nRF52810 power optimization
I am currently working on an application for nRF52810. It has only advertising feature and I calculated the consumption with online calculator. The values I got from the calculator are:
but in the real device I get values:
* 5s adv average: 3.9uA
* in sleep average: 1.46uA
* send peak: 6.67mA
This is the power consumption diagram:
I am using module  ISP1507_AL  and I am not sure where I can lower the consumption to get to the calculated values.
Suggestions and questions are welcomed.
Thank you,
Voja.
  • Have you set the external crystal as the LFCLK source?
    What is your Supply Voltage?
    The ISP1507_AL is an exact copy of our reference design, so I doubt the issue lies with the SiP.
    I think the crystal is set correctly, this is the part of the sdk_config.h for that:
    // </h>
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 1
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 0
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 0
    // <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 7
    // </h>
    The supply voltage is 3V.
  • Yeah, that looks correct.
    What's your operating temperature? The calculator assumes 25C operating temperature.
    See Figure 2. System ON, Full 24 kB RAM retention, Wake on any event (typical values) in Sleep.
  • May I have a question?
    ISP1507 datasheet:
    Shouldn't be correct setting:
    #define NRF_SDH_CLOCK_LF_ACCURACY 5
  • Yes, you're correct. If a module has a 32kHz crystal already then you need to follow its spec.
