hi all ,
zephyr bt_hci_core: HCI driver open failed (-5)
i follow this link .(open lte-m(udp) and gps between psm mode on NRF9160)
now ,i need add HCI driver to control ble(nrf52840) central .
it get "HCI driver open failed"
how to do it (lte-m(udp) and gps between psm mode then ble controller)
HW: nRF9160-DK 0.8.5
1. i have been done hci_uart on nrf52840 and lte_ble_gateway suceess.
2. .config
# Generated by Kconfiglib (https://github.com/ulfalizer/Kconfiglib)
# GPS
# CONFIG_GPS_USE_SIM is not set
CONFIG_GPS_USE_EXTERNAL=y
# GPS_CONTROL
CONFIG_GPS_CONTROL=y
CONFIG_GPS_CONTROL_ON_LONG_PRESS=y
CONFIG_GPS_CONTROL_PSM_ENABLE_ON_START=y
# CONFIG_GPS_CONTROL_PSM_DISABLE_ON_STOP is not set
CONFIG_GPS_CONTROL_FIRST_FIX_CHECK_DELAY=10
CONFIG_GPS_CONTROL_FIX_CHECK_INTERVAL=120
CONFIG_GPS_CONTROL_FIX_TRY_TIME=360
CONFIG_GPS_CONTROL_FIX_COUNT=3
CONFIG_GPS_CONTROL_MAX_FAILED_FIX_ATTEMPTS=3
# CONFIG_GPS_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_GPS_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_GPS_CONTROL_LOG_LEVEL_WRN is not set
CONFIG_GPS_CONTROL_LOG_LEVEL_INF=y
# CONFIG_GPS_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_GPS_CONTROL_LOG_LEVEL=3
# end of GPS_CONTROL
CONFIG_GPS_DEV_NAME="NRF9160_GPS"
CONFIG_GPS_SIM_TRIGGER_TIMER_MSEC=2000
# end of GPS
# Zephyr Kernel
# Modules
# Nordic nRF Connect
# CONFIG_SECURE_BOOT_CRYPTO_CLIENT is not set
# CONFIG_SECURE_BOOT is not set
# Bluetooth Low Energy
# BLE Libraries
# CONFIG_BT_GATT_POOL is not set
CONFIG_BT_GATT_DM=y
CONFIG_BT_GATT_DM_MAX_ATTRS=35
CONFIG_BT_GATT_DM_MAX_MEM_CHUNKS=6
# CONFIG_BT_GATT_DM_LOG_LEVEL_OFF is not set
# CONFIG_BT_GATT_DM_LOG_LEVEL_ERR is not set
# CONFIG_BT_GATT_DM_LOG_LEVEL_WRN is not set
CONFIG_BT_GATT_DM_LOG_LEVEL_INF=y
# CONFIG_BT_GATT_DM_LOG_LEVEL_DBG is not set
CONFIG_BT_GATT_DM_LOG_LEVEL=3
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_NAME_MAX_LEN=32
CONFIG_BT_SCAN_SHORT_NAME_MAX_LEN=32
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_MANUFACTURER_DATA_MAX_LEN=32
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_SCAN_NAME_CNT=0
CONFIG_BT_SCAN_SHORT_NAME_CNT=0
CONFIG_BT_SCAN_ADDRESS_CNT=0
CONFIG_BT_SCAN_APPEARANCE_CNT=0
CONFIG_BT_SCAN_MANUFACTURER_DATA_CNT=0
# CONFIG_BT_SCAN_LOG_LEVEL_OFF is not set
# CONFIG_BT_SCAN_LOG_LEVEL_ERR is not set
# CONFIG_BT_SCAN_LOG_LEVEL_WRN is not set
CONFIG_BT_SCAN_LOG_LEVEL_INF=y
# CONFIG_BT_SCAN_LOG_LEVEL_DBG is not set
CONFIG_BT_SCAN_LOG_LEVEL=3
# CONFIG_BT_CONN_CTX is not set
# BLE GATT Services
# CONFIG_BT_GATT_BAS_C is not set
# CONFIG_BT_GATT_DFU_SMP_C is not set
# CONFIG_BT_GATT_HIDS is not set
# CONFIG_BT_GATT_HIDS_C is not set
# CONFIG_BT_GATT_LBS is not set
# CONFIG_BT_GATT_NUS is not set
# CONFIG_BT_GATT_NUS_C is not set
# CONFIG_BT_GATT_THROUGHPUT is not set
# end of Bluetooth Low Energy
# CONFIG_NRF_ESB is not set
# Networking
# Application protocols
# CONFIG_MQTT_SOCKET_LIB is not set
# CONFIG_NRF_CLOUD is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_FOTA_DOWNLOAD is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AWS_FOTA is not set
# CONFIG_CLOUD_API is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_T2T_PARSER is not set
# end of NFC
# CONFIG_PROFILER is not set
# SPM
CONFIG_SPM=y
# CONFIG_SPM_BUILD_STRATEGY_USE_HEX_FILE is not set
# CONFIG_SPM_BUILD_STRATEGY_SKIP_BUILD is not set
CONFIG_SPM_BUILD_STRATEGY_FROM_SOURCE=y
# CONFIG_IS_SPM is not set
# end of SPM
CONFIG_ARM_ENTRY_VENEERS_LIB_NAME="libspmsecureentries.a"
# CONFIG_FW_METADATA is not set
# CONFIG_PPI_TRACE is not set
# CONFIG_SHELL_BT_NUS is not set
# Libraries
# BSD Library for nrf91
CONFIG_BSD_LIBRARY=y
CONFIG_BSD_LIBRARY_SYS_INIT=y
# CONFIG_BSD_LIBRARY_TRACE_ENABLED is not set
# end of BSD Library for nrf91
# AT Host Library for nrf91
# CONFIG_AT_HOST_LIBRARY is not set
# end of AT Host Library for nrf91
# CONFIG_DK_LIBRARY is not set
CONFIG_AT_CMD_PARSER=y
# CONFIG_MODEM_INFO is not set
# CONFIG_PDN_MANAGEMENT is not set
# end of Libraries
# Device Drivers
# CONFIG_ADP536X is not set
# AT Command driver
CONFIG_AT_CMD=y
CONFIG_AT_CMD_SYS_INIT=y
CONFIG_AT_CMD_INIT_PRIORITY=40
CONFIG_AT_CMD_THREAD_PRIO=10
CONFIG_AT_CMD_THREAD_STACK_SIZE=1024
CONFIG_AT_CMD_RESPONSE_MAX_LEN=1792
