I have troble when try to change custom service to Environment Sensing Service in this sample
https://github.com/maidenone/custom_ble_service_example
I used the sample program provided by the link and only started to change what I think needed for that.:
#define BLE_UUID_ENVIRONMENT_SENSING_SERVICE 0x181A /**< Environmental Sensing Service UUID. */
#define BLE_UUID_TEMPERATURE_CHAR 0x2A6E /**< Temperature characteristic UUID. */
#define BLE_UUID_HUMIDITY_CHAR 0x2A6F /**< Humidity characteristic UUID. */
#define BLE_UUID_ENVIRONMENT_SENSING_SERVICE_BASE {0xFB, 0x34, 0x9B, 0x5F, 0x80, 0x00, 0x00, 0x80, \
0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}
and changed CUS value names to ESS. Now when program it to the nRF52840-DK in stuck in service_init() function
NRF_BREAKPOINT_COND;
// On assert, the system can only recover with a reset.
I found this problem refers to memory but I did not change anything about it in project file (KEIL I'm using). can anyone help me on that?
I attached me changed ess.c and ess.h and main files here.
Thank you
Behnam
#include "sdk_common.h"
#include "ble_ess.h"
#include <string.h>
#include "ble_srv_common.h"
#include "nrf_gpio.h"
#include "boards.h"
#include "nrf_log.h"
/**@brief Function for handling the Connect event.
* @param[in] p_ess Custom Service structure.
* @param[in] p_ble_evt Event received from the BLE stack.
static void on_connect(ble_ess_t * p_ess, ble_evt_t const * p_ble_evt)
p_ess->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
ble_ess_evt_t evt;
evt.evt_type = BLE_ESS_EVT_CONNECTED;
p_ess->evt_handler(p_ess, &evt);
/**@brief Function for handling the Disconnect event.
static void on_disconnect(ble_ess_t * p_ess, ble_evt_t const * p_ble_evt)
UNUSED_PARAMETER(p_ble_evt);
p_ess->conn_handle = BLE_CONN_HANDLE_INVALID;
ble_ess_evt_t evt;
evt.evt_type = BLE_ESS_EVT_DISCONNECTED;
/**@brief Function for handling the Write event.
static void on_write(ble_ess_t * p_ess, ble_evt_t const * p_ble_evt)
ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
// Custom Value Characteristic Written to.
if (p_evt_write->handle == p_ess->ess_meas_handles.value_handle)
nrf_gpio_pin_toggle(LED_4);
if(*p_evt_write->data == 0x01)
nrf_gpio_pin_clear(20);
else if(*p_evt_write->data == 0x02)
nrf_gpio_pin_set(20);
//Do nothing
// Check if the Custom value CCCD is written to and that the value is the appropriate length, i.e 2 bytes.
if ((p_evt_write->handle == p_ess->ess_meas_handles.cccd_handle)
&& (p_evt_write->len == 2)
// CCCD written, call application event handler
if (p_ess->evt_handler != NULL)
ble_ess_evt_t evt;
if (ble_srv_is_notification_enabled(p_evt_write->data))
evt.evt_type = BLE_ESS_EVT_NOTIFICATION_ENABLED;
evt.evt_type = BLE_ESS_EVT_NOTIFICATION_DISABLED;
// Call the application event handler.
void ble_ess_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context)
ble_ess_t * p_ess = (ble_ess_t *) p_context;
NRF_LOG_INFO("BLE event received. Event type = %d\r\n", p_ble_evt->header.evt_id);
if (p_ess == NULL || p_ble_evt == NULL)
return;
case BLE_GAP_EVT_CONNECTED:
on_connect(p_ess, p_ble_evt);
on_disconnect(p_ess, p_ble_evt);
case BLE_GATTS_EVT_WRITE:
// BEHNAM - we dont want to write on this value
on_write(p_ess, p_ble_evt);
/* Handling this event is not necessary
case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
NRF_LOG_INFO("EXCHANGE_MTU_REQUEST event received.\r\n");
// No implementation needed.
/**@brief Function for adding the Custom Value characteristic.
* @param[in] p_ess Battery Service structure.
* @param[in] p_ess_init Information needed to initialize the service.
* @return NRF_SUCCESS on success, otherwise an error code.
static uint32_t ess_measurement_char_add(ble_ess_t * p_ess, const ble_ess_init_t * p_ess_init)
uint32_t err_code;
ble_gatts_char_md_t char_md;
ble_gatts_attr_md_t cccd_md;
ble_gatts_attr_t attr_char_value;
ble_uuid_t ble_uuid;
ble_gatts_attr_md_t attr_md;
// Add Custom Value characteristic
memset(&cccd_md, 0, sizeof(cccd_md));
// Read operation on cccd should be possible without authentication.
