Questions for Thingy 91
Dears
I listed my questions below. Thanks.
1. About GPS searching and fixing, I tried Thingy91 outdoors.
- When Thingy91 connected to LTE, did LED shall blue color?
-  Then, I pressed the button more than 10s, LED became purple color. As user guide said,
   LED will turn green color if GPS fixing. However, I wait half an hour, LED still kept purple color.
   NRF Cloud didn't get GPS data.
2. For Thingy91, where can I get asset tracker source code of NRF9160,
    and board controller source code of NRF52840?
3. For recharging battery by USB power, shall I keep SW1 of Thingy91 ON?
Thanks.
  • Hi Heidi
    Besides, shall I deleted this Thingy91 at NRF CLOUD  to work the new certificates/
  • Hi Heidi
    My steps for getting new certificates"
    1. Used Didrik's workaround for Windows 7 (echo | set /p=<PIN> | http POST ....)
    2. Edit certificates.h for asset tracker example.
    3. At prj.conf, set CONFIG_NRF_CLOUD_PROVISION_CERTIFICATES=y.
    4. Compiled asset tracker example by SES v4.20a
    5. Programmed merged.hex file to Thingy91.
    For step 2, since there are two public client certificates generated, I had tried three options: only A, only B and A with B at certificates.h.
    However, the results were same. It still cannot connect to NRF CLOUD.
    Log message:
    cloud_connect failed: -111
    LTE link disconnect
    Shutdown modem
  • Hi again!
    Yes, the public certificates belong together. One is the CA public key and the other is the device public key. And you do not have to delete your device from nRF Cloud.
    As for your error, I am getting the same one here at the office so I have raised the issue internally and I'll get back to you with an answer or a workaround as soon as possible.
  • Hi Heidi
    When run "(echo | set /p=<PIN> | http POST ....) ", I found even I key in a wrong PIN or wrong IMEI.
    The certificates data was also generated. Is it normal?
    As for error -111, if you have any further information, please let me know.
    Thanks.
  • Hi
    I have the same issue as Jeffery with my Thingy:91.
    Everything was fine past week with nrfCloud connection but I have this issue since I turned it on this week. I also tried with different SIM cards to be sure I'm not out of data.
    How can this happen ? I heard about a bug which seems to delete the certificates.
    Is it possible to send me back the certificates and give me the procedure to re-install them ? As it seems I'm not even able to send AT commands to the device as the device reboots every time just after the cloud_connect failed: -111 message.
    I'm going to send you my IMEI and PIN in a separate message.
