I"m having trouble updating nrfConnect on my system. I am not using a proxy server.
Thanks for the help.
Hi.
According to a developer it has been removed, you should be able to install nRF Connect v3.2.0 without adding the nrf91.json file, just remove that source :-)
Andreas
Thanks, Andreas. I can install NRF Connect v3.2.0, but I get a version problem with nRF9x Link Monitor. When I try to launch it, I get a message that indicates that the app only supports NRF Connect ^2.4.0 and it never successfully launches. I get not messages to update Link Monitor.
Hi.
Have you upgraded both nRF Connecct for Desktop and the Link Monitor to the latest versions? I don't see this error message.
Andreas
As I indicated yesterday, I was able to install V3.20 of nRF Connect, but I cannot update the applications. When I try to run them, I get the message shown below. When I try to update the apps, the same message appears. Thank you for looking into this. I"m sure it's something simple that I am doing wrong.
Hi.
I think the issue is that you're not using the official app.
Can you remove the nRF91 source in the "Settings" tab and install the official application from the "Apps" tab?
Andreas