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
cccd_md.write_perm = p_ess_init->ess_meas_char_attr_md.cccd_write_perm;
cccd_md.vloc = BLE_GATTS_VLOC_STACK;
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.read = 1;
char_md.char_props.write = 1;
char_md.char_props.notify = 1;
char_md.p_char_user_desc = NULL;
char_md.p_char_pf = NULL;
char_md.p_user_desc_md = NULL;
char_md.p_cccd_md = &cccd_md;
char_md.p_sccd_md = NULL;
ble_uuid.type = p_ess->uuid_type;
ble_uuid.uuid = BLE_UUID_TEMPERATURE_CHAR;
memset(&attr_md, 0, sizeof(attr_md));
attr_md.read_perm = p_ess_init->ess_meas_char_attr_md.read_perm;
attr_md.write_perm = p_ess_init->ess_meas_char_attr_md.write_perm;
attr_md.vloc = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth = 0;
attr_md.wr_auth = 0;
attr_md.vlen = 0;
memset(&attr_char_value, 0, sizeof(attr_char_value));
attr_char_value.p_uuid = &ble_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_len = sizeof(uint8_t);
attr_char_value.init_offs = 0;
attr_char_value.max_len = sizeof(uint8_t);
err_code = sd_ble_gatts_characteristic_add(p_ess->service_handle, &char_md,
&attr_char_value,
&p_ess->ess_meas_handles);
if (err_code != NRF_SUCCESS)
return err_code;
return NRF_SUCCESS;
uint32_t ble_ess_init(ble_ess_t * p_ess, const ble_ess_init_t * p_ess_init)
if (p_ess == NULL || p_ess_init == NULL)
return NRF_ERROR_NULL;
uint32_t err_code;
// Initialize service structure
p_ess->evt_handler = p_ess_init->evt_handler;
// BEHNAM - We do not need this step because of using standards Base address for ESS
// Add Custom Service UUID
ble_uuid128_t base_uuid = {BLE_UUID_ENVIRONMENT_SENSING_SERVICE_BASE};
err_code = sd_ble_uuid_vs_add(&base_uuid, &p_ess->uuid_type);
VERIFY_SUCCESS(err_code);
ble_uuid.uuid = BLE_UUID_ENVIRONMENT_SENSING_SERVICE;
// Add the ENVIRONMENT SENSING SERVICE
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
&ble_uuid,
&p_ess->service_handle);
return err_code;
// BEHNAM - Here we can add our Values that want to report to service
return ess_measurement_char_add(p_ess, p_ess_init);
uint32_t ble_ess_ess_meas_update(ble_ess_t * p_ess, uint8_t ess_meas)
NRF_LOG_INFO("In ble_ess_ess_meas_update. \r\n");
if (p_ess == NULL)
uint32_t err_code = NRF_SUCCESS;
ble_gatts_value_t gatts_value;
// Initialize value struct.
memset(&gatts_value, 0, sizeof(gatts_value));
gatts_value.len = sizeof(uint8_t);
gatts_value.offset = 0;
gatts_value.p_value = &ess_meas;
// Update database.
err_code = sd_ble_gatts_value_set(p_ess->conn_handle,
p_ess->ess_meas_handles.value_handle,
&gatts_value);
return err_code;
// Send value if connected and notifying.
if ((p_ess->conn_handle != BLE_CONN_HANDLE_INVALID))
ble_gatts_hvx_params_t hvx_params;
memset(&hvx_params, 0, sizeof(hvx_params));
hvx_params.handle = p_ess->ess_meas_handles.value_handle;
hvx_params.type = BLE_GATT_HVX_NOTIFICATION;
hvx_params.offset = gatts_value.offset;
hvx_params.p_len = &gatts_value.len;
hvx_params.p_data = gatts_value.p_value;
err_code = sd_ble_gatts_hvx(p_ess->conn_handle, &hvx_params);
NRF_LOG_INFO("sd_ble_gatts_hvx result: %x. \r\n", err_code);
err_code = NRF_ERROR_INVALID_STATE;
NRF_LOG_INFO("sd_ble_gatts_hvx result: NRF_ERROR_INVALID_STATE. \r\n");
return err_code;
* Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_app_template_main main.c
* @ingroup ble_sdk_app_template
* @brief Template project main file.
* This file contains a template for creating a new application. It has the code necessary to wakeup
* from button, advertise, get a connection restart advertising on disconnect and if no new
* connection created go back to system-off mode.
* It can easily be used as a starting point for creating a new application, the comments identified
* with 'YOUR_JOB' indicates where and how you can customize.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME "Nordic_Template" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define NOTIFICATION_INTERVAL APP_TIMER_TICKS(1000)
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
NRF_BLE_GATT_DEF(m_gatt);
NRF_BLE_QWR_DEF(m_qwr); /**< GATT module instance. */
BLE_ESS_DEF(m_ess); /**< Context for the Queued Write module.*/ /**< GATT module instance. */
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
APP_TIMER_DEF(m_notification_timer_id);
static uint8_t m_custom_value = 0;
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
/* YOUR_JOB: Declare all services structure your application is using
* BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
// BEHNAM - I removed BLE_UUID_TYPE_VENDOR_BEGIN because we are adding standard ESS
{BLE_UUID_ENVIRONMENT_SENSING_SERVICE}
static void advertising_start(bool erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
ret_code_t err_code;
switch (p_evt->evt_id)
case PM_EVT_BONDED_PEER_CONNECTED:
NRF_LOG_INFO("Connected to a previously bonded device.");
} break;
case PM_EVT_CONN_SEC_SUCCEEDED:
NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
ble_conn_state_role(p_evt->conn_handle),
p_evt->conn_handle,
p_evt->params.conn_sec_succeeded.procedure);
} break;
case PM_EVT_CONN_SEC_FAILED:
/* Often, when securing fails, it shouldn't be restarted, for security reasons.