# CONFIG_AT_CMD_LOG_LEVEL_OFF is not set
# CONFIG_AT_CMD_LOG_LEVEL_ERR is not set
# CONFIG_AT_CMD_LOG_LEVEL_WRN is not set
CONFIG_AT_CMD_LOG_LEVEL_INF=y
# CONFIG_AT_CMD_LOG_LEVEL_DBG is not set
CONFIG_AT_CMD_LOG_LEVEL=3
# end of AT Command driver
# CONFIG_GPS_SIM is not set
CONFIG_NRF9160_GPS=y
CONFIG_NRF9160_GPS_DEV_NAME="NRF9160_GPS"
CONFIG_NRF9160_GPS_FIX_CHECK_INTERVAL=1
CONFIG_NRF9160_GPS_SET_MAGPIO=y
CONFIG_NRF9160_GPS_MAGPIO_STRING="AT%XMAGPIO=1,0,0,1,1,1574,1577"
# NMEA strings
# CONFIG_NRF9160_GPS_NMEA_GSV is not set
# CONFIG_NRF9160_GPS_NMEA_GSA is not set
# CONFIG_NRF9160_GPS_NMEA_GLL is not set
CONFIG_NRF9160_GPS_NMEA_GGA=y
# CONFIG_NRF9160_GPS_NMEA_RMC is not set
# end of NMEA strings
CONFIG_NRF9160_GPS_INIT_PRIO=90
CONFIG_NRF9160_GPS_THREAD_PRIORITY=10
CONFIG_NRF9160_GPS_THREAD_STACK_SIZE=2048
# CONFIG_NRF9160_GPS_LOG_LEVEL_OFF is not set
# CONFIG_NRF9160_GPS_LOG_LEVEL_ERR is not set
# CONFIG_NRF9160_GPS_LOG_LEVEL_WRN is not set
# CONFIG_NRF9160_GPS_LOG_LEVEL_INF is not set
CONFIG_NRF9160_GPS_LOG_LEVEL_DBG=y
CONFIG_NRF9160_GPS_LOG_LEVEL=4
CONFIG_LTE_LINK_CONTROL=y
# CONFIG_LTE_AUTO_INIT_AND_CONNECT is not set
# CONFIG_LTE_LOCK_BANDS is not set
CONFIG_LTE_PSM_REQ_RPTAU="00101010"
CONFIG_LTE_PSM_REQ_RAT="00000001"
# CONFIG_LTE_EDRX_REQ is not set
CONFIG_LTE_EDRX_REQ_ACTT_TYPE="4"
CONFIG_LTE_EDRX_REQ_VALUE="1000"
# CONFIG_LTE_LEGACY_PCO_MODE is not set
# CONFIG_LTE_PDP_CMD is not set
CONFIG_LTE_NETWORK_MODE_LTE_M=y
# CONFIG_LTE_NETWORK_MODE_NBIOT is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_WRN is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_INF is not set
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG=y
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL=4
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# CONFIG_ST25R3911B_LIB is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_BLOCKING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_10PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_5PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_2PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_1PPM is not set
# end of Device Drivers
# External libraries
# CONFIG_CJSON_LIB is not set
# end of External libraries
# CONFIG_UNITY is not set
# end of Nordic nRF Connect
# MCUboot
CONFIG_BOOT_SIGNATURE_KEY_FILE="root-rsa-2048.pem"
# end of MCUboot
# Nordic nrfxlib
CONFIG_BSD_LIB=y
# CONFIG_NRFXLIB_NFC is not set
# Crypto libraries for nRF5x SOCs.
CONFIG_NRFXLIB_CRYPTO=y
CONFIG_NRF_OBERON=y
# CONFIG_NRF_CC310_BL is not set
# end of Crypto libraries for nRF5x SOCs.
# Nordic Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# end of Nordic Security
# end of Nordic nrfxlib
# Optional modules. Make sure they're installed, via the project manifest.
# CONFIG_CIVETWEB is not set
# CONFIG_LIBMETAL is not set
# CONFIG_MBEDTLS is not set
# CONFIG_MBEDTLS_TLS_VERSION_1_0 is not set
# CONFIG_MBEDTLS_TLS_VERSION_1_1 is not set
CONFIG_MBEDTLS_TLS_VERSION_1_2=y
# CONFIG_MBEDTLS_DTLS is not set
# CONFIG_MBEDTLS_SSL_EXPORT_KEYS is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_PSK_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_PSK_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_PSK_ENABLED is not set
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_ENABLED=y
# CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED is not set
# CONFIG_MBEDTLS_CIPHER_ALL_ENABLED is not set
CONFIG_MBEDTLS_CIPHER_AES_ENABLED=y
CONFIG_MBEDTLS_AES_ROM_TABLES=y
# CONFIG_MBEDTLS_CIPHER_CAMELLIA_ENABLED is not set
CONFIG_MBEDTLS_CIPHER_DES_ENABLED=y
# CONFIG_MBEDTLS_CIPHER_ARC4_ENABLED is not set
# CONFIG_MBEDTLS_CIPHER_CHACHA20_ENABLED is not set
# CONFIG_MBEDTLS_CIPHER_BLOWFISH_ENABLED is not set
# CONFIG_MBEDTLS_CIPHER_CCM_ENABLED is not set
# CONFIG_MBEDTLS_CIPHER_MODE_XTS_ENABLED is not set
# CONFIG_MBEDTLS_CIPHER_MODE_GCM_ENABLED is not set
CONFIG_MBEDTLS_CIPHER_CBC_ENABLED=y
# CONFIG_MBEDTLS_MAC_ALL_ENABLED is not set
# CONFIG_MBEDTLS_MAC_MD4_ENABLED is not set
CONFIG_MBEDTLS_MAC_MD5_ENABLED=y
CONFIG_MBEDTLS_MAC_SHA1_ENABLED=y
CONFIG_MBEDTLS_MAC_SHA256_ENABLED=y
CONFIG_MBEDTLS_SHA256_SMALLER=y
# CONFIG_MBEDTLS_MAC_SHA512_ENABLED is not set
# CONFIG_MBEDTLS_MAC_POLY1305_ENABLED is not set
# CONFIG_MBEDTLS_MAC_CMAC_ENABLED is not set
CONFIG_MBEDTLS_CTR_DRBG_ENABLED=y
