Enabling and disabling Bluetooth
Hi there,
I'm currently working on a project in which I need to be able to deactivate Bluetooth advertising at the press of a button. I am using SDK 15.3 and have built a custom service from the ble_app_template example, following this tutorial. I have been able to get Bluetooth communication up and running, but am having difficulty deactivating it without causing the script to fail. To clarify, all I need it to do is to disable communication, not necessarily disable the entire module.
Here is the way I am currently enabling Bluetooth (working):
static void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
And this is the function I'm trying to use to disable it:
static void advertising_disconnect(void)
    ret_code_t err_code;
    // If connected, disconnect
    if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
        err_code = sd_ble_gap_disconnect(m_conn_handle,
    // Stop advertising
    err_code = sd_ble_gap_adv_stop(m_advertising.adv_handle);
When the button is pressed while no connected has been established, it hangs on sd_ble_gap_adv_stop() and will not reach the APP_ERROR_CHECK.
When the button is pressed while connected to a device, sd_ble_gap_disconnect() will work, but an error is generated at sd_ble_gap_adv_stop().
Is there a specific file I need to include in order to use sd_ble_gap_adv_stop()? Or maybe another way to achieve this?
*I have also tried using ble_advertising_start() to enter IDLE mode as a way of disabling communication but have not been able to get this to work either.
Any help would be much appreciated.
Cheers,
Charlie
  • I'm away from my main system right now, but I believe the proper way to stop advertising is:
    ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_IDLE);
  • Hi Charlie
    You should be able to call ble_advertising_start(BLE_ADV_MODE_IDLE); and sd_ble_gap_adv_stop(); to stop advertising. You can also check out this example, where someone is restarting advertising with a button press. That should be rather similar to what you're trying to do.
    Simon
  • Hi Simon
    Thank you for your help, I have managed to get sd_ble_gap_adv_stop(); to work when no connection has been established and am able to then toggle between advertising and not. However, I still cannot turn advertising off when a connection is established.
    Simply executing sd_ble_gap_adv_stop(); from the connected state has resulted in a NRF_ERROR_INVALID_STATE. I have tried removing the APP_ERROR_CHECK(err_code); but the connection is still not broken (possible that I am oversimplifying this and removing APP_ERROR_CHECK is not the same as ignoring the error code).
    Now, I am attempting to break the connection using sd_ble_gap_disconnect as bellow, where the function on_disconnect(); is used to update several parameters to match the new state.
    /**@brief Function for handling the Disconnect event.
     * @param[in]   p_cus       Custom Service structure.
     * @param[in]   p_ble_evt   Event received from the BLE stack.
    void on_disconnect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
        UNUSED_PARAMETER(p_ble_evt);
        p_cus->conn_handle = BLE_CONN_HANDLE_INVALID;
        ble_cus_evt_t evt;
        evt.evt_type = BLE_CUS_EVT_DISCONNECTED;
        p_cus->evt_handler(p_cus, &evt);
    /**@brief Function for stoping advertising.
    void advertising_stop(void)
    /**@brief Function for disconnecting device.
    void advertising_disconnect()
        ble_evt_t const * p_ble_evt;
        void * p_context;
        ble_cus_t * p_cus = (ble_cus_t *) p_context;
        on_disconnect(p_cus, p_ble_evt);
    The order these functions are called is: connection is established --> advertising_disconnect(); --> advertising_stop();
    Now with the code above, I am getting the error SOFTDEVICE: INVALID MEMORY ACCESS.
    When on_disconnect(); is commented out, an NRF_ERROR_INVALID_STATE is once again generated (also doesn't work when the error check is removed).
    I believe the issue may be from the sd_ble_gap_disconnect(); function as the evt_id appears to be different after every time I call it. Is there another way of severing the connection or just a general better way of handling this?
    Charlie
  • Hi
    How are you handling your disconnect events? The NRF_ERROR_INVALID_STATE from these functions means a disconnect is already in progress. You'll have to handle the events in the application code. Most of our ble_peripheral examples does this. Please check out the BLE_GAP_EVT_DISCONNECTED in any of them. Also, did you take a look at the post I linked to in my previous reply?
    Simon
    I finally managed to get everything working the other day. My main mistake was trying to run advertising_stop() immediately after advertising_disconnect() as the stop function would be called before the disconnect event was complete. To fix this, I added the stop function to the end of my BLE_GAP_EVT_DISCONNECTED event structure to ensure it was competed first (sd_ble_gap_disconnect(), once complete, will generate the BLE_GAP_EVT_DISCONNECTED evt_id and thus trigger the observer leading to the event handler).
    Charlie