* Other times, it can be restarted directly.
* Sometimes it can be restarted, but only after changing some Security Parameters.
* Sometimes, it cannot be restarted until the link is disconnected and reconnected.
* Sometimes it is impossible, to secure the link, or the peer device does not support it.
* How to handle this error is highly application dependent. */
} break;
case PM_EVT_CONN_SEC_CONFIG_REQ:
// Reject pairing request from an already bonded peer.
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
} break;
case PM_EVT_STORAGE_FULL:
// Run garbage collection on the flash.
err_code = fds_gc();
if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
// Retry.
} break;
advertising_start(false);
} break;
case PM_EVT_PEER_DATA_UPDATE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
} break;
case PM_EVT_PEER_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
} break;
case PM_EVT_PEERS_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
} break;
case PM_EVT_ERROR_UNEXPECTED:
// Assert.
APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
} break;
case PM_EVT_CONN_SEC_START:
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
case PM_EVT_PEER_DELETE_SUCCEEDED:
case PM_EVT_LOCAL_DB_CACHE_APPLIED:
case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
// This can happen when the local DB has changed.
case PM_EVT_SERVICE_CHANGED_IND_SENT:
case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
static void notification_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
// Increment the value of m_custom_value before nortifing it.
m_custom_value++;
//err_code = ble_ess_custom_value_update(&m_ess, m_custom_value);
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
// Initialize timer module.
// Create timers.
err_code = app_timer_create(&m_notification_timer_id, APP_TIMER_MODE_REPEATED, notification_timeout_handler);
/* YOUR_JOB: Create any timers to be used by the application.
Below is an example of how to create a timer.
For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
one.
err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
APP_ERROR_CHECK(err_code); */
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
/* YOUR_JOB: Use an appearance value matching the application's use case.
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
* YOUR_JOB implement a service handler function depending on the event the service you are using can generate
* @details This function will be called for all YY Service events which are passed to
* the application.
* @param[in] p_yy_service YY Service structure.
* @param[in] p_evt Event received from the YY Service.
static void on_yys_evt(ble_yy_service_t * p_yy_service,
ble_yy_service_evt_t * p_evt)
switch (p_evt->evt_type)
case BLE_YY_NAME_EVT_WRITE:
APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
/**@brief Function for handling the Custom Service Service events.
* @details This function will be called for all Custom Service events which are passed to
* the application.
* @param[in] p_ess_service Custom Service structure.
* @param[in] p_evt Event received from the Custom Service.
static void on_ess_evt(ble_ess_t * p_ess_service,
ble_ess_evt_t * p_evt)
switch(p_evt->evt_type)
case BLE_ESS_EVT_NOTIFICATION_ENABLED:
err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
case BLE_ESS_EVT_NOTIFICATION_DISABLED:
err_code = app_timer_stop(m_notification_timer_id);
case BLE_ESS_EVT_CONNECTED:
case BLE_ESS_EVT_DISCONNECTED:
ble_ess_init_t ess_init = {0};
// Initialize ENVIRONMENT SENSING SERVICE init structure to zero.
// BEHNAM - I added as said in web doc
//????memset(&ess_init, 0, sizeof(ess_init));
ess_init.evt_handler = on_ess_evt;
// BEHNAM - we dont want to write and get notification on this value
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&ess_init.custom_value_char_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&ess_init.custom_value_char_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&ess_init.custom_value_char_attr_md.write_perm);
err_code = ble_ess_init(&m_ess, &ess_init);
// BEHNAM - Here we can continue adding more charactristics and features
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for starting timers.
static void application_timers_start(void)
/* YOUR_JOB: Start your timers. below is an example of how to start a timer.
err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ret_code_t err_code = NRF_SUCCESS;
NRF_LOG_INFO("Disconnected.");
NRF_LOG_INFO("Connected.");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
* @param[in] event Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
break; // BSP_EVENT_SLEEP
case BSP_EVENT_DISCONNECT:
break; // BSP_EVENT_DISCONNECT
case BSP_EVENT_WHITELIST_OFF:
break; // BSP_EVENT_KEY_0
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for application main entry.
bool erase_bonds;
// Initialize.
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("Template example started.");
application_timers_start();
advertising_start(erase_bonds);
// Enter main loop.
for (;;)
idle_state_handle();