# CONFIG_MBEDTLS_HMAC_DRBG_ENABLED is not set
# CONFIG_MBEDTLS_GENPRIME_ENABLED is not set
# CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT is not set
# CONFIG_MBEDTLS_HAVE_ASM is not set
# CONFIG_MBEDTLS_ENTROPY_ENABLED is not set
# CONFIG_MBEDTLS_USER_CONFIG_ENABLE is not set
# CONFIG_OPENAMP is not set
# QMSI
# end of QMSI
# CONFIG_TINYCBOR is not set
# TLS configuration
# Supported TLS version
# end of Supported TLS version
# Ciphersuite configuration
# Supported key exchange modes
# Supported cipher modes
# Supported message authentication methods
# end of Ciphersuite configuration
# Random number generators
# Other configurations
# end of TLS configuration
# end of Modules
CONFIG_BOARD="nrf9160_pca10090"
CONFIG_FLASH_LOAD_SIZE=0x40000
CONFIG_FLASH_LOAD_OFFSET=0x40000
CONFIG_SOC="nRF9160_SICA"
CONFIG_SOC_SERIES="nrf91"
CONFIG_NUM_IRQS=65
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
# CONFIG_WATCHDOG is not set
# CONFIG_UART_NS16550 is not set
# CONFIG_GPIO is not set
CONFIG_ISR_STACK_SIZE=2048
CONFIG_CLOCK_CONTROL=y
CONFIG_NRF_RTC_TIMER=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_SYS_POWER_MANAGEMENT=y
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_TEXT_SECTION_OFFSET=0
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_SRAM_SIZE=128
CONFIG_SRAM_BASE_ADDRESS=0x20020000
# CONFIG_SPI is not set
# CONFIG_NET_L2_IEEE802154 is not set
CONFIG_SOC_GECKO_EMU=y
# CONFIG_BOARD_NRF9160_PCA10090 is not set
CONFIG_BOARD_NRF9160_PCA10090NS=y
# Board Options
CONFIG_BOARD_NRF52840_GPIO_RESET=y
CONFIG_BOARD_NRF52840_GPIO_RESET_PIN=23
# end of Board Options
# CONFIG_SOC_SERIES_BEETLE is not set
# CONFIG_SOC_SERIES_MPS2 is not set
# CONFIG_SOC_SERIES_MUSCA is not set
# CONFIG_SOC_SERIES_MUSCA_B1 is not set
# CONFIG_SOC_SERIES_SAMD20 is not set
# CONFIG_SOC_SERIES_SAMD21 is not set
# CONFIG_SOC_SERIES_SAMR21 is not set
# CONFIG_SOC_SERIES_SAM3X is not set
# CONFIG_SOC_SERIES_SAM4S is not set
# CONFIG_SOC_SERIES_SAME70 is not set
# CONFIG_SOC_SERIES_PSOC62 is not set
# CONFIG_SOC_SERIES_MEC1501X is not set
# CONFIG_SOC_SERIES_MEC1701X is not set
# CONFIG_SOC_SERIES_NRF51X is not set
# CONFIG_SOC_SERIES_NRF52X is not set
CONFIG_SOC_SERIES_NRF91X=y
# CONFIG_SOC_SERIES_IMX_6X_M4 is not set
# CONFIG_SOC_SERIES_IMX7_M4 is not set
# CONFIG_SOC_SERIES_IMX_RT is not set
# CONFIG_SOC_SERIES_KINETIS_K6X is not set
# CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
# CONFIG_SOC_SERIES_KINETIS_KL2X is not set
# CONFIG_SOC_SERIES_KINETIS_KWX is not set
# CONFIG_SOC_SERIES_LPC54XXX is not set
# CONFIG_SOC_SERIES_LPC55XXX is not set
# CONFIG_SOC_SERIES_EFM32HG is not set
# CONFIG_SOC_SERIES_EFM32PG12B is not set
# CONFIG_SOC_SERIES_EFM32WG is not set
# CONFIG_SOC_SERIES_EFR32FG1P is not set
# CONFIG_SOC_SERIES_EFR32MG12P is not set
# CONFIG_SOC_SERIES_STM32F0X is not set
# CONFIG_SOC_SERIES_STM32F1X is not set
# CONFIG_SOC_SERIES_STM32F2X is not set
# CONFIG_SOC_SERIES_STM32F3X is not set
# CONFIG_SOC_SERIES_STM32F4X is not set
# CONFIG_SOC_SERIES_STM32F7X is not set
# CONFIG_SOC_SERIES_STM32G0X is not set
# CONFIG_SOC_SERIES_STM32H7X is not set
# CONFIG_SOC_SERIES_STM32L0X is not set
# CONFIG_SOC_SERIES_STM32L1X is not set
# CONFIG_SOC_SERIES_STM32L4X is not set
# CONFIG_SOC_SERIES_STM32MP1X is not set
# CONFIG_SOC_SERIES_STM32WBX is not set
# CONFIG_SOC_TI_LM3S6965 is not set
# CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
# CONFIG_SOC_SERIES_CC2650 is not set
# CONFIG_SOC_SERIES_CC32XX is not set
# CONFIG_SOC_SERIES_MSP432P4XX is not set
# Hardware Configuration
CONFIG_CPU_HAS_ARM_MPU=y
CONFIG_CPU_HAS_NRF_IDAU=y
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NRF=y
CONFIG_HAS_HW_NRF_CC310=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_DPPIC=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIOTE=y
CONFIG_HAS_HW_NRF_I2S=y
CONFIG_HAS_HW_NRF_IPC=y
CONFIG_HAS_HW_NRF_PDM=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_PWM1=y
CONFIG_HAS_HW_NRF_PWM2=y
CONFIG_HAS_HW_NRF_PWM3=y
CONFIG_HAS_HW_NRF_RTC0=y
CONFIG_HAS_HW_NRF_RTC1=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPIM0=y
CONFIG_HAS_HW_NRF_SPIM1=y
CONFIG_HAS_HW_NRF_SPIM2=y
CONFIG_HAS_HW_NRF_SPIM3=y
CONFIG_HAS_HW_NRF_SPIS0=y
CONFIG_HAS_HW_NRF_SPIS1=y
CONFIG_HAS_HW_NRF_SPIS2=y
CONFIG_HAS_HW_NRF_SPIS3=y
CONFIG_HAS_HW_NRF_SPU=y
