nRF91 LTE_BLE_GATEWAY
Dear,
I am trying to test BLE on the nRF91 DK, I found an example:  \nrf\samples\nrf9160\lte_ble_gateway
I tried with the master branch, but I got the error:
Building ‘spm/zephyr/linker.cmd’ from solution ‘build’ in configuration ‘Common’
1> spm/zephyr/linker.cmd does not exist.
1> Combining ‘spm/zephyr/linker.cmd’
Building ‘spm/zephyr/CMakeFiles/spm_linker_script_target’ from solution ‘build’ in configuration ‘Common’
Building ‘spm/zephyr/spm_linker_script_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_spm_zephyr_prebuilt’ from solution ‘build’ in configuration ‘Common’
Building ‘spm/spm_app/libspm_app.a’ from solution ‘build’ in configuration ‘Common’
2> spm/CMakeFiles/spm_app.dir/src/main.c.obj does not exist.
2> Compiling ‘main.c’
1> spm\spm_app\libspm_app.a does not exist.
Building ‘spm/zephyr/libspm_zephyr.a’ from solution ‘build’ in configuration ‘Common’
1> Archiving ‘libspm_app.a’
2> spm/zephyr/CMakeFiles/spm_zephyr.dir/arch/common/isr_tables.c.obj does not exist.
2> Compiling ‘isr_tables.c’
3> spm/zephyr/CMakeFiles/spm_zephyr.dir/arch/common/sw_isr_common.c.obj does not exist.
3> Compiling ‘sw_isr_common.c’
4> spm/zephyr/CMakeFiles/spm_zephyr.dir/arch/arm/core/cortex_m/cmse/arm_core_cmse.c.obj does not exist.
4> Compiling ‘arm_core_cmse.c’
5> spm/zephyr/CMakeFiles/spm_zephyr.dir/arch/arm/core/cortex_m/tz/arm_core_tz.c.obj does not exist.
5> Compiling ‘arm_core_tz.c’
6> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/crc32_sw.c.obj does not exist.
6> Compiling ‘crc32_sw.c’
7> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/crc16_sw.c.obj does not exist.
7> Compiling ‘crc16_sw.c’
8> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/crc8_sw.c.obj does not exist.
8> Compiling ‘crc8_sw.c’
1> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/crc7_sw.c.obj does not exist.
1> Compiling ‘crc7_sw.c’
2> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/fdtable.c.obj does not exist.
2> Compiling ‘fdtable.c’
3> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/hex.c.obj does not exist.
3> Compiling ‘hex.c’
6> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/mempool.c.obj does not exist.
1> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/rb.c.obj does not exist.
1> Compiling ‘rb.c’
6> Compiling ‘mempool.c’
7> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/sem.c.obj does not exist.
7> Compiling ‘sem.c’
5> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/thread_entry.c.obj does not exist.
5> Compiling ‘thread_entry.c’
8> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/timeutil.c.obj does not exist.
8> Compiling ‘timeutil.c’
4> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/work_q.c.obj does not exist.
4> Compiling ‘work_q.c’
3> spm/zephyr/CMakeFiles/spm_zephyr.dir/lib/os/printk.c.obj does not exist.
3> Compiling ‘printk.c’
8> spm/zephyr/CMakeFiles/spm_zephyr.dir/misc/generated/configs.c.obj does not exist.
8> Compiling ‘configs.c’
2> spm/zephyr/CMakeFiles/spm_zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj does not exist.
2> Compiling ‘soc.c’
5> spm/zephyr/CMakeFiles/spm_zephyr.dir/soc/arm/nordic_nrf/nrf91/mpu_regions.c.obj does not exist.
5> Compiling ‘mpu_regions.c’
7> spm/zephyr/CMakeFiles/spm_zephyr.dir/ext/hal/nordic/nrfx/mdk/system_nrf9160.c.obj does not exist.
7> Compiling ‘system_nrf9160.c’
6> spm/zephyr/CMakeFiles/spm_zephyr.dir/ext/hal/nordic/nrfx_glue.c.obj does not exist.
6> Compiling ‘nrfx_glue.c’
1> spm/zephyr/CMakeFiles/spm_zephyr.dir/subsys/power/power.c.obj does not exist.
1> Compiling ‘power.c’
4> spm/zephyr/CMakeFiles/spm_zephyr.dir/subsys/power/reboot.c.obj does not exist.
4> Compiling ‘reboot.c’
8> spm/zephyr/CMakeFiles/spm_zephyr.dir/subsys/power/policy/policy_residency.c.obj does not exist.
