hello,
i want to build eddystone outside sdk..how can i do it.?? i found this..but not getting how to change those directories
can somebody help???
hello,
yes @Einar Thorsrud....thank you ..i removed app_button.c file and added it from the folder i want...it at least have accepted the path and can now open...i am making eddystone out of sdk..so i need to change paths
I think the best way to do it is to edit the project file (.emProject) in a text editor
I agree.
The project file is XML - there are plenty of text editors that recognise XML and will helpfully highlight the syntax for you ...
I use Notepad++
now i am done with all errors..solved...but getting two new errors as follows
Linking ble_app_eddystone_pca10040_s132.elf
cannot find ../../../../../../external/nrf_cc310/lib/cortex-m4/hard-float/libnrf_cc310_0.9.12.a: No such file or directory
cannot find ../../../../../../external/nrf_oberon/lib/cortex-m4/hard-float/liboberon_2.0.7.a: No such file or directory
i have those files inthose folders ony path is different now.....how to add path to those files...can get help??
thank you
The error message means that the file cannot be found at the specified path, which is relative to the project file. What is the full path to your project file, and what is the full path to libnrf_cc310_0.9.12.a?
If you are relocating the project file outside the SDK it would make sense to not use a relative path like this, but instead specify an exact path, using a global macro to define the SDK root.
i have added full path to files.... libnrf_cc310_0.9.12.a error is removed but, cannot find ../../../../../../external/nrf_oberon/lib/cortex-m4/hard-float/liboberon_2.0.7.a: No such file or directory is still there