CONFIG_HAS_HW_NRF_TIMER0=y
CONFIG_HAS_HW_NRF_TIMER1=y
CONFIG_HAS_HW_NRF_TIMER2=y
CONFIG_HAS_HW_NRF_TWIM0=y
CONFIG_HAS_HW_NRF_TWIM1=y
CONFIG_HAS_HW_NRF_TWIM2=y
CONFIG_HAS_HW_NRF_TWIM3=y
CONFIG_HAS_HW_NRF_TWIS0=y
CONFIG_HAS_HW_NRF_TWIS1=y
CONFIG_HAS_HW_NRF_TWIS2=y
CONFIG_HAS_HW_NRF_TWIS3=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_UARTE1=y
CONFIG_HAS_HW_NRF_UARTE2=y
CONFIG_HAS_HW_NRF_UARTE3=y
CONFIG_HAS_HW_NRF_WDT=y
CONFIG_GPIO_AS_PINRESET=y
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_SOC_NRF9160=y
CONFIG_SOC_NRF9160_SICA=y
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
CONFIG_SOC_LOG_LEVEL_INF=y
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL=3
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
# ARM Options
CONFIG_CPU_CORTEX=y
CONFIG_CPU_CORTEX_M=y
# CONFIG_BUILTIN_STACK_GUARD is not set
CONFIG_ARM_NONSECURE_FIRMWARE=y
# ARM TrustZone Options
# Non-secure firmware
CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS=y
# end of ARM TrustZone Options
# Architecture Floating Point Options
CONFIG_FP_HARDABI=y
# CONFIG_FP_SOFTABI is not set
# end of Architecture Floating Point Options
CONFIG_CPU_CORTEX_M33=y
CONFIG_ISA_THUMB2=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_CPU_CORTEX_M_HAS_CMSE=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_SE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
CONFIG_ARMV8_M_DSP=y
# ARM Cortex-M options
CONFIG_LDREX_STREX_AVAILABLE=y
CONFIG_DATA_ENDIANNESS_LITTLE=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_FAULT_DUMP=2
CONFIG_XIP=y
# end of ARM Cortex-M options
# ARM Cortex-M0/M0+/M3/M4/M7/M23/M33 options
CONFIG_GEN_ISR_TABLES=y
# CONFIG_ZERO_LATENCY_IRQS is not set
CONFIG_PLATFORM_SPECIFIC_INIT=y
# end of ARM Cortex-M0/M0+/M3/M4/M7/M23/M33 options
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_STACK_GUARD is not set
# CONFIG_MPU_ALLOW_FLASH_WRITE is not set
CONFIG_ARM_TRUSTZONE_M=y
CONFIG_ARCH="arm"
# end of ARM Options
# CONFIG_ARC is not set
CONFIG_ARM=y
# CONFIG_X86 is not set
# CONFIG_X86_64 is not set
# CONFIG_NIOS2 is not set
# CONFIG_RISCV is not set
# CONFIG_XTENSA is not set
# CONFIG_ARCH_POSIX is not set
# General Architecture Options
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
CONFIG_ARCH_LOG_LEVEL_INF=y
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL=3
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
CONFIG_MPU_LOG_LEVEL_INF=y
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL=3
# CONFIG_TRUSTED_EXECUTION_SECURE is not set
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
# CONFIG_HW_STACK_PROTECTION is not set
# CONFIG_USERSPACE is not set
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_PRIVILEGED_STACK_TEXT_AREA=256
CONFIG_KOBJECT_TEXT_AREA=256
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=0
CONFIG_GEN_IRQ_START_VECTOR=0
# CONFIG_IRQ_OFFLOAD is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_HAS_SYS_POWER_STATE_DEEP_SLEEP_1=y
CONFIG_CPU_HAS_TEE=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MEMORY_PROTECTION=y
CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
CONFIG_FLOAT=y
CONFIG_FP_SHARING=y
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
CONFIG_KERNEL_LOG_LEVEL_INF=y
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=7
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=0
CONFIG_NUM_METAIRQ_PRIORITIES=0
# CONFIG_SCHED_DEADLINE is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_IDLE_STACK_SIZE=320
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
CONFIG_ERRNO=y
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Kernel Debugging and Metrics
# CONFIG_INIT_STACKS is not set
# CONFIG_KERNEL_DEBUG is not set
CONFIG_BOOT_BANNER=y
CONFIG_BOOT_DELAY=0
# CONFIG_EXECUTION_BENCHMARKING is not set
# CONFIG_THREAD_MONITOR is not set
# CONFIG_THREAD_NAME is not set
# end of Kernel Debugging and Metrics
# Work Queue Options
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
CONFIG_OFFLOAD_WORKQUEUE_STACK_SIZE=1024
CONFIG_OFFLOAD_WORKQUEUE_PRIORITY=-1
# end of Work Queue Options
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
CONFIG_POLL=y
# end of Timer API Options
# Other Kernel Object Options
CONFIG_NUM_MBOX_ASYNC_MSGS=10
CONFIG_NUM_PIPE_ASYNC_MSGS=10
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_HEAP_MEM_POOL_MIN_SIZE=64