8> Compiling ‘policy_residency.c’
7> spm/zephyr/CMakeFiles/spm_zephyr.dir/drivers/console/uart_console.c.obj does not exist.
7> Compiling ‘uart_console.c’
5> spm/zephyr/CMakeFiles/spm_zephyr.dir/drivers/clock_control/nrf_power_clock.c.obj does not exist.
5> Compiling ‘nrf_power_clock.c’
2> spm/zephyr/CMakeFiles/spm_zephyr.dir/drivers/timer/sys_clock_init.c.obj does not exist.
2> Compiling ‘sys_clock_init.c’
3> spm/zephyr/CMakeFiles/spm_zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj does not exist.
3> Compiling ‘nrf_rtc_timer.c’
1> spm/zephyr/CMakeFiles/spm_zephyr.dir/D_/hng/projects/CyCollector/ncs_2308_master/nrf/subsys/spm/spm.c.obj does not exist.
1> Compiling ‘spm.c’
6> spm/zephyr/CMakeFiles/spm_zephyr.dir/D_/hng/projects/CyCollector/ncs_2308_master/nrf/subsys/spm/secure_services.c.obj does not exist.
6> Compiling ‘secure_services.c’
1> spm\zephyr\libspm_zephyr.a does not exist.
Building ‘spm/zephyr/arch/arm/core/libspm_arch__arm__core.a’ from solution ‘build’ in configuration ‘Common’
1> Archiving ‘libspm_zephyr.a’
2> spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/exc_exit.S.obj does not exist.
2> Assembling ‘exc_exit.S’
3> spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/swap_helper.S.obj does not exist.
3> Assembling ‘swap_helper.S’
4> spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/cpu_idle.S.obj does not exist.
4> Assembling ‘cpu_idle.S’
5> spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/fault_s.S.obj does not exist.
5> Assembling ‘fault_s.S’
6> spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/nmi_on_reset.S.obj does not exist.
6> Assembling ‘nmi_on_reset.S’
7> spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/isr_wrapper.S.obj does not exist.
7> Assembling ‘isr_wrapper.S’
8> spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/swap.c.obj does not exist.
8> Compiling ‘swap.c’
1> spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/irq_manage.c.obj does not exist.
1> Compiling ‘irq_manage.c’
2> spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/thread.c.obj does not exist.
2> Compiling ‘thread.c’
3> spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/fatal.c.obj does not exist.
3> Compiling ‘fatal.c’
4> spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/nmi.c.obj does not exist.
4> Compiling ‘nmi.c’
5> spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/prep_c.c.obj does not exist.
5> Compiling ‘prep_c.c’
1> spm\zephyr\arch\arm\core\libspm_arch__arm__core.a does not exist.
Building ‘spm/zephyr/arch/arm/core/cortex_m/libspm_arch__arm__core__cortex_m.a’ from solution ‘build’ in configuration ‘Common’
1> Archiving ‘libspm_arch__arm__core.a’
2> spm/zephyr/arch/arm/core/cortex_m/CMakeFiles/spm_arch__arm__core__cortex_m.dir/vector_table.S.obj does not exist.
2> Assembling ‘vector_table.S’
3> spm/zephyr/arch/arm/core/cortex_m/CMakeFiles/spm_arch__arm__core__cortex_m.dir/reset.S.obj does not exist.
3> Assembling ‘reset.S’
4> spm/zephyr/arch/arm/core/cortex_m/CMakeFiles/spm_arch__arm__core__cortex_m.dir/fault.c.obj does not exist.
4> Compiling ‘fault.c’
5> spm/zephyr/arch/arm/core/cortex_m/CMakeFiles/spm_arch__arm__core__cortex_m.dir/scb.c.obj does not exist.
5> Compiling ‘scb.c’
6> spm/zephyr/arch/arm/core/cortex_m/CMakeFiles/spm_arch__arm__core__cortex_m.dir/irq_init.c.obj does not exist.
6> Compiling ‘irq_init.c’
7> spm/zephyr/arch/arm/core/cortex_m/CMakeFiles/spm_arch__arm__core__cortex_m.dir/thread_abort.c.obj does not exist.
7> Compiling ‘thread_abort.c’
1> spm\zephyr\arch\arm\core\cortex_m\libspm_arch__arm__core__cortex_m.a does not exist.
