bootloader stuck in wait_for_events if started programatically
I have modified slightly the OTA bootloader sample in SDK6.1 and SoftDevice 7.1.0. After flashing the bootloader code to the nrf51822 it works like charm, I can update the firmware on the module OTA with MCP. If I upload OTA a modified version of hrs example code in SDK with OTA DFU support, the bootloader gets started by writing 0x01 to the DFU control characteristic, but afterwards it is stuck in wait_for_events function in bootloader.c. I use gcc 4.9.3 as compiler on Linux. Do you have any ideas what I should check?
I have checked with the unmodified codes in SDK v6.1. DFU does not work with MCP with those codes either. Is gcc problematic with bootloader?
Tamas