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Security Options
# CONFIG_STACK_CANARIES is not set
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# SMP Options
CONFIG_MP_NUM_CPUS=1
# CONFIG_SCHED_IPI_SUPPORTED is not set
# end of SMP Options
CONFIG_TICKLESS_IDLE=y
CONFIG_TICKLESS_IDLE_THRESH=3
CONFIG_TICKLESS_KERNEL=y
# CONFIG_SYS_POWER_DEEP_SLEEP_STATES is not set
# CONFIG_SYS_PM_STATE_LOCK is not set
# CONFIG_SYS_PM_DEBUG is not set
CONFIG_SYS_PM_POLICY_RESIDENCY=y
# CONFIG_SYS_PM_POLICY_DUMMY is not set
# CONFIG_SYS_PM_POLICY_APP is not set
CONFIG_SYS_PM_MIN_RESIDENCY_DEEP_SLEEP_1=60000
# CONFIG_SYS_PM_LOG_LEVEL_OFF is not set
# CONFIG_SYS_PM_LOG_LEVEL_ERR is not set
# CONFIG_SYS_PM_LOG_LEVEL_WRN is not set
CONFIG_SYS_PM_LOG_LEVEL_INF=y
# CONFIG_SYS_PM_LOG_LEVEL_DBG is not set
CONFIG_SYS_PM_LOG_LEVEL=3
# CONFIG_DEVICE_POWER_MANAGEMENT is not set
# end of General Kernel Options
CONFIG_HAS_DTS=y
# Device Drivers
# Bluetooth Drivers
# Bluetooth HCI Driver Options
CONFIG_BT_UART=y
CONFIG_BT_H4=y
# CONFIG_BT_H5 is not set
# CONFIG_BT_STM32_IPM is not set
# CONFIG_BT_NO_DRIVER is not set
CONFIG_BT_UART_ON_DEV_NAME="UART_2"
# end of Bluetooth Drivers
# CONFIG_IEEE802154 is not set
CONFIG_UART_CONSOLE_ON_DEV_NAME="UART_0"
CONFIG_CONSOLE=y
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
CONFIG_CONSOLE_HANDLER=y
CONFIG_UART_CONSOLE=y
CONFIG_UART_CONSOLE_INIT_PRIORITY=60
CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS=y
# CONFIG_UART_CONSOLE_MCUMGR is not set
# CONFIG_USB_UART_CONSOLE is not set
# CONFIG_RAM_CONSOLE is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_PIPE is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y
# CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
CONFIG_UART_CONSOLE_LOG_LEVEL=3
# CONFIG_SLIP is not set
# CONFIG_NET_LOOPBACK is not set
CONFIG_SERIAL=y
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
# CONFIG_UART_ASYNC_API is not set
# CONFIG_UART_LINE_CTRL is not set
# CONFIG_UART_DRV_CMD is not set
# Serial Drivers
# CONFIG_UART_NSIM is not set
CONFIG_UART_NRFX=y
CONFIG_UART_0_NRF_UARTE=y
CONFIG_UART_0_INTERRUPT_DRIVEN=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
# CONFIG_UART_0_NRF_FLOW_CONTROL is not set
CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
# CONFIG_UART_1_NRF_UARTE is not set
CONFIG_UART_2_NRF_UARTE=y
CONFIG_UART_2_INTERRUPT_DRIVEN=y
# CONFIG_UART_2_NRF_PARITY_BIT is not set
CONFIG_UART_2_NRF_FLOW_CONTROL=y
CONFIG_UART_2_NRF_TX_BUFFER_SIZE=32
# CONFIG_UART_3_NRF_UARTE is not set
CONFIG_NRF_UARTE_PERIPHERAL=y
# CONFIG_UART_ALTERA_JTAG is not set
# Interrupt Controllers
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# end of Interrupt Controllers
# Timer Drivers
# CONFIG_CORTEX_M_SYSTICK is not set
# CONFIG_SYSTEM_CLOCK_DISABLE is not set
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
# end of Timer Drivers
CONFIG_ENTROPY_GENERATOR=y
# CONFIG_ENTROPY_NRF5_RNG is not set
CONFIG_ENTROPY_NAME="ENTROPY_0"
# CONFIG_SHARED_IRQ is not set
# CONFIG_I2C is not set
# CONFIG_I2S is not set
# CONFIG_PWM is not set
# CONFIG_PINMUX is not set
# CONFIG_ADC is not set
# CONFIG_RTC is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_PTP_CLOCK is not set
# CONFIG_IPM is not set
# CONFIG_IPM_LOG_LEVEL_OFF is not set
# CONFIG_IPM_LOG_LEVEL_ERR is not set
# CONFIG_IPM_LOG_LEVEL_WRN is not set
CONFIG_IPM_LOG_LEVEL_INF=y
# CONFIG_IPM_LOG_LEVEL_DBG is not set
CONFIG_IPM_LOG_LEVEL=3
# CONFIG_FLASH is not set
# CONFIG_COUNTER is not set
# CONFIG_DMA is not set
# CONFIG_USB is not set
# CONFIG_CRYPTO is not set
# CONFIG_DISPLAY is not set
# CONFIG_LED_STRIP is not set
# CONFIG_WIFI is not set
# CONFIG_LED is not set
# CONFIG_CAN is not set
# CONFIG_MODEM is not set
# CONFIG_AUDIO is not set
# CONFIG_NEURAL_NET_ACCEL is not set
# CONFIG_HWINFO is not set
# CONFIG_ESPI is not set
# C Library
CONFIG_NEWLIB_LIBC=y
# CONFIG_NEWLIB_LIBC_FLOAT_PRINTF is not set
# CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
CONFIG_STDOUT_CONSOLE=y
# end of C Library
# Additional libraries
# CONFIG_LVGL is not set
# OS Support Library
# CONFIG_JSON_LIBRARY is not set
# CONFIG_RING_BUFFER is not set
# CONFIG_BASE64 is not set
# end of OS Support Library
CONFIG_POSIX_MAX_FDS=4