Building ‘spm/zephyr/arch/arm/core/cortex_m/mpu/libspm_arch__arm__core__cortex_m__mpu.a’ from solution ‘build’ in configuration ‘Common’
1> Archiving ‘libspm_arch__arm__core__cortex_m.a’
2> spm/zephyr/arch/arm/core/cortex_m/mpu/CMakeFiles/spm_arch__arm__core__cortex_m__mpu.dir/arm_core_mpu.c.obj does not exist.
2> Compiling ‘arm_core_mpu.c’
3> spm/zephyr/arch/arm/core/cortex_m/mpu/CMakeFiles/spm_arch__arm__core__cortex_m__mpu.dir/arm_mpu.c.obj does not exist.
3> Compiling ‘arm_mpu.c’
1> spm\zephyr\arch\arm\core\cortex_m\mpu\libspm_arch__arm__core__cortex_m__mpu.a does not exist.
Building ‘spm/zephyr/lib/libc/minimal/libspm_lib__libc__minimal.a’ from solution ‘build’ in configuration ‘Common’
1> Archiving ‘libspm_arch__arm__core__cortex_m__mpu.a’
2> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/stdlib/atoi.c.obj does not exist.
2> Compiling ‘atoi.c’
3> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/stdlib/strtol.c.obj does not exist.
3> Compiling ‘strtol.c’
4> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/stdlib/strtoul.c.obj does not exist.
4> Compiling ‘strtoul.c’
5> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/stdlib/malloc.c.obj does not exist.
5> Compiling ‘malloc.c’
6> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/stdlib/bsearch.c.obj does not exist.
6> Compiling ‘bsearch.c’
7> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/stdlib/exit.c.obj does not exist.
7> Compiling ‘exit.c’
8> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/string/strncasecmp.c.obj does not exist.
8> Compiling ‘strncasecmp.c’
1> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/string/strstr.c.obj does not exist.
1> Compiling ‘strstr.c’
2> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/string/string.c.obj does not exist.
2> Compiling ‘string.c’
4> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/string/strspn.c.obj does not exist.
4> Compiling ‘strspn.c’
3> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/stdout/prf.c.obj does not exist.
3> Compiling ‘prf.c’
6> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/stdout/stdout_console.c.obj does not exist.
6> Compiling ‘stdout_console.c’
8> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/stdout/sprintf.c.obj does not exist.
8> Compiling ‘sprintf.c’
1> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/stdout/fprintf.c.obj does not exist.
1> Compiling ‘fprintf.c’
7> spm/zephyr/lib/libc/minimal/CMakeFiles/spm_lib__libc__minimal.dir/source/time/gmtime.c.obj does not exist.
7> Compiling ‘gmtime.c’
1> spm\zephyr\lib\libc\minimal\libspm_lib__libc__minimal.a does not exist.
Building ‘spm/zephyr/drivers/serial/libspm_drivers__serial.a’ from solution ‘build’ in configuration ‘Common’
1> Archiving ‘libspm_lib__libc__minimal.a’
2> spm/zephyr/drivers/serial/CMakeFiles/spm_drivers__serial.dir/uart_nrfx_uarte.c.obj does not exist.
2> Compiling ‘uart_nrfx_uarte.c’
1> spm\zephyr\drivers\serial\libspm_drivers__serial.a does not exist.
Building ‘spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/libspm_mbeddrbg.a’ from solution ‘build’ in configuration ‘Common’
1> Archiving ‘libspm_drivers__serial.a’
2> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbeddrbg.dir/de772e27bd3bd05794d2fd6d89f43a82/mbedtls/library/ctr_drbg.c.obj does not exist.
2> Compiling ‘ctr_drbg.c’
3> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbeddrbg.dir/__/backend/cc310/replacements/entropy.c.obj does not exist.
3> Compiling ‘entropy.c’
1> spm\zephyr\modules\nrfxlib\nrf_security\src\mbedtls\libspm_mbeddrbg.a does not exist.
Building ‘spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/libspm_mbedcrypto_vanilla.a’ from solution ‘build’ in configuration ‘Common’
1> Archiving ‘libspm_mbeddrbg.a’
2> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/aes.c.obj does not exist.
2> Compiling ‘aes.c’
3> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/aesni.c.obj does not exist.
3> Compiling ‘aesni.c’
4> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/arc4.c.obj does not exist.
4> Compiling ‘arc4.c’
5> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/aria.c.obj does not exist.
5> Compiling ‘aria.c’
6> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/f62c56ec4c2fbe0fcfeeba9bfcaf4f2d/asn1parse.c.obj does not exist.
