Live fetch amount of bytes sent/received in modem
Hi
We have a budget every month of max bytes we can send (unsure about receive, but prob not included).
We need to be able to ask the modem for the actual NUMBER of bytes sent, including at any level of firmware, ie framing bytes, tcp bytes, encryption bytes, hidden bytes due to x.509 exchange handshake hello, key exchange etc, and also including the bytes we send with the  write call.
This is absolutely necessary to bound the data sent for our customer so they can limit and not go over the monthly budget.
How do you suggest we handle this?
We can only know the bytes written with the lowest level we have access to, and thats the socket.write. The rest done inside the modem, is done by Nordics secret modem firmware. We need access to a counter keeping track of the amount of bytes written to the base station. We need to be able to fetch this via an AT-command. At least.the bytes written, if not also available, the bytes received (but probably not counted towards a reception budget from the operator).
Also a clear command for the counter will be needed to start from 0, next month, or whenever we need to clear the counter.
Johan