# CONFIG_POSIX_API is not set
# CONFIG_UPDATEHUB is not set
# CONFIG_UPDATEHUB_LOG_LEVEL_OFF is not set
# CONFIG_UPDATEHUB_LOG_LEVEL_ERR is not set
# CONFIG_UPDATEHUB_LOG_LEVEL_WRN is not set
CONFIG_UPDATEHUB_LOG_LEVEL_INF=y
# CONFIG_UPDATEHUB_LOG_LEVEL_DBG is not set
CONFIG_UPDATEHUB_LOG_LEVEL=3
# end of Additional libraries
CONFIG_BT=y
# CONFIG_BT_LOG_LEVEL_OFF is not set
# CONFIG_BT_LOG_LEVEL_ERR is not set
# CONFIG_BT_LOG_LEVEL_WRN is not set
CONFIG_BT_LOG_LEVEL_INF=y
# CONFIG_BT_LOG_LEVEL_DBG is not set
CONFIG_BT_LOG_LEVEL=3
CONFIG_BT_HCI=y
# CONFIG_BT_CUSTOM is not set
# CONFIG_BT_HCI_RAW is not set
# CONFIG_BT_PERIPHERAL is not set
CONFIG_BT_CENTRAL=y
# Broadcaster
# CONFIG_BT_BROADCASTER is not set
# end of Broadcaster
CONFIG_BT_OBSERVER=y
CONFIG_BT_PHY_UPDATE=y
CONFIG_BT_DATA_LEN_UPDATE=y
# GATT Services
# CONFIG_BT_GATT_DIS is not set
# CONFIG_BT_GATT_BAS is not set
# CONFIG_BT_GATT_HRS is not set
# end of GATT Services
CONFIG_BT_CONN=y
CONFIG_BT_MAX_CONN=1
CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
CONFIG_BT_WAIT_NOP=y
CONFIG_BT_DEBUG_NONE=y
# CONFIG_BT_DEBUG_LOG is not set
# CONFIG_BT_DEBUG_MONITOR is not set
# Host Stack Configuration
CONFIG_BT_HCI_HOST=y
CONFIG_BT_HCI_CMD_COUNT=2
CONFIG_BT_RX_BUF_COUNT=3
CONFIG_BT_RX_BUF_LEN=76
CONFIG_BT_DISCARDABLE_BUF_COUNT=3
CONFIG_BT_HCI_TX_STACK_SIZE=512
CONFIG_BT_HCI_TX_PRIO=7
CONFIG_BT_HCI_RESERVE=0
CONFIG_BT_RECV_IS_RX_THREAD=y
CONFIG_BT_RX_STACK_SIZE=1024
CONFIG_BT_RX_PRIO=8
CONFIG_BT_HOST_CRYPTO=y
CONFIG_BT_ACL_RX_COUNT=6
CONFIG_BT_CONN_TX_MAX=7
CONFIG_BT_AUTO_PHY_UPDATE=y
# CONFIG_BT_SMP is not set
# L2CAP Options
CONFIG_BT_L2CAP_RX_MTU=23
CONFIG_BT_L2CAP_TX_BUF_COUNT=3
CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
CONFIG_BT_L2CAP_TX_MTU=23
# end of L2CAP Options
# ATT and GATT Options
CONFIG_BT_ATT_ENFORCE_FLOW=y
CONFIG_BT_ATT_PREPARE_COUNT=0
CONFIG_BT_ATT_TX_MAX=2
# CONFIG_BT_GATT_DYNAMIC_DB is not set
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_READ_MULTIPLE=y
# end of ATT and GATT Options
CONFIG_BT_MAX_PAIRED=0
CONFIG_BT_CREATE_CONN_TIMEOUT=3
CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048
CONFIG_BT_BACKGROUND_SCAN_WINDOW=18
# CONFIG_BT_SCAN_WITH_IDENTITY is not set
# CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
CONFIG_BT_DEVICE_NAME="Zephyr"
CONFIG_BT_DEVICE_APPEARANCE=0
CONFIG_BT_ID_MAX=1
# CONFIG_BT_ECC is not set
# CONFIG_BT_TESTING is not set
# CONFIG_BT_BREDR is not set
# CONFIG_BT_HCI_VS_EVT_USER is not set
# BLE Controller support
# CONFIG_BT_CTLR is not set
# CONFIG_BT_SHELL is not set
CONFIG_CONSOLE_SUBSYS=y
CONFIG_CONSOLE_GETCHAR=y
# CONFIG_CONSOLE_GETLINE is not set
CONFIG_CONSOLE_GETCHAR_BUFSIZE=16
CONFIG_CONSOLE_PUTCHAR_BUFSIZE=16
# CONFIG_CPLUSPLUS is not set
# System Monitoring Options
# CONFIG_PERFORMANCE_METRICS is not set
# CONFIG_STATS is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_TRACING is not set
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
# CONFIG_ASSERT is not set
# CONFIG_FORCE_NO_ASSERT is not set
# CONFIG_OBJECT_TRACING is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_OPENOCD_SUPPORT is not set
# CONFIG_TRACING_CPU_STATS is not set
# CONFIG_TRACING_CTF is not set
CONFIG_HAS_SEGGER_RTT=y
# CONFIG_USE_SEGGER_RTT is not set
# end of Debugging Options
# CONFIG_DISK_ACCESS is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
CONFIG_FS_LITTLEFS_NUM_FILES=4
CONFIG_FS_LITTLEFS_NUM_DIRS=4
CONFIG_FS_LITTLEFS_READ_SIZE=16
CONFIG_FS_LITTLEFS_PROG_SIZE=16
CONFIG_FS_LITTLEFS_CACHE_SIZE=64
CONFIG_FS_LITTLEFS_LOOKAHEAD_SIZE=32
CONFIG_FS_LITTLEFS_BLOCK_CYCLES=512
# CONFIG_NVS is not set
# end of File Systems
CONFIG_LOG=y
# CONFIG_LOG_RUNTIME_FILTERING is not set
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# Prepend log message with function name
# CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
# end of Prepend log message with function name
# CONFIG_LOG_PRINTK is not set
# CONFIG_LOG_IMMEDIATE is not set
CONFIG_LOG_MODE_OVERFLOW=y
# CONFIG_LOG_MODE_NO_OVERFLOW is not set
CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
CONFIG_LOG_BUFFER_SIZE=1024
CONFIG_LOG_DETECT_MISSED_STRDUP=y
CONFIG_LOG_STRDUP_MAX_STRING=46
CONFIG_LOG_STRDUP_BUF_COUNT=4
# CONFIG_LOG_STRDUP_POOL_PROFILING is not set
CONFIG_LOG_DOMAIN_ID=0
