I'm looking at the output of nm
on my ELF file:
20002004 00000002 d heart_rate /path/to/Debug/../src/ble.c:132
200028ac D __data_end__
200028ac D __data_start__
200028ac d __fini_array_end
200028ac d __fini_array_start
200028ac d __init_array_end
200028ac d __init_array_start
200028ac d __preinit_array_end
200028ac d __preinit_array_start
Based on gcc_nrf51_common.ld
, I would expect __data_start__
and __data_end__
to bound my initialized data. The problem I'm having is that my initialized globals don't seem to get initialized. i.e. heart_rate
doesn't get the value 70
like it should (instead it gets different values):
uint16_t heart_rate = 70;
The d
in front of heart_rate
indicates that it should be in the initialized data section--so shouldn't __data_end__
expand to accommodate at least the heart_rate
variable?
Somehow, it looks to me like the linker script is being run twice. This is an excerpt from the .map
file:
.data 0x0000000020002000 0x438 load address 0x0000000000021180
0x0000000020002000 __data_start__ = .
*(vtable)
*(.data*)
.data.m_conn_handle
0x0000000020002000 0x2 ./src/ble.o
.data.m_rr_interval_enabled
0x0000000020002002 0x1 ./src/ble.o
*fill* 0x0000000020002003 0x1
.data.heart_rate
0x0000000020002004 0x2 ./src/ble.o
.data.rr_interval
0x0000000020002006 0x2 ./src/ble.o
.data.m_transfer_completed
0x0000000020002008 0x1 ./src/cc1101.o
*fill* 0x0000000020002009 0x7
.data.impure_data
0x0000000020002010 0x428 /usr/local/gcc-arm-none-eabi-4_8-2014q3/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/lib/armv6-m/libc.a(lib_a-impure.o)
0x0000000020002438 . = ALIGN (0x4)
0x0000000020002438 PROVIDE (__preinit_array_start, .)
*(.preinit_array)
0x0000000020002438 PROVIDE (__preinit_array_end, .)
0x0000000020002438 PROVIDE (__init_array_start, .)
*(SORT(.init_array.*))
*(.init_array)
0x0000000020002438 PROVIDE (__init_array_end, .)
0x0000000020002438 PROVIDE (__fini_array_start, .)
*(SORT(.fini_array.*))
*(.fini_array)
0x0000000020002438 PROVIDE (__fini_array_end, .)
*(.jcr)
0x0000000020002438 __data_end__ = .
0x0000000020002438 __data_start__ = .
*(vtable)
*(.data*)
*(.preinit_array)
*(.init_array)
*(.fini_array)
*(.jcr)
Notice that __data_start__
is correct at first. Then it's redefined to what __data_end__
ends up being.
