Why is LTE band 7 (2600MHz) not available?
I have a nRF9160 DK and since I am in Germany, we are trying to use the most common LTE band they use here, which are:
Band 1,3,7,20
However, band 7 does not seem available from the AT band lock commands.
AFAIK, the embedded Ethretronics antenna is a Octaband antenna also supporting 2600 MHz, so what's going on  here?
http://datasheets.avx.com/ethertronics/AVX-E_P822601-P822602.pdf
     This is because band 7 isn't supported by the modem yet, and as far as I know it isn't being certified in the near future either. I'm not aware of the concrete reasons why it isn't supported.
  • Hi Hakan,
    Yes, I see now that perhaps this may be a hardware limitation. (Is it realy?)
    Although I find it funny that it supports BT which operates at ~2400 MHz.
    But the LTE bands are clear from here:
    https://en.wikipedia.org/wiki/LTE_frequency_bands
    Which if it is true that the SiP9160 cannot handle LTE above 2200 MHz according to the product sheet:
    www.nordicsemi.com/.../nRF9160-SiP-product-brief.pdf
    www.nordicsemi.com/.../nRF9160-Certifications
    Then we will not be able to use the following bands:
    Bands above 2200 MHz:
    7,30,38,40-43,46-49,52,63,69
    Here's the list:
    1	FDD	2100
    2	FDD	1900
    3	FDD	1800
    4	FDD	1700
    5	FDD	850
    7	FDD	2600
    8	FDD	900
    11	FDD	1500
    12	FDD	700
    13	FDD	700
    14	FDD	700
    17	FDD	700
    18	FDD	850
    19	FDD	850
    20	FDD	800
    21	FDD	1500
    24	FDD	1600
    25	FDD	1900
    26	FDD	850
    28	FDD	700
    29	SDL 700
    30	FDD	2300
    31	FDD	450
    32	SDL	1500
    34	TDD	2000
    37	TDD	1900
    38	TDD	2600
    39	TDD	1900
    40	TDD	2300
    41	TDD	2500
    42	TDD	3500
    43	TDD	3700
    44	TDD	700
    46	TDD	5200
    47	TDD	5900
    48	TDD	3500
    49	TDD	3500
    50	TDD	1500
    51	TDD	1500
    52	TDD	3300
    53	TDD	2400
    65	FDD	2100
    66	FDD	1700
    67	SDL	700
    68	FDD	700
    69	SDL 2600
    70	FDD	1700
    71	FDD	600
    72	FDD	450
    73	FDD	450
    74	FDD	1500
    75	SDL 1500
    76	SDL 1500
    85	FDD	700
    87	FDD	450
    88	FDD	450
    Thanks for the answer!