# CONFIG_LOG_FRONTEND is not set
CONFIG_LOG_BACKEND_UART=y
# CONFIG_LOG_BACKEND_NET is not set
CONFIG_LOG_BACKEND_SHOW_COLOR=y
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
# Management
# CONFIG_MCUMGR_SMP_BT is not set
# CONFIG_MCUMGR_SMP_SHELL is not set
# CONFIG_MCUMGR_SMP_UART is not set
# CONFIG_MCUMGR is not set
# end of Management
# Networking
CONFIG_NET_BUF=y
CONFIG_NET_BUF_USER_DATA_SIZE=8
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
# CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
# CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
CONFIG_NET_BUF_LOG_LEVEL_INF=y
# CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
CONFIG_NET_BUF_LOG_LEVEL=3
# CONFIG_NET_BUF_POOL_USAGE is not set
CONFIG_NETWORKING=y
# CONFIG_NET_HOSTNAME_ENABLE is not set
# Link layer options
# CONFIG_NET_L2_DUMMY is not set
# CONFIG_NET_L2_BT_SHELL is not set
# CONFIG_NET_L2_ETHERNET is not set
# CONFIG_NET_L2_PPP is not set
# CONFIG_NET_L2_WIFI_MGMT is not set
# CONFIG_NET_L2_WIFI_SHELL is not set
# CONFIG_NET_L2_CANBUS is not set
# end of Link layer options
# IP stack
CONFIG_NET_INIT_PRIO=90
CONFIG_NET_IPV6=y
CONFIG_NET_IF_MAX_IPV6_COUNT=1
CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=2
CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=3
CONFIG_NET_IF_IPV6_PREFIX_COUNT=2
CONFIG_NET_INITIAL_HOP_LIMIT=64
CONFIG_NET_IPV6_MAX_NEIGHBORS=8
# CONFIG_NET_IPV6_FRAGMENT is not set
CONFIG_NET_IPV6_MLD=y
CONFIG_NET_IPV6_NBR_CACHE=y
CONFIG_NET_IPV6_ND=y
CONFIG_NET_IPV6_DAD=y
CONFIG_NET_IPV6_RA_RDNSS=y
# CONFIG_NET_6LO is not set
CONFIG_NET_IPV6_LOG_LEVEL=0
CONFIG_NET_ICMPV6_LOG_LEVEL=0
CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL=0
# CONFIG_NET_IPV4 is not set
# CONFIG_NET_SHELL is not set
CONFIG_NET_TC_TX_COUNT=1
CONFIG_NET_TC_RX_COUNT=1
CONFIG_NET_TC_MAPPING_STRICT=y
CONFIG_NET_TX_DEFAULT_PRIORITY=1
CONFIG_NET_IP_ADDR_CHECK=y
CONFIG_NET_MAX_ROUTERS=1
CONFIG_NET_ROUTE=y
# CONFIG_NET_ROUTING is not set
CONFIG_NET_MAX_ROUTES=8
CONFIG_NET_MAX_NEXTHOPS=8
# CONFIG_NET_TCP is not set
CONFIG_NET_UDP=y
CONFIG_NET_UDP_CHECKSUM=y
CONFIG_NET_UDP_LOG_LEVEL=0
CONFIG_NET_MAX_CONN=4
CONFIG_NET_MAX_CONTEXTS=6
# CONFIG_NET_CONTEXT_NET_PKT_POOL is not set
CONFIG_NET_CONTEXT_SYNC_RECV=y
CONFIG_NET_CONTEXT_CHECK=y
# CONFIG_NET_CONTEXT_PRIORITY is not set
# CONFIG_NET_CONTEXT_TIMESTAMP is not set
# CONFIG_NET_CONTEXT_TXTIME is not set
# CONFIG_NET_TEST is not set
# CONFIG_NET_TRICKLE is not set
CONFIG_NET_PKT_RX_COUNT=4
CONFIG_NET_PKT_TX_COUNT=4
CONFIG_NET_BUF_RX_COUNT=16
CONFIG_NET_BUF_TX_COUNT=16
CONFIG_NET_BUF_FIXED_DATA_SIZE=y
# CONFIG_NET_BUF_VARIABLE_DATA_SIZE is not set
CONFIG_NET_BUF_DATA_SIZE=128
CONFIG_NET_DEFAULT_IF_FIRST=y
# CONFIG_NET_DEFAULT_IF_OFFLOAD is not set
# CONFIG_NET_PKT_TIMESTAMP is not set
# CONFIG_NET_PKT_TXTIME is not set
# CONFIG_NET_PROMISCUOUS_MODE is not set
# Stack usage
CONFIG_NET_TX_STACK_SIZE=1200
CONFIG_NET_RX_STACK_SIZE=1500
# end of Stack usage
# CONFIG_NET_MGMT is not set
# CONFIG_NET_STATISTICS is not set
CONFIG_NET_OFFLOAD=y
CONFIG_NET_OFFLOAD_LOG_LEVEL=0
# CONFIG_NET_LOG is not set
CONFIG_NET_PKT_LOG_LEVEL=0
# CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set
CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0
# CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set
CONFIG_NET_CORE_LOG_LEVEL=0
CONFIG_NET_IF_LOG_LEVEL=0
CONFIG_NET_TC_LOG_LEVEL=0
CONFIG_NET_UTILS_LOG_LEVEL=0
CONFIG_NET_CONTEXT_LOG_LEVEL=0
CONFIG_NET_CONN_LOG_LEVEL=0
CONFIG_NET_ROUTE_LOG_LEVEL=0
# end of IP stack
# Network Protocols
# CONFIG_COAP is not set
# CONFIG_DNS_RESOLVER is not set
# CONFIG_MQTT_LIB is not set
# CONFIG_HTTP_PARSER is not set
# CONFIG_HTTP_PARSER_URL is not set
# CONFIG_LWM2M is not set
# CONFIG_SOCKS is not set
# CONFIG_SNTP is not set
# end of Network Protocols
# Network Libraries
CONFIG_NET_CONFIG_AUTO_INIT=y
CONFIG_NET_CONFIG_INIT_PRIO=95
CONFIG_NET_CONFIG_INIT_TIMEOUT=30
# CONFIG_NET_CONFIG_NEED_IPV6 is not set
# CONFIG_NET_CONFIG_NEED_IPV6_ROUTER is not set
# CONFIG_NET_CONFIG_NEED_IPV4 is not set
CONFIG_NET_CONFIG_LOG_LEVEL=0
# CONFIG_NET_CONFIG_SETTINGS is not set
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_SOCKETS_POLL_MAX=3
CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=3000
