Butttonless DFU issue with CONFIG_NFCT_PINS_AS_GPIOS
I am using nrf52832 for button less DFU. DFU is working fine when  CONFIG_NFCT_PINS_AS_GPIOS is not added in applicaton. When added seems like code is getting reset at bootloader level. Is any connection with CONFIG_NFCT_PINS_AS_GPIOS ? Please suggest.
Thanks
  • HI chandan,
    which SDK and which SoftDevice version are you using?
    If the CONFIG_NFCT_PINS_AS_GPIOS is defined, then the following code will be compiled into and run by SystemInit() on startup.
        #if defined (CONFIG_NFCT_PINS_AS_GPIOS)
            if ((NRF_UICR->NFCPINS & UICR_NFCPINS_PROTECT_Msk) == (UICR_NFCPINS_PROTECT_NFC << UICR_NFCPINS_PROTECT_Pos)){
                NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos;
                while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
                NRF_UICR->NFCPINS &= ~UICR_NFCPINS_PROTECT_Msk;
                NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;
                NVIC_SystemReset();
    This code will simply configure the NFC pins as GPIOs and these pins are not used by the bootloader at all. If CONFIG_NFCT_PINS_AS_GPIOS is defined in the bootloader project, then the bootlaoders SystemInit() will run the snippet first and when jumping to the application it will see that the pins are already configured and not run the code as you can see from the if statement. Hence, whether CONFIG_NFCT_PINS_AS_GPIOS is defined or not in the application should not affect the bootloader or the DFU process in any way.
    Can you provide more details on what the issue is? When exactly does the reset occur?Can you provide logs from the debug output from the bootloader on the nRF52832?
    Best regards
    Bjørn
  • I am using nRF5_SDK_15.3.0 and s132_nrf52_6.1.1_softdevice. As I am flashing both boot loader and  application from nrf connect, not aware how to make log with debugger. Please help.
  • Also I have defined CONFIG_NFCT_PINS_AS_GPIOS in bootlodaer
  • Can you provide more details on what the issue is? When exactly does the reset occur?
    In order to capture logs from the bootloader you will have to flash the debug version, i.e. nRF5_SDK_15.3.0_59ac345\examples\dfu\secure_bootloader\pca10040_ble_debug. The example uses UART logging by default and you can view it using Putty with the following Terminal settings.
    Best regards
    Bjørn
  • Thanks, Below is the log
    <info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> nrf_dfu_settings: Us<info> app: Inside main
    <debug> nrf_dfu_settings: Using settings page.
    <debug> nrf_dfu_settings: Copying forbidden parts from backup page.<info> app: Inside main
    <debug> nrf_dfu_settings: Copying forbidden parts from <info> app: Inside main
    <info> a<info> app: Inside main
    <debug> nrf_dfu_settings: Callin<info> app: Inside main
    <debug> nrf_dfu_sett<info> app: Inside main
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_i<info> app: Inside main
    <debu<info> app: Inside main
    <debug> nrf_dfu_set<info> app: Inside main
    <debug> nrf_dfu_<info> app: Inside main
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init(<info> app: Inside main
    <debug> nrf_dfu_settings: Copying forbi<info> app: Inside main
    <deb<info> app: Inside main
    <debug><info> app: Inside main
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend. <info> app: Inside main
    <debug> nrf_dfu_settings: Calling nrf_dfu_settin<info> app: Inside main