6> Compiling ‘asn1parse.c’
7> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/f62c56ec4c2fbe0fcfeeba9bfcaf4f2d/asn1write.c.obj does not exist.
7> Compiling ‘asn1write.c’
8> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/base64.c.obj does not exist.
8> Compiling ‘base64.c’
1> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/bignum.c.obj does not exist.
1> Compiling ‘bignum.c’
2> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/blowfish.c.obj does not exist.
2> Compiling ‘blowfish.c’
5> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/camellia.c.obj does not exist.
5> Compiling ‘camellia.c’
3> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/ccm.c.obj does not exist.
3> Compiling ‘ccm.c’
4> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/chacha20.c.obj does not exist.
4> Compiling ‘chacha20.c’
8> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/f62c56ec4c2fbe0fcfeeba9bfcaf4f2d/chachapoly.c.obj does not exist.
8> Compiling ‘chachapoly.c’
6> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/cipher.c.obj does not exist.
6> Compiling ‘cipher.c’
7> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/cmac.c.obj does not exist.
7> Compiling ‘cmac.c’
2> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/des.c.obj does not exist.
2> Compiling ‘des.c’
5> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/dhm.c.obj does not exist.
5> Compiling ‘dhm.c’
3> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/ecdh.c.obj does not exist.
3> Compiling ‘ecdh.c’
4> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/ecdsa.c.obj does not exist.
4> Compiling ‘ecdsa.c’
8> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/ecjpake.c.obj does not exist.
8> Compiling ‘ecjpake.c’
7> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/ecp.c.obj does not exist.
7> Compiling ‘ecp.c’
2> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/f62c56ec4c2fbe0fcfeeba9bfcaf4f2d/ecp_curves.c.obj does not exist.
2> Compiling ‘ecp_curves.c’
5> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/f62c56ec4c2fbe0fcfeeba9bfcaf4f2d/entropy_poll.c.obj does not exist.
5> Compiling ‘entropy_poll.c’
8> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/error.c.obj does not exist.
8> Compiling ‘error.c’
6> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/gcm.c.obj does not exist.
6> Compiling ‘gcm.c’
3> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/havege.c.obj does not exist.
3> Compiling ‘havege.c’
4> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/hkdf.c.obj does not exist.
4> Compiling ‘hkdf.c’
5> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/f62c56ec4c2fbe0fcfeeba9bfcaf4f2d/hmac_drbg.c.obj does not exist.
5> Compiling ‘hmac_drbg.c’
8> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/md.c.obj does not exist.
8> Compiling ‘md.c’
6> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/md2.c.obj does not exist.
3> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/md4.c.obj does not exist.
3> Compiling ‘md4.c’
6> Compiling ‘md2.c’
4> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/md5.c.obj does not exist.
4> Compiling ‘md5.c’
6> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/md_wrap.c.obj does not exist.
6> Compiling ‘md_wrap.c’
3> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/D_/hng/projects/CyCollector/ncs_2308_master/mbedtls/library/memory_buffer_alloc.c.obj does not exist.
3> Compiling ‘memory_buffer_alloc.c’
5> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/nist_kw.c.obj does not exist.
5> Compiling ‘nist_kw.c’
1> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/oid.c.obj does not exist.
1> Compiling ‘oid.c’
4> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/padlock.c.obj does not exist.
4> Compiling ‘padlock.c’
8> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/pk.c.obj does not exist.
8> Compiling ‘pk.c’
2> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/pk_wrap.c.obj does not exist.
2> Compiling ‘pk_wrap.c’
5> spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/spm_mbedcrypto_vanilla.dir/4352513364f36a06865eb5f026d6d137/library/pkcs12.c.obj does not exist.
5> Compiling ‘pkcs12.c’
3> D:/hng/projects/CyCollector/ncs_2308_master/mbedtls/library/memory_buffer_alloc.c:614:1: fatal error: opening dependency file D:/hng/projects/CyCollector/ncs_2308_master/nrf/samples/nrf9160/lte_ble_gateway/build_nrf9160_pca10090ns/spm\zephyr\modules\nrfxlib\nrf_security\src\mbedtls\CMakeFiles\spm_mbedcrypto_vanilla.dir\D_\hng\projects\CyCollector\ncs_2308_master\mbedtls\library\memory_buffer_alloc.c.obj.d: No such file or directory
3> compilation terminated.
Build failed
Then, I tried with PR #943, I got the same errors.
Which version of ncs should I use to test BLE on the nRF91 DK?
BR,
Hoang Nguyen
