DK boards (nrf52832DK and nrf52840DK) fail to load JLINK driver
I tried to install the latest nRF Connect (3.1.0) on my Windows 7 dev machine and it did something to wipe out my USB setup (froze up during install of JLINK). So I had to use the latest System Restore Point to get my USB keyboard, mouse, etc to work.
But now my Nordic DK boards won't load.  When I plug them in the USB, I see a "Port" show up, but the "JLINK" part of the driver doesn't show up in the "Universal Serial Bus controllers" section any more.
On this same computer, I can use my standalone J-Link debugger (the expensive kind), and I can even use it to debug my DK boards (in a limited fashion, since I was using the built-in debugger for comms too, and that's all messed up now).
These same DK boards are visible and work on a different Widows 10 laptop and Macbook (i.e. I can 'nrfjprog -f NRF52 --reset', --halt, --run and all those work).  So the DK boards seem ok.  I tried forcing a reload of the DK jlink firmware and that doesn't make it work on the win7 box.
Absent other good ideas to try (which are welcome), is there a way to force the complete removal of JLINK drivers from the USB subsystem of this windows 7 machine and reinstall from scratch?  I've tried uninstalling JLINK itself from the programs and features" control panel (even going so far as choosing a few different versions of jlink to try) and it still doesn't work.
Edit: on the same Win7 machine, in a Mint Linux VM, the nrfjprog + jlink tools work like they are supposed to.  It's only trying to use them on the Win7 host that doesn't seem to work
  • New information: I have several nRF DK '32 boards and two '40 boards.
    The two '32 boards that I had successfully connected to the win7 host prior to bricking it with the nrfconnect install STILL SEEM TO WORK.  that is, those two still enumerate and show up as ids that nrfjprog sees and issues commands to.
    The other '32 boards and the '40 boards (that were not connected previously to this machine) do not work.  Yet they all work in the linux VM or on a different windows 10 and mac machine.
    Is this relevant?
    When I plug in the working '32 board, the device driver properties show in the "Universal Bus Serial controllers" section as "J-Link driver" with the Hardware Ids as:
    USB\VID_1366&PID_1015&REV_0100&MI_02
    USB\VID_1366&PID_1015&MI_02
    This is the same on the windows 10 machine as well
    When I plug in a non-working '32 board, I get only a COM16 (badged as no driver) in "Other devices" whose Hardware Ids show as:
    When I plug this same board into the windows 10 machine, the IDs show up as before
    I've also tried using the jlink configurator to reprogram the firmware from the windows 10 machine and reset the user data, nothing seems to help.
  • This exists:
    HKEY_USERS\S-1-5-21-863567031-3561377604-2044554372-1000\Software\SEGGER
    and has a J-flash, J-Link, and J-LinkRemoteServer sub folder
  • I renamed the SEGGER folder in the registry to SEGGER_OLD, then reinstalled the cmd line utilities (which installed jlkink 6.44e again) and it made a new registry entry, but the problem is still here.
    On the non-working boards, can you try, from Device Manager, to right click to get right-click menu, then "Update Driver Software..."? (Or, in the case of no driver, probably something like "Install Driver" or similar.)
    Regarding the nature of the issue, what happens when the board is connected to the computer and you try the command "nrfjprog --recover"? (I.e. what is the error message printed by nrfjprog, and is there anything else happening? "ERROR: There is no debugger connected to the PC"?)
    What is the output from "nrfjprog --version"?
    Terje
  • Yes, on the non-working boards I've tried the "update driver sw" and pointed it to the USBDriver folder in the JLink installation.  Doesn't seem to recognize it as a compatible driver.
    when the board is connected and issue the recover command I get the ERROR: There is no debugger ... message like you posted.
    nrfjprog version: 10.3.0
    JLinkARM.dll version: 6.50a
    I have also tried with JLinkARM.dll version 6.44e and it does the same thing. That's the version that NRFConnect tried to install.
