\n\r";
while (cmdmsg_queue_recv(&cmdMsgQueue, &cmdMsg) == pdTRUE) {
otCliOutputFormat("w: %d:%s\r\n", cmdMsg.len, cmdMsg.msg);
(void)nrf_serial_write(&serial1_uarte, &cmdMsg.msg, cmdMsg.len, NULL, NRF_SERIAL_MAX_TIMEOUT);
(void)nrf_serial_flush(&serial1_uarte, 0);
(void)nrf_serial_write(&serial1_uarte, newline, strlen(newline), NULL, 0);