# CONFIG_NET_SOCKETS_SOCKOPT_TLS is not set
CONFIG_NET_SOCKETS_OFFLOAD=y
# CONFIG_NET_SOCKETS_CAN is not set
CONFIG_NET_SOCKETS_LOG_LEVEL=0
# CONFIG_TLS_CREDENTIALS is not set
# end of Network Libraries
# Network additional services
# CONFIG_NET_CONNECTION_MANAGER is not set
# end of Network additional services
# end of Networking
# CONFIG_SHELL is not set
# CONFIG_IMG_MANAGER is not set
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_TIMER_RANDOM_GENERATOR=y
# Storage
# end of Storage
# CONFIG_SETTINGS is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_TEST is not set
# CONFIG_TEST_SHELL is not set
CONFIG_TEST_EXTRA_STACKSIZE=0
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# CONFIG_JWT is not set
# External Sources
# HALs
CONFIG_HAS_CMSIS=y
# CONFIG_HAS_MEC_HAL is not set
CONFIG_HAS_NRFX=y
# end of HALs
# Cryptography
CONFIG_TINYCRYPT=y
# CONFIG_TINYCRYPT_CTR_PRNG is not set
CONFIG_TINYCRYPT_SHA256=y
CONFIG_TINYCRYPT_SHA256_HMAC=y
CONFIG_TINYCRYPT_SHA256_HMAC_PRNG=y
# CONFIG_TINYCRYPT_ECC_DH is not set
# CONFIG_TINYCRYPT_ECC_DSA is not set
CONFIG_TINYCRYPT_AES=y
# CONFIG_TINYCRYPT_AES_CBC is not set
# CONFIG_TINYCRYPT_AES_CTR is not set
# CONFIG_TINYCRYPT_AES_CCM is not set
# CONFIG_TINYCRYPT_AES_CMAC is not set
# end of Cryptography
# CONFIG_FNMATCH is not set
# end of External Sources
# Build and Link Features
# Linker Options
CONFIG_KERNEL=y
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
# CONFIG_CODE_DATA_RELOCATION is not set
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_USE_CODE_PARTITION is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
# CONFIG_CUSTOM_RODATA_LD is not set
# CONFIG_CUSTOM_RWDATA_LD is not set
# CONFIG_CUSTOM_SECTIONS_LD is not set
# CONFIG_LINK_WHOLE_ARCHIVE is not set
CONFIG_KERNEL_ENTRY="__start"
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
# end of Linker Options
# Compiler Options
# CONFIG_NATIVE_APPLICATION is not set
CONFIG_SIZE_OPTIMIZATIONS=y
# CONFIG_SPEED_OPTIMIZATIONS is not set
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# CONFIG_NO_OPTIMIZATIONS is not set
CONFIG_COMPILER_OPT=""
# end of Compiler Options
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
CONFIG_OUTPUT_DISASSEMBLY=y
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# end of Build Options
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_MCUBOOT is not set
# CONFIG_REBOOT is not set
# CONFIG_MISRA_SANE is not set
# end of Boot Options
# Compatibility
CONFIG_COMPAT_INCLUDES=y
# end of Compatibility
# end of Zephyr Kernel
3. nrf9160_pca10090ns.overlay
chosen {
zephyr,bt-uart=&uart2;
&uart2 {
current-speed = <1000000>;
status = "ok";
tx-pin = <18>;
rx-pin = <17>;
rts-pin = <21>;
cts-pin = <19>;
3.
CONFIG_NEWLIB_LIBC=y CONFIG_BSD_LIBRARY=y CONFIG_GPIO=n CONFIG_SERIAL=y CONFIG_STDOUT_CONSOLE=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_TEST_RANDOM_GENERATOR=y CONFIG_NETWORKING=y #CONFIG_NET_BUF_USER_DATA_SIZE=1 CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_POSIX_NAMES=y CONFIG_TRUSTED_EXECUTION_NONSECURE=y CONFIG_LOG=y CONFIG_LOG_DEFAULT_LEVEL=4 # Heap and stacks CONFIG_HEAP_MEM_POOL_SIZE=16384 CONFIG_MAIN_STACK_SIZE=8192 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_MAIN_THREAD_PRIORITY=7 # LTE link control CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_PSM_REQ_RPTAU="00101010" CONFIG_LTE_PSM_REQ_RAT="00000001" CONFIG_AT_HOST_LIBRARY=n CONFIG_LTE_AUTO_INIT_AND_CONNECT=n CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG=y CONFIG_LTE_NETWORK_MODE_NBIOT=n CONFIG_LTE_LEGACY_PCO_MODE=n # GPS CONFIG_NRF9160_GPS=y CONFIG_NRF9160_GPS_LOG_LEVEL_DBG=y CONFIG_GPS_USE_EXTERNAL=y CONFIG_GPS_DEV_NAME="NRF9160_GPS" CONFIG_GPS_CONTROL=y CONFIG_GPS_CONTROL_FIRST_FIX_CHECK_DELAY=10 CONFIG_GPS_CONTROL_FIX_COUNT=3 CONFIG_GPS_CONTROL_FIX_CHECK_INTERVAL=120 CONFIG_GPS_CONTROL_FIX_TRY_TIME=360 CONFIG_GPS_CONTROL_PSM_DISABLE_ON_STOP=n CONFIG_BT=y CONFIG_BT_H4=y CONFIG_BT_WAIT_NOP=y CONFIG_BT_CENTRAL=y CONFIG_BT_GATT_CLIENT=y CONFIG_BT_GATT_DM=y CONFIG_BT_SCAN=y CONFIG_BT_SCAN_FILTER_ENABLE=y CONFIG_BT_SCAN_UUID_CNT=1 CONFIG_UART_2_NRF_UARTE=y CONFIG_UART_2_NRF_FLOW_CONTROL=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_BSD_LIBRARY_TRACE_ENABLED=n # Console for user association CONFIG_CONSOLE_SUBSYS=y CONFIG_CONSOLE_GETCHAR=y
