How a device in mesh of ble controlled by internet.
I tested light on/off of mesh and it works fine.
but how can I control it from internet.
like with wifi or ethernet modules connected with one of the device.
Not sure that's within the scope of the Model ?
It's your application which needs to deal with the UART, recognise your "commands", and feed that into the Mesh
On Models:
https://devzone.nordicsemi.com/f/nordic-q-a/51801/why-there-is-models-in-mesh-communication-nrf52832
If i can't create models likes this, Then I think this BLE Mesh is useless, as today's world wants configurable and manageable system witch can be accessed from anywhere.
In zigbee protocol this thing is very simple to do, take uart data and send to any node.
When I comes to know about BLE mesh, then I think its mostly useful as system can be connected to mobile directly (this is also true I expreiments it and happy with it).
But when its comes to real life application Ble mesh doesn't seems to perform well.
Correct me if I am wrong.
Thank You
You're missing the point!
You don't need to create the model - that is done for you already.
In the Nordic Mesh SDK example, they use the buttons to make the 'On' and 'Off' work.
So all you have to do is to do whatever happens on those buttons - but do it in response to your UART messages instead.
Actually my requirement of model are as follow:
1) A node took data from uart, in uart data there is address of node, whom to send data and data of dimming level.
2) every node should have functionality like this. with address send data to any node.
3) can took status data from any node.
Uart implementation is not issue.
Issue is not to access any node individually. I can access to only a fixed configured node.
OK - none of that was clear from your original post.
As the name suggests, the on'off demo just does 'ON' and 'OFF' - not dimming - so you do need a different model for that.
Have you looked at the other examples to see if there's something closer to your requirements?
In terms of moving on from the examples, see:
