PA and LNA pin in BLE mesh examples
Hi All,
I'm referring to generic on/off ble mesh example code and we are in the development stage.
I would like to know which pins are used for PA and LNA in the example code and what changes do I need to make if I want to enable it on my custom hardware.
Here is the code snippet from example code: gpiote_setup(&m_gpiote.params.lna_cfg, m_gpiote.params.ppi_ch_id_set);
Thanks in advance.
Domneck
  • Hi.
    Have you seen the documentation about adding PA/LNA support?
    Infocenter - Adding PA/LNA Support
    Joakim
    In link I see GPIO pins 25 and 24 are used for PA and LNA but in schematic I'm finding it (in PCA 10056).
    And if I want to change in software as per custom hardware how do I do?
    And also I checked in debug mode "mesh_pa_lna_gpiote_enable" is the function to enable and it's not called any where in the code and "m_gpiote.enabled" flag is false always.
    Domneck
  • Hi!
    There is a code example in the link i sent you. In the guide we are using GPIO pins 24/25, but you are free to change this to any other unused GPIO.
     Did you add a call to the mesh_pa_lna_gpiote_enable() function?
    Point 3. in the guide: sd
    Enable the PA/LNA module by calling mesh_pa_lna_gpiote_enable() after the call to mesh_init():
        mesh_pa_lna_gpiote_enable(&m_pa_lna_params);
    Joakim
